621-M09-360-BT4
621-M09-360-BT4
    弯插
    621M SERIES RIGHT ANGLE D-SUB PL
621-M09-360-BT4 数据手册
621M/622M SERIES D-Sub Connectors: Right Angle, 0.283”(7.20mm) Footprint Features: • • • • • • • • • Two contact rows with 0.283”(7.20mm) footprint, right angle bend D-Sub with machined contacts 0.109”(2.77mm) contact spacing x 0.112”(2.84mm) row spacing Plug and receptacle in 9, 15, 25, 37 or 50 contact sizes Pin and socket contact mating design with P.C. tail termination Metal shell provides EMI/RFI shielding, plug shell indents provide grounding and additional mating retention Grounding features include brackets with four prong boardlock for exceptional retention to P.C. board Mounting options for panel mount or connector mating include through hole, threaded inserts and threaded standoffs Insulation housings are offered in different colors: black, white, green and blue D-shaped connector mating outline provides polarization Specifications: Insulator Material PA6T, UL 94V-0, Color: Black, White, Blue or Green Contact Material Precision Machined Copper Alloy Contact Plating Gold Plating over Nickel All Over Shell Material Nickel Plated Steel (Optional Tin Plating) Current Rating 5 amps Contact Resistance 10 Milliohms maximum Dielectric Withstanding Voltage 5000 megaohms minimum Insulation Resistance 1000 V AC rms at Sea Level Operating Temperature -55°C To +125°C Ordering Code: 621-M25-260-BN3 SERIES: 621: PLUG (PIN) 622: RECEPTACLE (SOCKET) M: MACHINED CONTACTS NO. OF CONTACTS: 09 - 9 CONTACTS 25 - 25 CONTACTS 15 - 15 CONTACTS 37 - 37 CONTACTS 50 - 50 CONTACTS CONTACT FINISH CODE: 2 - GOLD FLASH PLATING 3 - 15 MICROINCHES OF GOLD PLATING 6 - 30 MICROINCHES OF GOLD PLATING CONTACT CODE: 60 - .283"(7.20MM) FOOTPRINT RIGHT ANGLE PC TAIL www.edac.net MOUNTING & GROUNDING OPTIONS: 1 - Ø.120"(Ø3.05) THROUGH HOLE 2 - 4-40 UNC INSERT 3 - 4-40 UNC INSERT + STABILIZER PCB + BOARDLOCKS 4 - 4-40 UNC INSERT + STABILIZER PCB + Ø.126"(Ø3.20) HOLE 5 - 4-40 UNC STANDOFF + STABILIZER PCB + BOARDLOCKS 6 - 4-40 UNC STANDOFF + STABILIZER PCB + Ø.126"(Ø3.20) HOLE SHELL PLATING CODE: N - NICKEL T - TIN HOUSING MATERIAL CODE: B - BLACK W - WHITE G - GREEN L - BLUE customerservice@edac.net 621M/622M SERIES D-Sub Connectors: Right Angle, 0.283”(7.20mm) Footprint PLUG RECEPTACLE MOUNTING & GROUNDING OPTIONS: CODE - 1 Ø3.05 THROUGH HOLE CODE - 2 #4-40 UNC INSERT CODE - 3 #4-40 UNC INSERT + STABILIZER PCB + BOARDLOCKS CODE - 4 #4-40 UNC INSERT + STABILIZER PCB + Ø3.20 HOLE www.edac.net customerservice@edac.net 621M/622M SERIES D-Sub Connectors: Right Angle, 0.283”(7.20mm) Footprint MOUNTING & GROUNDING OPTIONS: CODE - 5 #4-40 UNC STANDOFF + STABILIZER PCB + BOARDLOCKS CODE - 6 #4-40 UNC STANDOFF + STABILIZER PCB + Ø3.20 HOLE RECOMMENDED PCB LAYOUT 9 POS 37 POS 15 POS 50 POS 25 POS www.edac.net customerservice@edac.net
621-M09-360-BT4
物料型号为621M/622M系列,是EDAC D-SUB+的D-Sub连接器。
以下是关于该连接器的详细信息:
- 器件简介:提供直角弯曲的D-Sub连接器,具有机械加工的接触点,接触点间距为0.109英寸(2.77mm),行间距为0.112英寸(2.84mm)。
插头和插座有9、15、25、37或50个接触点大小。
- 引脚分配:提供了不同接触点数量的尺寸,包括9、15、25、37和50个接触点。
- 参数特性: - 绝缘体材料:PA6T, UL 94V-0,颜色:黑色、白色、蓝色或绿色。
- 接触材料:精密机械加工的铜合金。
- 接触镀层:整体镀金,覆盖镍。
- 外壳材料:镀镍钢(可选镀锡)。
- 电流额定值:5安培。
- 接触电阻:最大10毫欧姆。
- 介质耐压:至少5000兆欧姆。
- 绝缘电阻:在海平面上1000V交流有效值。
- 工作温度:-55°C至+125°C。
- 功能详解:金属外壳提供EMI/RFI屏蔽,插头外壳的凹槽提供接地和额外的配对保持力。
接地特性包括带有四个插脚板锁的支架,以实现对PCB板的卓越保持。
- 应用信息:适用于需要直角D-Sub连接器的应用,如电子设备连接。
- 封装信息:提供了不同颜色的绝缘体外壳,D形连接器配对轮廓提供极化。
订购代码示例:621-M25-260-BN3,包括多种安装和接地选项。
更多详细信息和推荐PCB布局可以在EDAC的官方网站上找到。
621-M09-360-BT4 价格&库存
很抱歉,暂时无法提供与“621-M09-360-BT4”相匹配的价格&库存,您可以联系我们找货
