625-009-262-532
625-009-262-532
    625 SERIES RIGHT ANGLE D-SUB PLU
625-009-262-532 数据手册
625/626 SERIES D-Sub Connectors: Right Angle, 0.584” (14.84mm) Footprint Features: • • • • • • • • • Two contact rows with 0.584”(14.84mm) footprint, right angle bend 0.109”(2.77mm) contact spacing X 0.112”(2.84mm) row spacing Plug and receptacle in 9, 15, 25, or 37 contact sizes Pin and socket contact mating design with P.C. tail termination Metal shell provides EMI/RFI shielding, plug shell indents provide grounding and additional mating retention Board mounting features include threaded hole, two and three prong boardlock for superior retention to P.C. board Flange mounting options for panel mount or connector mating include through hole, threaded hole and threaded standoffs D-shaped connector mating outline provides polarization Design based on requirements of MIL-C-24038, EIA RS-232 and RS-449 Specifications: Insulator Material Thermoplastic Polyester, UL 94V-0, Chemical Resistant, Color: Black Contact Material Plug (Pins): Copper Alloy Receptacle (Socket): Copper Alloy Contact Plating Selective Gold (See Ordering Code) over Nickel for the Mating Area, Tin Plating for Tail Area Shell Material Nickel Plated Steel Current Rating 3 amps Contact Resistance 25 Milliohms maximum Insulation Resistance 5000 megaohms minimum Dielectric Withstanding Voltage 1000 V AC rms at Sea Level Operating Temperature -55°C To +85°C (upto +125°C for high temp) Insertion Force 16 oz (4.45 N) Maximum Per Contact Position Withdrawal Force 1 oz (0.28 N) Minimum Per Contact Position Ordering Code: FLANGE MOUNTING OPTIONS 625-037-262-043 SERIES: 625: PLUG (PIN) 626: RECEPTACLE (SOCKET) NO. OF CONTACTS: 009 - 9 CONTACTS 025 - 25 CONTACTS 015 - 15 CONTACTS 037 - 37 CONTACTS CONTACT FINISH CODE: 2 - GOLD FLASH PLATING 3 - 15 MICROINCHES OF GOLD PLATING 6 - 30 MICROINCHES OF GOLD PLATING CONTACT CODE: 62 - .584" (14.84MM) FOOTPRINT CONTACT www.edac.net FLANGE MOUNTING OPTIONS: 0 - #4-40 THREADED FIXED STANDOFF 1 - Ø.120"(Ø3.05MM) THROUGH HOLE 2 - #4-40 THREADED HOLE 3 - #4-40 THREADED STANDOFF 5 - M3 THREADED HOLE BOARD MOUNTING FEATURE: 1 - Ø.120"(Ø3.05MM) THROUGH HOLE 3 - TWO PRONG BOARDLOCKS 4 - THREE PRONG BOARDLOCKS INSULATOR MATERIAL CODE: 0 - STANDARD 5 - HIGH TEMP INSULATOR customerservice@edac.net 625/626 SERIES D-Sub Connectors: Right Angle, 0.584” (14.84mm) Footprint PLUG #4-40 UNC/M3 15-Ø1.10 2.77±0.13 2.84 A B C 2.77±0.13 2-Ø3.20 8.00 14.84 12.55±0.38 8.36±0.13 2.84 1.385 P.C.B EDGE 1.385 6.00±0.25 8.00±0.25 2.84 19.16±0.25 12.45 14.84±0.25 RECOMMENDED P.C.B LAYOUT (FOR PLUG AND RECEPTACLE) 3.18±0.38 RECEPTACLE A B C 2.77±0.13 12.55±0.38 7.90±0.13 2.84 #4-40 UNC/M3 5.80±0.25 8.00±0.25 2.84 19.16±0.25 12.45 14.84±0.25 1.385 NUMBER OF CONTACTS www.edac.net A±0.38 Inch B±0.25 3.18±0.38 C±0.13 PLUG C±0.13 RECEPTACLE Inch (mm) Inch (mm) Inch (mm) 9 1.213 (30.81) .984 (24.99) .666 (16.92) .643 (16.33) 15 1.543 (39.19) 1.312 (33.32) .994 (25.25) .971 (24.66) 25 2.088 (53.04) 1.852 (47.04) 1.534 (38.96) 1.511 (38.38) 37 2.729 (69.32) 2.500 (63.50) 2.182 (55.42) 2.159 (54.84) (mm) customerservice@edac.net
625-009-262-532
物料型号:625/626系列
器件简介:这些连接器是直角D-Sub连接器,具有0.584英寸(14.84mm)的尺寸,适用于9、15、25或37个接触点。
引脚分配:提供两排接触点,接触点间距为0.109英寸(2.77mm),行间距为0.112英寸(2.84mm)。
参数特性: - 绝缘体材料:热塑性聚酯,UL 94V-0,耐化学腐蚀,颜色为黑色。 - 接触材料:插头(针)和插座(孔)均为铜合金。 - 接触镀层:选择性金层(详见订购代码)覆盖镍层,尾部区域为锡镀层。 - 壳体材料:镀镍钢。 - 电流额定值:3安培。 - 接触电阻:最大25毫欧姆。 - 绝缘电阻:最小5000兆欧姆。 - 耐电压:1000V交流有效值,海平面。 - 工作温度:-55°C至+85°C(高温版本可达+125°C)。 - 插入力:每个接触位置最大16盎司(4.45牛顿)。 - 拔出力:每个接触位置最小0.28牛顿。
功能详解:金属壳体提供EMI/RFI屏蔽,插头壳体凹槽提供接地和额外的配对保持力。板载安装特性包括螺纹孔、两个和三个叉板锁,以实现对PCB板的优越保持力。面板安装或连接器配对的法兰安装选项包括通孔、螺纹孔和螺纹支架。
应用信息:设计基于MIL-C-24038、EIA RS-232和RS-449的要求。
封装信息:D形连接器配对轮廓提供极化。
订购代码:提供了详细的订购代码,包括系列、接触点数量、法兰安装选项、板载安装特性、接触表面处理代码和接触代码。
625-009-262-532 价格&库存
很抱歉,暂时无法提供与“625-009-262-532”相匹配的价格&库存,您可以联系我们找货
  • 250+15.95869250+2.07216
