627-015-222-068
627-015-222-068
    627 SERIES VERTICAL METAL SHELL
627-015-222-068 数据手册
627/628 SERIES D-Sub Connectors: Vertical, Metal Body Features: • • • • • • • • • Standard and high profile insulator styles are available 0.109”(2.77mm) contact spacing x 0.112”(2.84mm) row spacing Plug and receptacle in 9, 15, 25, 37 or 50 contact sizes Pin and socket contact mating design with P.C. tail termination Metal shell provides EMI/RFI shielding, plug shell indents provide grounding and additional mating retention Grounding features include boardlock for exceptional retention to P.C. board Mounting options for panel mount or connector mating include through hole, threaded hole and threaded standoffs D-shaped connector mating outline provides polarization Design based on requirements of MIL-C-24038, EIA RS-232 and RS-449 Specifications: Insulator Material Thermoplastic polyester, UL 94V-0, chemical resistant, color: Black Contact Material Plug (pin): Brass Receptacle (socket): Brass Contact Plating Selective gold (see ordering code) over nickel for the mating area, tin plating for tail area Ferrite Specs: 20dB minimum @30 MHz, 30dB minimum @50 MHz, and 50dB minimum @100 MHz Shell Material Nickel plated steel (optional tin plating) Current Rating 3 amps - 5 amps Contact Resistance 25 milliohms maximum Insulation Resistance 1000 megaohms minimum Dielectric Withstanding Voltage 1000 V AC rms at Sea Level Operating Temperature -55°C To +85°C (upto +125°C for high temp) Insertion Force 16 oz (4.45 N) Maximum Per Contact Position Withdrawal Force 1 oz (0.28 N) Minimum Per Contact Position Ordering Code: 627-025-220-043 SERIES: 627: PLUG (PIN) 628: RECEPTACLE (SOCKET) NO. OF CONTACTS: 009 - 9 CONTACTS 025 - 25 CONTACTS 015 - 15 CONTACTS 037 - 37 CONTACTS 050 - 50 CONTACTS (STANDARD PROFILE & C&L ONLY) CONTACT FINISH CODE: 2 - GOLD FLASH PLATING 3 - 15µ" OF GOLD PLATING 6 - 30µ" OF GOLD PLATING CONTACT CODE: 20 - PCB TAIL STANDARD PROFILE INSULATOR 21 - PCB TAIL HIGH PROFILE INSULATOR: STANDARD LENGTH 22 - SOLDER CUP (STANDARD PROFILE ONLY) 28 - 0.110"(2.80mm) PC TAIL WITH FERRITE FILTER (STANDARD PROFILE ONLY) 41 - PCB TAIL HIGH PROFILE: ONLY AVAILABLE WITH 11.7mm BOARDLOCKS 51 - PCB TAIL HIGH PROFILE: ONLY AVAILABLE WITH 12.7mm BOARDLOCKS 61 - PCB TAIL HIGH PROFILE: ONLY AVAILABLE WITH 13.7mm BOARDLOCKS 71 - PCB TAIL HIGH PROFILE: ONLY AVAILABLE WITH 14.2mm BOARDLOCKS 81 - PCB TAIL HIGH PROFILE: ONLY AVAILABLE WITH 15.0mm BOARDLOCKS 91 - PCB TAIL HIGH PROFILE: ONLY AVAILABLE WITH 10.8mm BOARDLOCKS www.edac.net Contact P/N: Description: Wire Gauge (AWG): 627-290-001 On reel 24-28 60 pcs/strip 24-28 FLANGE MOUNTING OPTIONS: 627-290-001P60 1 - DIA.120"(DIA.3.05MM) THROUGH HOLE 2 - #4-40 THREADED CLINCH NUT (BOARDSIDE) 3 - #4-40 THREADED STANDOFF 6 - #4-40 THREADED HOLE WITH BOARDLOCKS (N/A FOR CRIMP & LOAD TERMINATION) 7 - #4-40 THREADED STANDOFF WITH BOARDLOCKS (N/A FOR CRIMP & LOAD TERMINATION) 8 - #4-40 THREADED CLINCH NUT (MATING SIDE) .236"(6.00mm) 9 - #4-40 THREADED CLINCH NUT (BOARDSIDE) .236"(6.00mm) INSULATOR STYLE: 4 - STANDARD PROFILE - STANDARD TEMP (N/A FOR CRIMP & LOAD TERMINATION) 5 - HIGH PROFILE - STANDARD TEMP 6 - STANDARD PROFILE - HIGH TEMP (N/A FOR CRIMP & LOAD TERMINATION) 7 - HIGH PROFILE - HIGH TEMP (N/A FOR CRIMP & LOAD TERMINATION) SHELL PLATING: 0 - NICKEL PLATED SHELL 2 - TIN PLATED SHELL TERMINATION: 010 - CRIMP AND LOAD (CABLE ASSEMBLY) Contact P/N: Description: Wire Gauge (AWG): 628-292-001 On reel 24-28 628-292-001P60 60 pcs/strip 24-28 customerservice@edac.net 627/628 SERIES D-Sub Connectors: Vertical, Metal Body HIGH PROFILE PLUG 627 SERIES HIGH PROFILE A B C 2.77±0.13 12.55±0.38 8.36±0.25 2.84 #4-40 1 2 9 3 10 4 5 11 12 6 13 7 14 8 15 C±0.13 PLUG NUMBER OF CONTACTS Inch (mm) Inch (mm) Inch (mm) 9 1.213 (30.81) .984 (24.99) .666 (16.92) 15 1.543 (39.19) 1.312 (33.32) .994 25 2.088 (53.04) 1.852 (47.04) 1.534 37 2.729 (69.32) 2.500 (63.50) 2.182 A±0.38 B±0.25 C±0.13 RECEPTACLE Inch (mm) .643 (16.33) (25.25) .971 (24.66) (38.96) 1.511 (38.38) (55.42) 2.159 (54.84) 0.60 10.90±0.25 2.84 10.80±0.25 1.60 3.50±0.25 TAIL LENGTH (WITH BOARDLOCK) TAIL LENGTH (WITHOUT BOARDLOCK) Ø3.20±0.1 SEE ORDERING GUIDE 1.0 MAX 0.5 MAX 6.00±0.25 1.385 RECEPTACLE 628 SERIES HIGH PROFILE A B C 2.84 B Ø1.10 2.77 2.77±0.13 #4-40 2-Ø3.20 12.55±0.38 7.90±0.13 2.84 1.385 RECOMMENDED P.C.B LAYOUT FOR PLUG AND RECEPTACLE www.edac.net 10.70±0.25 2.84 10.80±0.25 1.60 3.50±0.25 0.60 TAIL LENGTH (WITH BOARDLOCK) TAIL LENGTH (WITHOUT BOARDLOCK) Ø3.20±0.1 SEE ORDERING GUIDE 1.0 MAX 0.5 MAX 5.80±0.25 1.385 customerservice@edac.net 627/628 SERIES D-Sub Connectors: Vertical, Metal Body PLUG 627 SERIES A B C 4.0 REF 0.9 6.00 12.60 ? 3.20 REF 6.0±0.35 2.84 STANDARD PROFILE 8.36±0.15 #4-40 5.0 4.8±0.5 5.6 MAX 10° A B 1 0.90±0.3 12.60 6.0±0.35 3. 05 2.84 CRIMP TYPE 8.36±0.15 C 4.1 ? 10° 2X 11.0±0.25 RECEPTACLE 628 SERIES A B C 4.0 1.6 12.60 2.84 7.90±0.15 STANDARD PROFILE 0.9 6.0 6.0±0.35 1 ? 3.20 REF #4-40 4.8±0.5 5.6 MAX 10° A B 6.0±0.35 C 0.90±0.3 12.60 2.84 CRIMP TYPE 7.90±0.15 1 4.1 10° B±0.10 ? 1.05-PIN NUMBER 2.84 ? 3.05-2PLC 2.77 Recommended PCB Layout (Plug and Receptacle) www.edac.net NUMBER OF CONTACTS A±0.35 Inch (mm) 11.0±0.25 B±0.10 C±0.15 PLUG C±0.15 RECEPTACLE Inch (mm) .642 (16.30) (25.25) .970 (24.65) (38.96) 1.512 (38.40) (63.50) 2.182 (55.42) 2.157 (54.80) (61.00) 2.079 (52.80) 2.055 (52.20) Inch (mm) Inch (mm) 9 1.213 (30.80) .984 (24.99) .666 (16.92) 15 1.541 (39.15) 1.312 (33.32) .994 25 2.087 (53.00) 1.852 (47.04) 1.534 37 2.728 (69.30) 2.500 50 2.638 (67.00) 2.402 customerservice@edac.net
627-015-222-068
物料型号: - 627系列:插头(PIN) - 628系列:插座(SOCKET)
器件简介: - 提供标准和高轮廓绝缘体样式。 - 0.109英寸(2.77mm)接触间距x 0.112英寸(2.84mm)行间距。 - 插头和插座接触设计,带有PC尾端终止。 - 金属壳体提供EMI/RFI屏蔽。
引脚分配: - 9、15、25、37或50接触尺寸的插头和插座。
参数特性: - 绝缘体材料:热塑性聚酯,化学耐性,黑色。 - 接触材料:黄铜。 - 接触电镀:选择性金电镀覆盖镍,尾部区域锡电镀。 - 额定电流:3至5安培。 - 接触电阻:最大25毫欧姆。 - 绝缘电阻:最小1000兆欧姆。 - 介电强度:1000 V AC rms在海平面。
功能详解: - 基于MIL-C-24038、EIA RS-232和RS-449的要求设计。
应用信息: - 适用于需要EMI/RFI屏蔽和极化功能的垂直D-Sub连接器应用。
封装信息: - 提供多种安装选项,包括通孔、螺纹孔和螺纹支架。
627-015-222-068 价格&库存
很抱歉,暂时无法提供与“627-015-222-068”相匹配的价格&库存,您可以联系我们找货
    • 1+17.16120
    • 200+6.84720
    • 500+6.62040
    • 1000+6.51240
