629-M25-640-LT3
629-M25-640-LT3
    插件
    629M SERIES RIGHT ANGLE D-SUB PL
629-M25-640-LT3 数据手册
629M/630M SERIES Machined D-Sub Connectors: Right Angle, 0.370” (9.40mm) Footprint Features: • • • • • • • • • Two contact rows with 0.370”(9.40mm) footprint, right angle bend D-Sub with machined contacts 0.109”(2.77mm) contact spacing x 0.112”(2.84mm) row spacing Plug and receptacle in 9, 15, 25, 37 or 50 contact sizes Pin and socket contact mating design with P.C. tail termination Metal shell provides EMI/RFI shielding, plug shell indents provide grounding and additional mating retention Grounding features include brackets with boardlock for exceptional retention to P.C. board Mounting options for panel mount or connector mating include through hole, threaded inserts and threaded standoffs Insulation housings are offered in different colors: black, white, green and blue D-shaped connector mating outline provides polarization Specifications: Insulator Material PA6T, UL 94V-0, Color: Black, White, Blue or Green Contact Material Precision Machined Copper Alloy Contact Plating Gold Plating over Nickel All Over Shell Material Nickel Plated Steel (Optional Tin Plating) Current Rating 5 amps Contact Resistance 10 Milliohms maximum Dielectric Withstanding Voltage 5000 megaohms minimum Insulation Resistance 1000 V AC rms at Sea Level Operating Temperature -55°C To +125°C Ordering Code: 629-M25-240-BN3 SERIES: 629: PLUG (PIN) 630: RECEPTACLE (SOCKET) M: MACHINED CONTACTS NO. OF CONTACTS: 09 - 9 CONTACTS 25 - 25 CONTACTS 15 - 15 CONTACTS 37 - 37 CONTACTS 50 - 50 CONTACTS CONTACT FINISH CODE: 2 - GOLD FLASH PLATING 3 - 15 MICROINCHES OF GOLD PLATING 6 - 30 MICROINCHES OF GOLD PLATING CONTACT CODE: 40 - 0.370" (9.40MM) FOOTPRINT R/A PC TAIL www.edac.net MOUNTING & GROUNDING OPTIONS: 1 - Ø.120"(Ø3.05) THROUGH HOLE 2 - 4-40 UNC INSERT 3 - 4-40 UNC INSERT + STABILIZER PCB + BOARDLOCKS 4 - 4-40 UNC INSERT + STABILIZER PCB + Ø.126"(Ø3.20) HOLE 5 - 4-40 UNC STANDOFF + STABILIZER PCB + BOARDLOCKS 6 - 4-40 UNC STANDOFF + STABILIZER PCB + Ø.126"(Ø3.20) HOLE SHELL PLATING CODE: N - NICKEL T - TIN HOUSING MATERIAL CODE: B - BLACK W - WHITE G - GREEN L - BLUE customerservice@edac.net 629M/630M SERIES Machined D-Sub Connectors: Right Angle, 0.370” (9.40mm) Footprint MOUNTING & GROUNDING OPTIONS: CODE - 1 Ø3.05 THROUGH HOLE CODE - 3 #4-40 UNC INSERT + STABILIZER PCB + BOARDLOCKS www.edac.net CODE - 2 #4-40 UNC INSERT CODE - 4 #4-40 UNC INSERT + STABILIZER PCB + Ø3.20 HOLE customerservice@edac.net 629M/630M SERIES Machined D-Sub Connectors: Right Angle, 0.370” (9.40mm) Footprint MOUNTING & GROUNDING OPTIONS: CODE - 5 #4-40 UNC INSERT + STABILIZER PCB + BOARDLOCKS CODE - 6 #4-40 UNC INSERT + STABILIZER PCB + Ø3.20 HOLE RECOMMENDED PCB LAYOUT www.edac.net customerservice@edac.net
629-M25-640-LT3
物料型号为629M/630M系列,是直角D-Sub连接器,具有0.370”(9.40mm)的足迹。
这些连接器具有精密加工的接触点,接触点间距为0.109”(2.77mm),行间距为0.112”(2.84mm)。
插头和插座有9、15、25、37或50种接触尺寸可选。
接触点和插座接触采用PC尾端终止设计。
金属外壳提供EMI/RFI屏蔽,插头外壳的凹槽提供接地和额外的配对保持力。
引脚分配参数特性如下: - 绝缘体材料:PA6T, UL 94V-0,颜色:黑色、白色、蓝色或绿色 - 接触材料:精密加工的铜合金 - 接触镀层:全覆盖镍上镀金 - 外壳材料:镀镍钢(可选锡镀层) - 电流额定值:5安培 - 接触电阻:最大10毫欧姆 - 介质耐电压:最小5000兆欧 - 绝缘电阻:在海平面1000V AC rms - 工作温度:-55°C至+125°C
功能详解应用信息包括: - 提供EMI/RFI屏蔽 - 插头外壳凹槽提供接地和额外的配对保持力 - 不同颜色的绝缘体,D形连接器配对轮廓提供极化
封装信息包括: - 订购代码:629-M25-240-BN3 - 安装和接地选项:包括通孔、螺纹嵌入件和螺纹立杆等
此外,文档还提供了不同接触点数量的尺寸信息和推荐的PCB布局。
629-M25-640-LT3 价格&库存
很抱歉,暂时无法提供与“629-M25-640-LT3”相匹配的价格&库存,您可以联系我们找货
629-M25-640-LT3
  • 500+117.48660500+15.15608
