632 SERIES
D-Sub Connectors: Right Angle, High Density, 0.121” (3.08mm) Footprint
Features:
High density three contact rows with 0.121”(3.08mm) footprint, right angle bend
0.090”(2.29mm) contact spacing X 0.078”(1.98mm) row spacing
Receptacle in 15 contact size
Pin and socket contact mating design with P.C. tail termination
Metal shell provides EMI/RFI shielding
Board mounting features include two prong boardlock for exceptional retention to P.C. board
Flange mounting options for panel mount or connector mating include through hole, threaded hole
and threaded standoffs
D-shaped connector mating outline provides polarization
Design based on requirements of MIL-C-24038, EIA RS-232 and RS-44
Specifications:
Insulator Material
Thermoplastic Polyester, UL 94V-0, Chemical Resistant, Color: Black
Contact Material
Brass
Contact Plating
Selective Gold (See Ordering Code) over Nickel for the Mating Area, Tin Plating for Tail Area
Shell Material
Nickel Plated Steel
Current Rating
3 amps
Contact Resistance
25 Milliohms maximum
Insulation Resistance
5000 megaohms minimum
Dielectric Withstanding Voltage
1000 V AC rms at Sea Level
Operating Temperature
-55°C To +85°C (upto +125°C for high temp)
Insertion Force
211.6 oz (58.8 N) maximum
Withdrawal Force
42.3 oz (11.8 N) minimum
Ordering Code:
632-015-266-033
SERIES:
632: RECEPTACLE (SOCKET)
NO. OF CONTACTS:
015 - 15 CONTACTS
FLANGE MOUNTING OPTIONS
FLANGE MOUNTING OPTIONS:
1 - Ø.120" (Ø3.05MM) THROUGH HOLE
2 - #4-40 THREADED HOLE
3 - #4-40 THREADED STANDOFF
5 - M3 THREADED HOLE
CONTACT FINISH CODE:
2 - GOLD FLASH PLATING
3 - 15 MICROINCHES OF GOLD PLATING
6 - 30 MICROINCHES OF GOLD PLATING
BOARD MOUNTING FEATURE:
3 - TWO PRONG BOARDLOCKS
CONTACT CODE:
66 - .121" (3.08MM) FOOTPRINT CONTACT
74 - 9TH PIN CONTACT RECESSED, BLUE INSULATOR
MATERIAL CODE:
0 - STANDARD
5 - HIGH TEMP INSULATOR
www.edac.net
customerservice@edac.net
632 SERIES
RECEPTACLE
632 SERIES
5
1
10
15
11
3.18±0.38
SEE FLANGE
MOUNTING
OPTIONS
6
3.80
12.55±0.38
7.90±0.13
3.96
30.81±0.38
24.99±0.25
16.33±0.13
2.290
0.25
3.96±0.25
24.99
2-Ø3.20
1.145
2.29
15-Ø1.09
1.98
1.98
0.25
2.29
1.145
P.C.B. EDGE
3.08
5.06
14.85±0.25
6.00
5.06±0.25
3.08±0.25
RECOMMENDED P.C.B. LAYOUT
www.edac.net
很抱歉,暂时无法提供与“632-015-366-035”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 5000+25.230595000+3.26300
