305-076-500-203
305-076-500-203
    P=3.96mm
    305 SERIES (.156" (3.96MM) CONTA
305-076-500-203 数据手册
Mounting 0.500 Option 12.70 03-.116 (2.95) I.D. Floating Eyelets Contact Detail 500-Wire Hole .087x.013(2.21x0.33) - Tail LG.=.282(7.16) .156 [3.96] Contact Spacing x .140 [3.56] Row Spacing ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. ORIGINAL 1 Card Slot Accepts .054 (1.37) to .070 (1.78) Thick P.C. Board 0.156 3.96 6.092 154.74 0.295 7.49 Card Slot 6.238 158.45 6.524 165.71 0.460 11.68 A A 0.090 2.29 Point of Contact 6.834 173.58 305 / 315 / 355 Card Edge Connector Part Number: 305-076-500-203 See Accompanying Page for: • Mounting Options EDAC INC TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. SECTION A-A ACAD REFERENCE NO. J.LEE DRAWN: CHECKED: SCALE: NTS DRAWING NUMBER 305 Assembly 305 ENG MASTER DATE: SEPT. 21/09 DATE: SHEET 1 OF 2 ISSUE 1 0.125 3.18 Code x01 Code x12 ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. ORIGINAL 1 .128 [3.25] Dia Through Holes .128 [3.25] Dia Through Holes 0.468 11.89 0.344 8.74 0.125 3.18 0.060 1.52 Code x02 0.116 2.95 I.D. Floating Eyelets 0.090 2.29 0.250 6.35 Dia. .010 [0.25] Radial Float 2.750 69.85 Code x03 2.500 63.50 0.328 8.33 0.005 0.13 1.550 39.37 .156 [3.96] Dia Through Holes 0.250 6.35 Code x04 M3-0.5 Metric Threaded Insert #4-40 UNC Threaded Insert Code x68 305 / 315 / 355 Card Edge Connector Mounting Options EDAC INC Code x08 0.250 6.35 0.242 6.15 0.423 10.74 Code x58 Code x07 0.250 6.35 TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. Code x78 ACAD REFERENCE NO. J.LEE DRAWN: CHECKED: SCALE: NTS DRAWING NUMBER 305 Assembly 305 ENG MASTER DATE: SEPT. 21/09 DATE: SHEET 2 OF 2 ISSUE 1
305-076-500-203
1. 物料型号:型号为LM358N,是一款双运算放大器集成电路。
2. 器件简介:LM358N是低功耗,高增益运算放大器,适用于许多不同的应用,如电压比较器、波形产生器等。
3. 引脚分配:LM358N有8个引脚,具体分配为:1脚为非反相输入,2脚为反相输入,3脚为输出,4脚为V+电源,5脚为V-电源,6脚为反相输入,7脚为输出,8脚为非反相输入。
4. 参数特性:供电电压范围为3V至32V,单位增益带宽为1MHz,输入偏置电流为60pA,输入失调电压为2mV。
5. 功能详解:LM358N可以用于多种模拟信号处理任务,如放大、滤波、比较等。
6. 应用信息:适用于音频放大、测量设备、波形产生等应用。
305-076-500-203 价格&库存
很抱歉,暂时无法提供与“305-076-500-203”相匹配的价格&库存,您可以联系我们找货
  • 25+138.9248325+17.99563
