627W9W4-624-4ND
627W9W4-624-4ND
    CONN D-SUB PLUG 9P PNL MNT SLDR
627W9W4-624-4ND 数据手册
627WC/628WC SERIES Waterproof D-Sub Connectors: Power Combo, Vertical Features: • • • • • • • Signal, along with power or coaxial contacts within one connector Space saving on the PCB and I/O designs Available in various pin out configurations Pin and socket contact mating design with P.C. tail and solder cup termination Metal shell provides EMI/RFI shielding, plug shell indents provide grounding and additional mating retention Mounting options for panel mount or connector mating include through hole, threaded hole and threaded standoffs D-shaped connector mating outline provides polarization Specifications: Power Only Insulator Material PBT+30% GF, UL 94V-0, Color: Black Contact Material Copper Alloy Contact Plating Selective Gold (See Ordering Code) over Nickel Shell Material and Plating Steel with Ni or Tin Plating Sealing compound Epoxy O-ring Material Silicone Current Rating (Power Contacts) 10 amps, 20 amps, 30 amps, 40 amps Current Rating (Signal Contacts) Combination 5 amps Voltage Rating 125 V Contact Resistance (Power Contacts) 1 Milliohms maximum Contact Resistance (Signal Contacts) 10 Milliohms maximum Insulation Resistance 5000 megaohms minimum Dielectric Withstanding Voltage 1000 V AC rms at Sea Level Operating Temperature -25°C To +85°C Mating Cycle 500 For 30 Microinches Gold Plating, 50 For Gold Flash Plating IP Rating IP67 Ordering Code: 627W2W2-222-1N2 SERIES: 627: PLUG (PIN) 628: RECEPTACLE (SOCKET) MOUNTING OPTIONS: 2 - #4-40 UNC THREADED HOLE 5 - #4-40 UNC THREADED HOLE WITH BOARDLOCKS A - M3 THREADED HOLE D - M3 THREADED HOLE WITH BOARDLOCKS CONNECTOR TYPE: W - WATERPROOF LAYOUT: POWER ONLY COMBINATION 2W2 2WK2 5W1 SIZE 15 CONTACT SHELL 3W3 3WK3 7W2 11W1 SIZE 25 CONTACT SHELL 5W5 9W4 13W3 17W2 21W1 SIZE 9 CONTACT SHELL 8W8 TOTAL NO.OF POWER TOTAL NO.OF CONTACT 2WK2 MALE FEMALE COMBINATION CONTACT PLATING THICKNESS: 2 - GOLD FLASH PLATING 1 - 5 MICROINCHES OF GOLD PLATING 3 - 15 MICROINCHES OF GOLD PLATING 6 - 30 MICROINCHES OF GOLD PLATING TAIL TYPE: 22 - SOLDER CUP 24 - PC TAIL www.edac.net SHELL PLATING: N - NICKEL T - TIN CURRENT RATING: 1 - 10A 2 - 20A 3 - 30A 4 - 40A customerservice@edac.net 627WC/628WC SERIES Waterproof D-Sub Connectors: Power Combo, Vertical Layout: SHELL SIZE LAYOUT 1(E) 2(A) 3WK3(FEMALE) 3(B) 3WK3(MALE) 5W1 2W2 2WK2(FEMALE) 2WK2(MALE) 3W3 7W2 11W1 9W4 5W5 13W3 21W1 17W2 Straight PCB Power Contacts: STRAIGHT PCB SOLDER POWER CONTACTS MALE FEMALE 17.10 16.90 5.30 ØA Ø3.6 CURRENT RATING 10A 20A 30A 40A www.edac.net 5.30 ØA Ø5.50 Ø5.50 DIMENSION (mm) ØA 1.7 2.8 3.2 3.75 customerservice@edac.net 627WC/628WC SERIES Waterproof D-Sub Connectors: Power Combo, Vertical Current Rating: D(mm): www.edac.net 10A 2.2 20A 3.3 30A 3.7 40A 4.2 customerservice@edac.net 627WC/628WC SERIES Power Combo D-Sub Connectors: Vertical Solder Cup Power Contacts: Solder Cup Power Contacts: SOLDER CUP POWER CONTACTS MALE FEMALE 21.80 21.80 10.20 10.20 ØA ØB Ø3.60 CURRENT RATING 10A 20A 30A 40A ØA ØB Ø5.50 DIMENSION (mm) ØA 1.7 2.7 3.5 4.6 Ø5.50 DIMENSION (mm) ØB 2.5 3.6 4.4 5.5 Mouting options: #4-40 UNC THREADED HOLE CODE: 2 M3 THREADED HOLE CODE: A www.edac.net #4-40 UNC THREADED HOLE WITH BOARDLOCKS CODE: 5 M3 THREADED HOLE WITH BOARDLOCKS CODE: D customerservice@edac.net
627W9W4-624-4ND
1. 物料型号:文档中提供了连接器的型号,例如627W2W2-222-1N2,其中627代表插头,628代表插座。
2. 器件简介:这些连接器具有防水功能,适用于垂直安装,可以同时传输信号、电源或同轴接触。
3. 引脚分配:文档列出了不同尺寸的壳体布局,例如1(E)、2(A)、3(B)等,以及相应的引脚配置。
4. 参数特性:包括绝缘材料、接触材料、接触镀层、壳体材料和镀层、密封化合物、O型圈材料等。
5. 功能详解:连接器具有EMI/RFI屏蔽功能,金属壳体提供接地和额外的配对保持力。
6. 应用信息:适用于需要防水和节省空间的应用场景。
7. 封装信息:提供了多种安装选项,包括通孔、带板锁的#4-40 UNC螺纹孔和M3螺纹孔。
627W9W4-624-4ND 价格&库存
很抱歉,暂时无法提供与“627W9W4-624-4ND”相匹配的价格&库存,您可以联系我们找货
