633-062-663-040
633-062-663-040
    633 SERIES RIGHT ANGLE D-SUB PLU
633-062-663-040 数据手册
633/634 SERIES D-Sub Connectors: Right Angle, High Density, 0.350” (8.89mm) Footprint Features: • • • • • • • • • • High density three contact rows with 0.350”(8.89mm) footprint, right angle bend Standard contact spacing and row spacing Optional 9th pin recessed on 15 contact size in accordance with VESA Display Data Channel standard Plug and receptacle in 15, 26, 44, 62 or 78 contact sizes Pin and socket contact mating design with P.C. tail termination Metal shell provides EMI/RFI shielding, plug shell indents provide grounding and additional mating retention Board mounting features include threaded hole, two or four prong boardlock for exceptional retention to P.C. board Flange mounting options for panel mount or connector mating include through hole, threaded holes and threaded standoffs D-shaped connector mating outline provides polarization Design based on requirements of MIL-C-24038, EIA RS-232 and RS-449 Specifications: Insulator Material Thermoplastic Polyester, UL 94V-0, Chemical Resistant Contact Material Plug (Pins): Copper Alloy Receptacle (Socket): Copper Alloy Contact Plating Selective Gold (See Ordering Code) over Nickel for the Mating Area, Tin Plating for Tail Area Shell Material Nickel Plated Steel Current Rating 3 amps Contact Resistance 25 Milliohms maximum Insulation Resistance 5000 megaohms minimum Dielectric Withstanding Voltage 1000 V AC rms at Sea Level Operating Temperature -55°C To +85°C (upto +125°C for high temp) Insertion Force 16 oz (4.45 N) Maximum Per Contact Position Withdrawal Force 1 oz (0.28 N) Minimum Per Contact Position Ordering Code: 634-015-263-032 SERIES: 633: PLUG (PIN) 634: RECEPTACLE (SOCKET) NO. OF CONTACTS: 015 - 15 CONTACTS 026 - 26 CONTACTS 044 - 44 CONTACTS 062 - 62 CONTACTS 078 - 78 CONTACTS CONTACT FINISH CODE: 2 - GOLD FLASH PLATING 3 - 15 MICROINCHES OF GOLD PLATING 6 - 30 MICROINCHES OF GOLD PLATING CONTACT CODE: 63 - STANDARD CONTACT 74 - 9TH PIN CONTACT RECESSED FOR 15-PIN, BLUE INSULATOR (RECEPTACLE ONLY) www.edac.net FLANGE MOUNTING OPTIONS FLANGE MOUNTING OPTIONS: 0 - #4-40 THREADED FIXED STANDOFF 1 - Ø.120"(Ø3.05MM) THROUGH HOLE 2 - #4-40 THREADED HOLE 3 - #4-40 THREADED STANDOFF 5 - M3 THREADED HOLE BOARD MOUNTING FEATURE: 1 - Ø.120"(Ø3.05MM) THROUGH HOLE 3 - TWO PRONG BOARDLOCKS 4 - FOUR PRONG BOARDLOCKS 5 - #4-40 THREADED HOLE (78 CONTACTS ONLY AVAILABLE WITH TWO PRONG BOARDLOCKS) MATERIAL CODE: 0 - STANDARD 5 - HIGH TEMP INSULATOR customerservice@edac.net 633/634 SERIES D-Sub Connectors: Right Angle, High Density, 0.350” (8.89mm) Footprint PLUG 633 SERIES (15 TO 62 PINS) A B C D 22.10±0.38 6.00±0.25 12.55±0.38 8.36±0.13 3.960 SEE FLANGE MOUNTING OPTIONS 8.89±0.25 FOOTPRINT 3.18±0.38 E B Ø1.10 D NUMBER OF CONTACTS A±0.38 Inch D 2.54±0.25 2.54±0.25 E (mm) 8.89 E 11.43 16.10±0.25 11.43±0.25 5.08 2-Ø3.20 P.C.B EDGE RECOMMENDED P.C.B LAYOUT D±0.13 C±0.13 B±0.25 E±0.25 Inch (mm) Inch (mm) Inch (mm) Inch (mm) 15 1.213 (30.81) .984 (24.99) .666 (16.92) .090 (2.29) .010 (0.25) 26 1.543 (39.19) 1.312 (33.32) .994 (25.25) .090 (2.29) .020 (0.51) 44 2.088 (53.04) 1.852 (47.04) 1.534 (38.96) .090 (2.29) .020 (0.51) 62 2.729 (69.32) 2.500 (63.50) 2.182 (55.42) .095 (2.41) .023 (0.58) PLUG 633 SERIES (78 PINS) 2.54 2.42 1.21 61.10 1 20 21 39 60 78 6.10±0.25 2.54 2.54 8.89±0.25 FOOTPRINT RECOMMENDED P.C.B. LAYOUT 3.18±0.38 2.54 8.89 59 P.C.B. EDGE 2.54 12.70±0.25 17.70±0.25 11.30±0.25 2.08±0.13 12.70 40 2.54 1.21 2-Ø3.20 15.40±0.38 SEE FLANGE MOUNTING OPTIONS 78-Ø1.10 67.00±0.38 61.10±0.25 52.80±0.25 2.42±0.13 633/634 SERIES D-Sub Connectors: Right Angle, High Density, 0.350” (8.89mm) Footprint RECEPTACLE 634 SERIES (15 TO 62 PINS) A B C D 22.10±0.38 6.00±0.25 E 3.18±0.38 3.7 2.1 12.55±0.38 7.90±0.13 3.960 SEE FLANGE MOUNTING OPTIONS 8.89±0.25 FOOTPRINT 3.70 B Ø1.10 5.08 16.10±0.25 11.43±0.25 2-Ø3.20 D NUMBER OF CONTACTS A±0.38 Inch (mm) D 2.54±0.25 2.54±0.25 E 8.89 11.43 E P.C.B EDGE RECOMMENDED P.C.B LAYOUT D±0.13 C±0.13 B±0.25 E±0.25 Inch (mm) Inch (mm) Inch (mm) Inch (mm) .090 (2.29) .010 (0.25) 15 1.213 (30.81) .984 (24.99) .643 (16.33) 26 1.543 (39.19) 1.312 (33.32) .971 (24.66) .090 (2.29) .020 (0.51) 44 2.088 (53.04) 1.852 (47.04) 1.511 (38.38) .090 (2.29) .020 (0.51) 62 2.729 (69.32) 2.500 (63.50) 2.159 (54.84 .095 (2.41) .023 (0.58) RECEPTACLE 634 SERIES (78 PINS) 78-Ø1.10 1 20 21 39 60 78 6.00±0.25 2.54 2.54 8.89±0.25 FOOTPRINT RECOMMENDED P.C.B. LAYOUT 2.54 8.89 11.43 11.43±0.25 59 P.C.B. EDGE 2.54 10.90±0.25 2.08±0.13 2.54 2-Ø3.20 61.10 40 17.70±0.25 www.edac.net 2.42 1.21 2.54 1.21 67.00±0.38 61.10±0.25 52.20±0.25 2.42±0.13 15.40±0.38 SEE FLANGE MOUNTING OPTIONS 3.30±0.38 customerservice@edac.net
633-062-663-040
物料型号:633系列为插头(PIN),634系列为插座(SOCKET)。
器件简介:这些连接器是直角、高密度的D-Sub连接器,具有0.350英寸(8.89mm)的尺寸,适用于多种接触点尺寸,包括15、26、44、62或78个接触点。
引脚分配:文档提供了详细的引脚分配图和推荐PCB布局。
参数特性:包括绝缘材料、接触材料、接触镀层、壳体材料、电流额定值、接触电阻、绝缘电阻、介电强度、操作温度范围、插入力和拔出力等。
功能详解:文档描述了金属壳体提供EMI/RFI屏蔽,插头壳体凹槽提供接地和额外的配对保持力。
应用信息:设计基于MIL-C-24038、EIA RS-232和RS-449的要求。
封装信息:包括法兰安装选项,如通孔、螺纹孔和螺纹支架。
订购代码:提供了订购代码的详细说明,包括接触点数量、接触点镀层、板载安装特性、材料代码和接触点代码。
633-062-663-040 价格&库存
很抱歉,暂时无法提供与“633-062-663-040”相匹配的价格&库存,您可以联系我们找货
    • 50+118.7968950+15.37498
