846-094-560-208
846-094-560-208
    94 位置 母头 连接器 非指定 - 双边 镀金 0.125"(3.18mm) 绿色
846-094-560-208 数据手册
Contact Dimensions: 560-Extender Board Bend (Code 523 Contacts) See Sheet 2 for Contact Code 555, 556, 558, 559, 560 Dimensions ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. ORIGINAL 1 6.160 156.46 6.000 152.4 .370 9.4 Card Slot Accepts .054 [1.37] to .070 [1.78] Thick P.C. Board .330 8.38 Card Slot .160 4.07 Point of Contact .600 15.24 • • • INSULATOR MATERIAL: THERMOPLASTIC POLYESTER, UL 94V-0 CONTACT MATERIAL; COPPER, NICKEL, TIN ALLOY CA-725 CONTACT PLATING: GOLD ON THE MATING AREA, TIN-LEAD ON THE CONTACT TAILS, NICKEL UNDERPLATE 846/896 SERIES HIGH TEMP CARD EDGE CONNECTOR PART NUMBER: 846-094-560-208 EDAC INC TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. ACAD REFERENCE NO. DRAWN: J.LEE DATE: CHECKED: SCALE: 846-ENG-MASTER DATE: APR. 22/09 1:1 DRAWING NUMBER 846-ENG-MASTER SHEET 1 OF 2 ISSUE 1 ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. .170 4.33 .245 6.22 .125(3.18) to .210(5.33) Outside Tails .125(3.18) to .210(5.33) Outside Tails .045(1.14) to .060(1.52) Between Tails .125(3.18) to .210(5.33) Outside Tails Contact Code 555 Contact Code 556 .060 1.52 .060 1.52 • • • .260 6.6 .660 16.76 .660 16.76 INSULATOR MATERIAL: THERMOPLASTIC POLYESTER, UL 94V-0 CONTACT MATERIAL; COPPER, NICKEL, TIN ALLOY CA-725 CONTACT PLATING: GOLD ON THE MATING AREA, TIN-LEAD ON THE CONTACT TAILS, NICKEL UNDERPLATE .165 4.19 .150 3.81 .200 5.08 .210 5.33 1 .095 2.41 .120 3.05 Contact Code 558 ORIGINAL .375 9.54 .125(3.18) to .210(5.33) Outside Tails .125(3.18) to .210(5.33) Outside Tails Contact Code 559 Contact Code 560 846/896 SERIES HIGH TEMP CARD EDGE CONNECTOR CONTACT CODE 555,556,558,559,560 DIMENSIONS EDAC INC TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. ACAD REFERENCE NO. DRAWN: J.LEE DATE: CHECKED: SCALE: 846-ENG-MASTER DATE: APR. 22/09 1:1 DRAWING NUMBER 846-ENG-MASTER SHEET 2 OF 2 ISSUE 1
846-094-560-208 价格&库存
很抱歉,暂时无法提供与“846-094-560-208”相匹配的价格&库存,您可以联系我们找货
