305-036-556-203
305-036-556-203
    305 SERIES (.156" (3.96MM) CONTA
305-036-556-203 数据手册
Mounting Option 03-.116 (2.95) I.D. Floating Eyelets Contact Detail 556-Extender Board Bend (Code 520 Contacts) .156 [3.96] Contact Spacing x .140 [3.56] Row Spacing ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. ORIGINAL 1 0.343 8.71 Card Slot Accepts .054 (1.37) to .070 (1.78) Thick P.C. Board 0.156 3.96 2.972 75.49 3.118 79.20 0.295 7.49 Card Slot 3.404 86.46 0.460 11.68 A A 0.090 2.29 Point of Contact 3.714 94.34 305 / 315 / 355 Card Edge Connector Part Number: 305-036-556-203 See Accompanying Page for: • Mounting Options EDAC INC TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. SECTION A-A ACAD REFERENCE NO. J.LEE DRAWN: CHECKED: SCALE: NTS DRAWING NUMBER 305 Assembly 305 ENG MASTER DATE: SEPT. 21/09 DATE: SHEET 1 OF 2 ISSUE 1 0.125 3.18 Code x01 Code x12 ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. ORIGINAL 1 .128 [3.25] Dia Through Holes .128 [3.25] Dia Through Holes 0.468 11.89 0.344 8.74 0.125 3.18 0.060 1.52 Code x02 0.116 2.95 I.D. Floating Eyelets 0.090 2.29 0.250 6.35 Dia. .010 [0.25] Radial Float 2.750 69.85 Code x03 2.500 63.50 0.328 8.33 0.005 0.13 1.550 39.37 .156 [3.96] Dia Through Holes 0.250 6.35 Code x04 M3-0.5 Metric Threaded Insert #4-40 UNC Threaded Insert Code x68 305 / 315 / 355 Card Edge Connector Mounting Options EDAC INC Code x08 0.250 6.35 0.242 6.15 0.423 10.74 Code x58 Code x07 0.250 6.35 TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. Code x78 ACAD REFERENCE NO. J.LEE DRAWN: CHECKED: SCALE: NTS DRAWING NUMBER 305 Assembly 305 ENG MASTER DATE: SEPT. 21/09 DATE: SHEET 2 OF 2 ISSUE 1
305-036-556-203
物料型号:ATMEGA16U2-AU 器件简介:ATMEGA16U2-AU是一款低功耗,高性能的8位AVR增强型微控制器,具有16KB的可编程Flash存储器,1KB的EEPROM,512字节的SRAM,32个通用I/O引脚,32个通用工作寄存器,全静态操作。 引脚分配:ATMEGA16U2-AU有44个引脚,包括电源引脚、地引脚、复位引脚、晶振引脚、I/O引脚等。 参数特性:工作电压范围1.8-5.5V,工作频率12MHz,I/O口可承受最大电压5.5V。 功能详解:ATMEGA16U2-AU具有多种功能,包括通用同步异步收发器(USART),模数转换器(ADC),定时器/计数器,中断,SPI,TWI等。 应用信息:该芯片广泛应用于键盘,鼠标,打印机,游戏手柄等USB设备。 封装信息:ATMEGA16U2-AU采用TQFP44封装。
305-036-556-203 价格&库存
很抱歉,暂时无法提供与“305-036-556-203”相匹配的价格&库存,您可以联系我们找货
  • 25+107.9625125+13.84837
