电子发烧友
开通电子发烧友VIP会员 尊享10大特权
海量资料免费下载
精品直播免费看
优质内容免费畅学
课程9折专享价
626-009-362-041
    626 SERIES RIGHT ANGLE D-SUB REC
626-009-362-041 数据手册
625/626 SERIES D-Sub Connectors: Right Angle, 0.584” (14.84mm) Footprint Features: • • • • • • • • • Two contact rows with 0.584”(14.84mm) footprint, right angle bend 0.109”(2.77mm) contact spacing X 0.112”(2.84mm) row spacing Plug and receptacle in 9, 15, 25, or 37 contact sizes Pin and socket contact mating design with P.C. tail termination Metal shell provides EMI/RFI shielding, plug shell indents provide grounding and additional mating retention Board mounting features include threaded hole, two and three prong boardlock for superior retention to P.C. board Flange mounting options for panel mount or connector mating include through hole, threaded hole and threaded standoffs D-shaped connector mating outline provides polarization Design based on requirements of MIL-C-24038, EIA RS-232 and RS-449 Specifications: Insulator Material Thermoplastic Polyester, UL 94V-0, Chemical Resistant, Color: Black Contact Material Plug (Pins): Copper Alloy Receptacle (Socket): Copper Alloy Contact Plating Selective Gold (See Ordering Code) over Nickel for the Mating Area, Tin Plating for Tail Area Shell Material Nickel Plated Steel Current Rating 3 amps Contact Resistance 25 Milliohms maximum Insulation Resistance 5000 megaohms minimum Dielectric Withstanding Voltage 1000 V AC rms at Sea Level Operating Temperature -55°C To +85°C (upto +125°C for high temp) Insertion Force 16 oz (4.45 N) Maximum Per Contact Position Withdrawal Force 1 oz (0.28 N) Minimum Per Contact Position Ordering Code: FLANGE MOUNTING OPTIONS 625-037-262-043 SERIES: 625: PLUG (PIN) 626: RECEPTACLE (SOCKET) NO. OF CONTACTS: 009 - 9 CONTACTS 025 - 25 CONTACTS 015 - 15 CONTACTS 037 - 37 CONTACTS CONTACT FINISH CODE: 2 - GOLD FLASH PLATING 3 - 15 MICROINCHES OF GOLD PLATING 6 - 30 MICROINCHES OF GOLD PLATING CONTACT CODE: 62 - .584" (14.84MM) FOOTPRINT CONTACT www.edac.net FLANGE MOUNTING OPTIONS: 0 - #4-40 THREADED FIXED STANDOFF 1 - Ø.120"(Ø3.05MM) THROUGH HOLE 2 - #4-40 THREADED HOLE 3 - #4-40 THREADED STANDOFF 5 - M3 THREADED HOLE BOARD MOUNTING FEATURE: 1 - Ø.120"(Ø3.05MM) THROUGH HOLE 3 - TWO PRONG BOARDLOCKS 4 - THREE PRONG BOARDLOCKS INSULATOR MATERIAL CODE: 0 - STANDARD 5 - HIGH TEMP INSULATOR customerservice@edac.net 625/626 SERIES D-Sub Connectors: Right Angle, 0.584” (14.84mm) Footprint PLUG #4-40 UNC/M3 15-Ø1.10 2.77±0.13 2.84 A B C 2.77±0.13 2-Ø3.20 8.00 14.84 12.55±0.38 8.36±0.13 2.84 1.385 P.C.B EDGE 1.385 6.00±0.25 8.00±0.25 2.84 19.16±0.25 12.45 14.84±0.25 RECOMMENDED P.C.B LAYOUT (FOR PLUG AND RECEPTACLE) 3.18±0.38 RECEPTACLE A B C 2.77±0.13 12.55±0.38 7.90±0.13 2.84 #4-40 UNC/M3 5.80±0.25 8.00±0.25 2.84 19.16±0.25 12.45 14.84±0.25 1.385 NUMBER OF CONTACTS www.edac.net A±0.38 Inch B±0.25 3.18±0.38 C±0.13 PLUG C±0.13 RECEPTACLE Inch (mm) Inch (mm) Inch (mm) 9 1.213 (30.81) .984 (24.99) .666 (16.92) .643 (16.33) 15 1.543 (39.19) 1.312 (33.32) .994 (25.25) .971 (24.66) 25 2.088 (53.04) 1.852 (47.04) 1.534 (38.96) 1.511 (38.38) 37 2.729 (69.32) 2.500 (63.50) 2.182 (55.42) 2.159 (54.84) (mm) customerservice@edac.net
626-009-362-041 价格&库存
很抱歉,暂时无法提供与“626-009-362-041”相匹配的价格&库存,您可以联系我们找货
