630-W09-640-015
630-W09-640-015
    弯插
    630W (WATERPROOF) SERIES RIGHT A
630-W09-640-015 数据手册
629W/630W SERIES Waterproof D-Sub Connectors: Right Angle Features: • • • • • • • • 0.109”(2.77mm) contact spacing x 0.112”(2.82mm) row spacing Plug and receptacle in 9, 15, or 25 contact sizes Pin and socket contact mating design with right angle P.C. tail termination. Plug shell indents provide grounding and additional mating retention Grounding features include two prong boardlock for exceptional retention to P.C. board Mounting options for panel mount or connector mating include threaded inserts or threaded standoffs D-shaped connector mating outline provides polarization Degree of protection: IP67 as per IEC60529 Specifications: Insulator Material PBT Thermoplastic with 30% Glass Filled, UL 94V-0 Rated, Black color Contact Material Pins and Sockets: Copper Alloy Contact Plating Gold Plating over Nickel underplating Shell Material Nickel Plated Steel Epoxy Sealant Epoxy O-Ring Silicone Current Rating 5 amps Contact Resistance 10 Milliohms maximum Dielectric Withstanding Voltage 5000 megaohms minimum Insulation Resistance 1000 V AC rms at Sea Level Operating Temperature -25°C To +85°C Ordering Code: 629-W09-240-015 SERIES: PLUG, 10.3 [0.406], FOOTPRINT . . . . 629 RECEPTACLE, 10.3 [0.406] FOOTPRINT . . . . 630 EDAC CODE: WATERPROOF . . . . W NO. OF CONTACTS: 9 CONTACT PINS . . . . 09 15 CONTACT PINS . . . . 15 25 CONTACT PINS . . . . 25 CONTACT PLATING: GOLD FLASH OVER NICKEL . . . . 2 15µ" GOLD OVER NICKEL . . . . 3 30µ" GOLD OVER NICKEL . . . . 6 www.edac.net MOUNTING OPTION: 2 . . . . #4-40 UNC THREADED HOLE 5 . . . . BRACKET #4-40 UNC WITHOUT BOARDLOCKS NOTE:ALL CONNECTORS ARE SHIPPED WITH #4-40 UNC HEXAGON SCREWS (PACKED SEPARATELY) SHELL OPTIONS: 1 . . . . NICKEL PLATED INSULATOR COLOR: 0 . . . . BLACK CONTACT CODE: 40 . . . . RIGHT ANGLE TAIL, 10.3 [0.405] FOOTPRINT (9.4 NODE) customerservice@edac.net
630-W09-640-015 价格&库存
很抱歉,暂时无法提供与“630-W09-640-015”相匹配的价格&库存,您可以联系我们找货
