电子发烧友
开通电子发烧友VIP会员 尊享10大特权
海量资料免费下载
精品直播免费看
优质内容免费畅学
课程9折专享价
633-044-263-515
    633 SERIES RIGHT ANGLE D-SUB PLU
633-044-263-515 数据手册
633/634 SERIES D-Sub Connectors: Right Angle, High Density, 0.350” (8.89mm) Footprint Features: • • • • • • • • • • High density three contact rows with 0.350”(8.89mm) footprint, right angle bend Standard contact spacing and row spacing Optional 9th pin recessed on 15 contact size in accordance with VESA Display Data Channel standard Plug and receptacle in 15, 26, 44, 62 or 78 contact sizes Pin and socket contact mating design with P.C. tail termination Metal shell provides EMI/RFI shielding, plug shell indents provide grounding and additional mating retention Board mounting features include threaded hole, two or four prong boardlock for exceptional retention to P.C. board Flange mounting options for panel mount or connector mating include through hole, threaded holes and threaded standoffs D-shaped connector mating outline provides polarization Design based on requirements of MIL-C-24038, EIA RS-232 and RS-449 Specifications: Insulator Material Thermoplastic Polyester, UL 94V-0, Chemical Resistant Contact Material Plug (Pins): Copper Alloy Receptacle (Socket): Copper Alloy Contact Plating Selective Gold (See Ordering Code) over Nickel for the Mating Area, Tin Plating for Tail Area Shell Material Nickel Plated Steel Current Rating 3 amps Contact Resistance 25 Milliohms maximum Insulation Resistance 5000 megaohms minimum Dielectric Withstanding Voltage 1000 V AC rms at Sea Level Operating Temperature -55°C To +85°C (upto +125°C for high temp) Insertion Force 16 oz (4.45 N) Maximum Per Contact Position Withdrawal Force 1 oz (0.28 N) Minimum Per Contact Position Ordering Code: 634-015-263-032 SERIES: 633: PLUG (PIN) 634: RECEPTACLE (SOCKET) NO. OF CONTACTS: 015 - 15 CONTACTS 026 - 26 CONTACTS 044 - 44 CONTACTS 062 - 62 CONTACTS 078 - 78 CONTACTS CONTACT FINISH CODE: 2 - GOLD FLASH PLATING 3 - 15 MICROINCHES OF GOLD PLATING 6 - 30 MICROINCHES OF GOLD PLATING CONTACT CODE: 63 - STANDARD CONTACT 74 - 9TH PIN CONTACT RECESSED FOR 15-PIN, BLUE INSULATOR (RECEPTACLE ONLY) www.edac.net FLANGE MOUNTING OPTIONS FLANGE MOUNTING OPTIONS: 0 - #4-40 THREADED FIXED STANDOFF 1 - Ø.120"(Ø3.05MM) THROUGH HOLE 2 - #4-40 THREADED HOLE 3 - #4-40 THREADED STANDOFF 5 - M3 THREADED HOLE BOARD MOUNTING FEATURE: 1 - Ø.120"(Ø3.05MM) THROUGH HOLE 3 - TWO PRONG BOARDLOCKS 4 - FOUR PRONG BOARDLOCKS 5 - #4-40 THREADED HOLE (78 CONTACTS ONLY AVAILABLE WITH TWO PRONG BOARDLOCKS) MATERIAL CODE: 0 - STANDARD 5 - HIGH TEMP INSULATOR customerservice@edac.net 633/634 SERIES D-Sub Connectors: Right Angle, High Density, 0.350” (8.89mm) Footprint PLUG 633 SERIES (15 TO 62 PINS) A B C D 22.10±0.38 6.00±0.25 12.55±0.38 8.36±0.13 3.960 SEE FLANGE MOUNTING OPTIONS 8.89±0.25 FOOTPRINT 3.18±0.38 E B Ø1.10 D NUMBER OF CONTACTS A±0.38 Inch D 2.54±0.25 2.54±0.25 E (mm) 8.89 E 11.43 16.10±0.25 11.43±0.25 5.08 2-Ø3.20 P.C.B EDGE RECOMMENDED P.C.B LAYOUT D±0.13 C±0.13 B±0.25 E±0.25 Inch (mm) Inch (mm) Inch (mm) Inch (mm) 15 1.213 (30.81) .984 (24.99) .666 (16.92) .090 (2.29) .010 (0.25) 26 1.543 (39.19) 1.312 (33.32) .994 (25.25) .090 (2.29) .020 (0.51) 44 2.088 (53.04) 1.852 (47.04) 1.534 (38.96) .090 (2.29) .020 (0.51) 62 2.729 (69.32) 2.500 (63.50) 2.182 (55.42) .095 (2.41) .023 (0.58) PLUG 633 SERIES (78 PINS) 2.54 2.42 1.21 61.10 1 20 21 39 60 78 6.10±0.25 2.54 2.54 8.89±0.25 FOOTPRINT RECOMMENDED P.C.B. LAYOUT 3.18±0.38 2.54 8.89 59 P.C.B. EDGE 2.54 12.70±0.25 17.70±0.25 11.30±0.25 2.08±0.13 12.70 40 2.54 1.21 2-Ø3.20 15.40±0.38 SEE FLANGE MOUNTING OPTIONS 78-Ø1.10 67.00±0.38 61.10±0.25 52.80±0.25 2.42±0.13 633/634 SERIES D-Sub Connectors: Right Angle, High Density, 0.350” (8.89mm) Footprint RECEPTACLE 634 SERIES (15 TO 62 PINS) A B C D 22.10±0.38 6.00±0.25 E 3.18±0.38 3.7 2.1 12.55±0.38 7.90±0.13 3.960 SEE FLANGE MOUNTING OPTIONS 8.89±0.25 FOOTPRINT 3.70 B Ø1.10 5.08 16.10±0.25 11.43±0.25 2-Ø3.20 D NUMBER OF CONTACTS A±0.38 Inch (mm) D 2.54±0.25 2.54±0.25 E 8.89 11.43 E P.C.B EDGE RECOMMENDED P.C.B LAYOUT D±0.13 C±0.13 B±0.25 E±0.25 Inch (mm) Inch (mm) Inch (mm) Inch (mm) .090 (2.29) .010 (0.25) 15 1.213 (30.81) .984 (24.99) .643 (16.33) 26 1.543 (39.19) 1.312 (33.32) .971 (24.66) .090 (2.29) .020 (0.51) 44 2.088 (53.04) 1.852 (47.04) 1.511 (38.38) .090 (2.29) .020 (0.51) 62 2.729 (69.32) 2.500 (63.50) 2.159 (54.84 .095 (2.41) .023 (0.58) RECEPTACLE 634 SERIES (78 PINS) 78-Ø1.10 1 20 21 39 60 78 6.00±0.25 2.54 2.54 8.89±0.25 FOOTPRINT RECOMMENDED P.C.B. LAYOUT 2.54 8.89 11.43 11.43±0.25 59 P.C.B. EDGE 2.54 10.90±0.25 2.08±0.13 2.54 2-Ø3.20 61.10 40 17.70±0.25 www.edac.net 2.42 1.21 2.54 1.21 67.00±0.38 61.10±0.25 52.20±0.25 2.42±0.13 15.40±0.38 SEE FLANGE MOUNTING OPTIONS 3.30±0.38 customerservice@edac.net
633-044-263-515 价格&库存
很抱歉,暂时无法提供与“633-044-263-515”相匹配的价格&库存,您可以联系我们找货
