ISSUE NUMBER
THIS IS A C.A.D. GENERATED DRAWING
DO NOT MAKE MANUAL REVISIONS TO MASTER.
Contact Information
520-P.C. Tail, Regular Point - Tail LG.=.175(4.45)
.100" (2.54mm) Contact Spacing x .200" (5.08mm) Row Spacing
ORIGINAL
1
0.760 19.30
0.600 15.24
Card Slot Accepts
.054 (1.37) to .070 (1.78)
Thick P.C. Board
0.350 8.89
.230 [5.84]
Point of Contact
0.550 13.97
0.100 2.54
0.420 10.67
Card Slot
A
A
0.300 7.62
SECTION A-A
725 Series Ultra-Mate Card Edge Connector - Press Fit
Part Number: 725-010-520-201
See Sheet 2 for Features and Specifications
EDAC INC
TORONTO, ONTARIO
CANADA
YOUR CONNECTION TO QUALITY & SERVICE
THESE DRAWINGS AND SPECIFICATIONS
ARE THE PROPERTY OF EDAC INC.,AND
SHALL NOT BE REPRODUCED,OR COPIED
OR USED AS THE BASIS FOR THE
MANUFACTURE OR SALE OF APPARATUS
WITHOUT WRITTEN PERMISSION.
ACAD REFERENCE NO.
DRAWN:
J.LEE
725-ENG MASTER
DATE: AUG31/09
CHECKED:
DATE:
SCALE:
SHEET 1
DRAWING NUMBER
725-ENG MASTER
OF 2
ISSUE
1
ISSUE NUMBER
ORIGINAL
1
Features
CSA Approved and UL Recognized
.100 (2.54) Contact Spacing x .200 (5.08) Row Spacing
Accepts .062 (1.57) Nominal Thickness P.C. Board
Low Profile Insulator Body, .550 (13.97) with End Notch Option
Ultra-Mate Compliant Section for Gas-Tight Reliable Connection in Plated Through
Holes Eliminates Soldering Operations
Contact Termination Options Include P.C. Tail and .025 (0.64) Square Wire Wrap
Single or Dual Row Configurations
Accepts Between Contact and In-Contact Polarizing Keys
Tools Available for Insulator and Contact Removal. Simple “Flat Rock” Tooling is
Used for Contact Installation
Specifications
Insulator Material: Thermoplastic Polyester, UL 94V-0, Colour: Black
Contact Material: Copper, Nickel,
Contact Plating: 30 Microinches (0.76 Microns) Gold on the Mating Area, Tin on the
Compliant Section and Contact Tails, Nickel Underplate. Other Plating Options
Available Upon Request.
Current Rating: 2 Amperes Continuous
Contact Resistance: 10 Milliohms Maximum
Dielectric Withstanding Voltage: 1200 V AC rms at Sea Level Between Adjacent
Contacts
Insulation Resistance: 5000 Megohms Minimum
Operating Temperature: -65 to +105 Degrees C
Daughter Board Insertion Force: 16 oz (4.45 N) Maximum per Contact Pair When
Tested with a .070 (1.78) Thick Gauge
Daughter Board Withdrawal Force: 1 oz (0.28 N) Minimum per Contact Pair When
Tested with a .054 (1.37) Thick Gauge
Contact Insertion into Hole: 20 lbs (89 N) Maximum
Contact Retention in Hole: 10 lbs (44 N) Minimum
Re-Insertability of Hole: 3 Times Minimum
EDAC INC
TORONTO, ONTARIO
CANADA
ACAD REFERENCE NO.
DRAWN:
J.LEE
725-ENG MASTER
DATE: AUG.31/09
CHECKED:
DATE:
SCALE:
SHEET 2
DRAWING NUMBER
725-ENG MASTER
OF 2
ISSUE
1
很抱歉,暂时无法提供与“725-010-520-201”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 25+31.1951125+3.88070
- 国内价格 香港价格
- 25+24.8053225+3.08580
- 75+24.4484175+3.04140
- 125+24.26996125+3.01920
- 375+23.91305375+2.97480
- 625+23.64536625+2.94150
