632-015-366-533
632-015-366-533
    632 SERIES RIGHT ANGLE D-SUB REC
632-015-366-533 数据手册
632 SERIES D-Sub Connectors: Right Angle, High Density, 0.121” (3.08mm) Footprint Features: • • • • • • • • • High density three contact rows with 0.121”(3.08mm) footprint, right angle bend 0.090”(2.29mm) contact spacing X 0.078”(1.98mm) row spacing Receptacle in 15 contact size Pin and socket contact mating design with P.C. tail termination Metal shell provides EMI/RFI shielding Board mounting features include two prong boardlock for exceptional retention to P.C. board Flange mounting options for panel mount or connector mating include through hole, threaded hole and threaded standoffs D-shaped connector mating outline provides polarization Design based on requirements of MIL-C-24038, EIA RS-232 and RS-44 Specifications: Insulator Material Thermoplastic Polyester, UL 94V-0, Chemical Resistant, Color: Black Contact Material Brass Contact Plating Selective Gold (See Ordering Code) over Nickel for the Mating Area, Tin Plating for Tail Area Shell Material Nickel Plated Steel Current Rating 3 amps Contact Resistance 25 Milliohms maximum Insulation Resistance 5000 megaohms minimum Dielectric Withstanding Voltage 1000 V AC rms at Sea Level Operating Temperature -55°C To +85°C (upto +125°C for high temp) Insertion Force 211.6 oz (58.8 N) maximum Withdrawal Force 42.3 oz (11.8 N) minimum Ordering Code: 632-015-266-033 SERIES: 632: RECEPTACLE (SOCKET) NO. OF CONTACTS: 015 - 15 CONTACTS FLANGE MOUNTING OPTIONS FLANGE MOUNTING OPTIONS: 1 - Ø.120" (Ø3.05MM) THROUGH HOLE 2 - #4-40 THREADED HOLE 3 - #4-40 THREADED STANDOFF 5 - M3 THREADED HOLE CONTACT FINISH CODE: 2 - GOLD FLASH PLATING 3 - 15 MICROINCHES OF GOLD PLATING 6 - 30 MICROINCHES OF GOLD PLATING BOARD MOUNTING FEATURE: 3 - TWO PRONG BOARDLOCKS CONTACT CODE: 66 - .121" (3.08MM) FOOTPRINT CONTACT 74 - 9TH PIN CONTACT RECESSED, BLUE INSULATOR MATERIAL CODE: 0 - STANDARD 5 - HIGH TEMP INSULATOR www.edac.net customerservice@edac.net 632 SERIES D-Sub Connectors: Right Angle, High Density, 0.121” (3.08mm) Footprint RECEPTACLE 632 SERIES 5 1 10 15 11 3.18±0.38 SEE FLANGE MOUNTING OPTIONS 6 3.80 12.55±0.38 7.90±0.13 3.96 30.81±0.38 24.99±0.25 16.33±0.13 2.290 0.25 3.96±0.25 24.99 2-Ø3.20 1.145 2.29 15-Ø1.09 1.98 1.98 0.25 2.29 1.145 P.C.B. EDGE 3.08 5.06 14.85±0.25 6.00 5.06±0.25 3.08±0.25 RECOMMENDED P.C.B. LAYOUT www.edac.net customerservice@edac.net
632-015-366-533 价格&库存
很抱歉,暂时无法提供与“632-015-366-533”相匹配的价格&库存,您可以联系我们找货
