663-037-664-03A
663-037-664-03A
    CONN D-SUB PLUG/RCPT 37P R/A SLD
663-037-664-03A 数据手册
661/662/663/664 SERIES D-Sub Connectors: Dual Port, Right Angle Features: • • • • • • • • • • Two contact rows per connector with right angle bend 0.109”(2.77mm) contact spacing x 0.112”(2.84mm) row spacing Plug and receptacle in 9, 15, 25 or 37 contact sizes Pin and socket contact mating design with P.C. tail termination Metal shell provides EMI/RFI shielding, plug shell indents provide grounding and additional mating retention Board mounting features include grounding bracket with threaded hole or boardlocks for exceptional retention to P.C. board Flange mounting options for panel mount or connector mating include through hole, threaded inserts and threaded standoffs D-shaped connector mating outline provides polarization Design based on requirements of MIL-C-24038, EIA RS-232 and RS-449 Additional grounding features or mounting options - contact customer service at customerservice@edac.net Specifications: Insulator Material Thermoplastic Polyester, UL 94V-0, Chemical Resistant, Color: Black Contact Material Plug (Pins): Brass Receptacle (Socket): Brass or Phosphor Bronze Contact Plating Selective Gold (See Ordering Code) over Nickel for the Mating Area, Tin Plating for Tail Area Ferrite Specs: 20dB MIN @30 MHz, 30dB MIN @50 MHz, and 50dB MIN @100 MHz (Optional) Shell Material Nickel Plated Steel Current Rating 3 amps Contact Resistance 25 Milliohms maximum Insulation Resistance 5000 megaohms minimum Dielectric Withstanding Voltage 1000 V AC rms at Sea Level Operating Temperature -55°C To +85°C Insertion Force 16 oz (4.45 N) Maximum Per Contact Position Ordering Code: 661-025-264-053 SERIES: 661: PLUG OVER PLUG 662: RECEPTACLE OVER RECEPTACLE 663: PLUG OVER RECEPTACLE 664: RECEPTACLE OVER PLUG NO. OF CONTACTS (PER CONNECTOR): 009 - 9 CONTACTS 025 - 25 CONTACTS 015 - 15 CONTACTS 037 - 37 CONTACTS CONTACT FINISH CODE: 2 - GOLD FLASH PLATING 3 - 15 MICROINCHES OF GOLD PLATING 6 - 30 MICROINCHES OF GOLD PLATING CONTACT CODE: 64 - DUAL PORT RIGHT ANGLE BEND CONTACT EDAC INTERNAL: 0 www.edac.net 661 SERIES PLUG OVER PLUG FLANGE MOUNTING OPTIONS: 1- .625"(15.88MM) M3 THREADED INSERT 2 - .625"(15.88MM) #4-40 UNC THREADED INSERT 3 - .625"(15.88MM) #4-40 UNC THREADED HEX STANDOFF 4 - .625"(15.88MM) .125" CLEAR HOLE INSERT A - .750"(19.05MM) M3 THREADED INSERT 5 - .750"(19.05MM) #4-40 UNC THREADED INSERT 6 - .750"(19.05MM) #4-40 UNC THREADED HEX STANDOFF 7 - .750"(19.05MM) .125" CLEAR HOLE INSERT C - .900"(22.86MM) M3 THREADED INSERT 8 - .900"(22.86MM) #4-40 UNC THREADED INSERT 9 - .900"(22.86MM) #4-40 UNC THREADED HEX STANDOF 0 - .900"(22.86MM) .125" CLEAR HOLE INSERT 663 SERIES PLUG OVER RECEPTACLE VERTICAL SPACING 662 SERIES RECEPTACLE OVER RECEPTACLE 664 SERIES RECEPTACLE OVER PLUG VERTICAL SPACING BOARD GROUNDING FEATURE: 0 - Ø3.80mm THRU' HOLES 3 - 4x 2 PRONG BOARDLOCKS 4 - 2x 2 PRONG BOARDLOCKS (REAR ONLY) 5 - #4-40 THREADED HOLE customerservice@edac.net 661/662/663/664 SERIES D-Sub Connectors: Dual Port, Right Angle 12.55±0.38 8.36±0.13 2.84 PLUG/PLUG 661 SERIES A B C 6.00±0.25 2.770 2 3 10 4 5 11 6 12 13 7 14 8 15 E F 9 3.18±0.38 1 1 2 4 3 5 11 10 6 12 12.55±0.38 8.36±0.13 2.84 9 13 7 14 8 15 2.770 Ø1.10 4-Ø3.20 2.77 8.08 8.00 2.77 3.92 8.08 8.00 8.08 19.60±0.25 8.08 14.84±0.25 3.92 2.84 2.84 2.84 B P.C.B EDGE 2.84 RECOMMENDED P.C.B LAYOUT FOR ALL SERIES 12.55±0.38 7.90±0.13 2.84 RECEPTACLE/RECEPTACLE 662 SERIES A B 5.80±0.25 2.770 8 7 6 14 5 13 4 12 3 11 2 10 1 9 8 7 6 14 5 13 4 12 3 11 2 10 1 9 2.770 D FOR ALL SERIES 8.00 8.08 19.60±0.25 E±0.25 CTR TO CTR VERTICAL SPACING 2.84 8.08 14.84±0.25 3.92 12.55±0.38 7.90±0.13 2.84 15 3.18±0.38 E F 15 (mm) Inch F±0.38 Inch (mm) .625 (15.88) 1.119 (28.43) .750 (19.05) 1.244 (31.60) .900 (22.86) 1.394 (35.41) FOR ALL SERIES NUMBER OF CONTACTS www.edac.net A±0.38 Inch (mm) B±0.25 C±0.13 PLUG Inch (mm) Inch (mm) D±0.13 RECEPTACLE Inch (mm) (16.33) 9 1.213 (30.81) .984 (24.99) .666 (16.92) .643 15 1.543 (39.19) 1.312 (33.32) .994 (25.25) .971 (24.66) 25 2.088 (53.04) 1.852 (47.04) 1.534 (38.96) 1.511 (38.38) 37 2.729 (69.32) 2.500 (63.50) 2.182 (55.42) 2.159 (54.84) customerservice@edac.net 661/662/663/664 SERIES D-Sub Connectors: Dual Port, Right Angle PLUG/RECEPTACLE 663 SERIES 12.55±0.38 8.36±0.13 2.84 A B C 6.00±0.25 2.770 1 2 4 3 5 7 6 8 10 11 12 13 14 15 7 6 5 4 3 2 14 13 12.55±0.38 7.90±0.13 2.84 15 12 11 1 10 9 2.770 5.80±0.25 B 2.84 D Ø1.10 4-Ø3.20 2.77 8.08 8.00 3.92 8.08 8.00 8.08 19.60±0.25 8.08 2.77 P.C.B EDGE RECOMMENDED P.C.B LAYOUT 2.84 14.84±0.25 3.92 2.84 2.84 8 3.18±0.38 E F 9 FOR ALL SERIES RECEPTACLE/PLUG 664 SERIES 12.55±0.38 7.90±0.13 2.84 A B D 5.80±0.25 2.770 8 5 6 7 14 13 3 4 12 11 2 10 1 9 1 2 3 10 4 11 5 12 6 13 7 14 8 15 2.770 C 6.00±0.25 FOR ALL SERIES E±0.25 8.00 8.08 19.60±0.25 14.84±0.25 3.92 12.55±0.38 8.36±0.13 2.84 2.84 8.08 9 3.18±0.38 E F 15 2.84 CTR TO CTR VERTICAL SPACING Inch (mm) F±0.38 Inch (mm) .625 (15.88) 1.119 (28.43) .750 (19.05) 1.244 (31.60) .900 (22.86) 1.394 (35.41) FOR ALL SERIES NUMBER OF CONTACTS www.edac.net A±0.38 Inch (mm) B±0.25 C±0.13 PLUG Inch (mm) Inch (mm) D±0.13 RECEPTACLE Inch (mm) (16.33) 9 1.213 (30.81) .984 (24.99) .666 (16.92) .643 15 1.543 (39.19) 1.312 (33.32) .994 (25.25) .971 (24.66) 25 2.088 (53.04) 1.852 (47.04) 1.534 (38.96) 1.511 (38.38) 37 2.729 (69.32) 2.500 (63.50) 2.182 (55.42) 2.159 (54.84) customerservice@edac.net
663-037-664-03A
物料型号:661/662/663/664系列
器件简介:这些连接器是双端口直角D-Sub连接器,具有金属外壳提供EMI/RFI屏蔽,插头外壳凹槽提供接地和额外的配对保持力。
引脚分配:提供9、15、25或37接触点大小的插头和插座。
参数特性: - 绝缘体材料:热塑性聚酯,UL 94V-0,耐化学性,颜色:黑色 - 接触材料:插头(引脚):黄铜 插座(插孔):黄铜或磷青铜 - 接触镀层:选择性金(见订购代码)在接触区域上镍上,尾部区域锡镀层 - 壳体材料:镀镍钢 - 电流额定值:3安培 - 接触电阻:最大25毫欧姆 - 绝缘电阻:最小5000兆欧姆 - 介质耐电压:1000V交流有效值在海平面 - 工作温度:-55°C至+85°C - 插入力:每个接触位置最大16盎司(4.45N)
功能详解:设计基于MIL-C-24038、EIA RS-232和RS-449的要求,具有D形连接器配对轮廓以提供极性。
应用信息:适用于需要EMI/RFI屏蔽和极性防错的应用。
封装信息:包括板载安装特性,如带螺纹孔的接地支架或板锁,以及面板安装或连接器配对的法兰安装选项。
订购代码示例:661-025-264-053
663-037-664-03A 价格&库存
很抱歉,暂时无法提供与“663-037-664-03A”相匹配的价格&库存,您可以联系我们找货
