305-034-500-507
305-034-500-507
    305 SERIES (.156" (3.96MM) CONTA
305-034-500-507 数据手册
Mounting Option 07-M3-0.5 Metric Threaded Inserts Contact Detail 500-Wire Hole .087x.013(2.21x0.33) - Tail LG.=.282(7.16) .156 [3.96] Contact Spacing x .140 [3.56] Row Spacing ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. ORIGINAL 1 0.343 8.71 Card Slot Accepts .054 (1.37) to .070 (1.78) Thick P.C. Board 0.156 3.96 2.816 71.53 2.962 75.23 0.330 8.38 Card Slot 3.248 82.50 0.460 11.68 A A 0.125 3.18 Point of Contact 3.558 90.37 305 / 315 / 355 Card Edge Connector Part Number: 305-034-500-507 See Accompanying Page for: • Mounting Options EDAC INC TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. SECTION A-A ACAD REFERENCE NO. J.LEE DRAWN: CHECKED: SCALE: NTS DRAWING NUMBER 305 Assembly 305 ENG MASTER DATE: SEPT. 21/09 DATE: SHEET 1 OF 2 ISSUE 1 0.125 3.18 Code x01 Code x12 ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. ORIGINAL 1 .128 [3.25] Dia Through Holes .128 [3.25] Dia Through Holes 0.468 11.89 0.344 8.74 0.125 3.18 0.060 1.52 Code x02 0.116 2.95 I.D. Floating Eyelets 0.090 2.29 0.250 6.35 Dia. .010 [0.25] Radial Float 2.750 69.85 Code x03 2.500 63.50 0.328 8.33 0.005 0.13 1.550 39.37 .156 [3.96] Dia Through Holes 0.250 6.35 Code x04 M3-0.5 Metric Threaded Insert #4-40 UNC Threaded Insert Code x68 305 / 315 / 355 Card Edge Connector Mounting Options EDAC INC Code x08 0.250 6.35 0.242 6.15 0.423 10.74 Code x58 Code x07 0.250 6.35 TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. Code x78 ACAD REFERENCE NO. J.LEE DRAWN: CHECKED: SCALE: NTS DRAWING NUMBER 305 Assembly 305 ENG MASTER DATE: SEPT. 21/09 DATE: SHEET 2 OF 2 ISSUE 1
305-034-500-507
1. 物料型号:文档中提到了“305 / 315 / 355 Card Edge Connector”,并且给出了具体的部件型号“Part Number: 305-034-500-507”。
2. 器件简介:文档中描述了一种卡边缘连接器,具有500个线孔,尾部长度为.282英寸(7.16毫米),并提供了安装选项,例如M3-0.5米制螺纹嵌件和#4-40 UNC螺纹嵌件。
3. 引脚分配:文档中提到了接触点的间距为.156英寸(3.96毫米),行间距为.140英寸(3.56毫米)。
4. 参数特性:文档中提供了一些尺寸参数,例如接触点的直径为0.250英寸(6.35毫米),内径为0.116英寸(2.95毫米),以及通过孔的直径为.128英寸(3.25毫米)。
5. 功能详解:文档中没有提供详细的功能解释,但提到了卡槽可以接受厚度从.054英寸(1.37毫米)到.070英寸(1.78毫米)的PCB板。
6. 应用信息:文档中没有明确提供应用信息,但根据上下文推测,该连接器可能用于需要高密度连接的电子设备中。
7. 封装信息:文档中提供了一些封装相关的尺寸信息,例如卡槽的尺寸和接触点的布局。
305-034-500-507 价格&库存
很抱歉,暂时无法提供与“305-034-500-507”相匹配的价格&库存,您可以联系我们找货
