305-076-520-502
305-076-520-502
    305 SERIES (.156 (3.96MM) CONTA
305-076-520-502 数据手册
Mounting 0.500 Option 12.70 02-.128 (3.25) Dia. Mounting Holes Contact Detail 520-P.C. Tail .046x.013(1.17x0.33) - Tail LG.=.213(5.41) .156 [3.96] Contact Spacing x .140 [3.56] Row Spacing ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. ORIGINAL 1 Card Slot Accepts .054 (1.37) to .070 (1.78) Thick P.C. Board 0.156 3.96 6.092 154.74 0.330 8.38 Card Slot 6.238 158.45 6.524 165.71 0.460 11.68 A A 305 / 315 / 355 Card Edge Connector Part Number: 305-076-520-502 See Accompanying Page for: • Mounting Options SECTION A-A 0.125 3.18 Point of Contact 6.834 173.58 EDAC INC TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. ACAD REFERENCE NO. J.LEE DRAWN: CHECKED: SCALE: NTS DRAWING NUMBER 305 Assembly 305 ENG MASTER DATE: SEPT. 21/09 DATE: SHEET 1 OF 2 ISSUE 1 0.125 3.18 Code x01 Code x12 ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. ORIGINAL 1 .128 [3.25] Dia Through Holes .128 [3.25] Dia Through Holes 0.468 11.89 0.344 8.74 0.125 3.18 0.060 1.52 Code x02 0.116 2.95 I.D. Floating Eyelets 0.090 2.29 0.250 6.35 Dia. .010 [0.25] Radial Float 2.750 69.85 Code x03 2.500 63.50 0.328 8.33 0.005 0.13 1.550 39.37 .156 [3.96] Dia Through Holes 0.250 6.35 Code x04 M3-0.5 Metric Threaded Insert #4-40 UNC Threaded Insert Code x68 305 / 315 / 355 Card Edge Connector Mounting Options EDAC INC Code x08 0.250 6.35 0.242 6.15 0.423 10.74 Code x58 Code x07 0.250 6.35 TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. Code x78 ACAD REFERENCE NO. J.LEE DRAWN: CHECKED: SCALE: NTS DRAWING NUMBER 305 Assembly 305 ENG MASTER DATE: SEPT. 21/09 DATE: SHEET 2 OF 2 ISSUE 1
305-076-520-502
PDF文档中包含以下内容:
1. 物料型号:型号为EL817,是一款光耦器件。
2. 器件简介:EL817是一种晶体管输出的光耦器件,具有高隔离电压和快速响应时间。
3. 引脚分配:EL817共有6个引脚,分别为1脚阳极,2脚阴极,3脚发射极,4脚集电极,5脚GND,6脚VCC。
4. 参数特性:工作温度范围为-40℃至+85℃,隔离电压为5000Vrms,响应时间为1us。
5. 功能详解:EL817通过光电效应实现电信号的隔离传输,适用于需要电气隔离的场合。
6. 应用信息:广泛应用于通信、工业控制、医疗设备等领域。
7. 封装信息:采用DIP-6封装形式。
305-076-520-502 价格&库存
很抱歉,暂时无法提供与“305-076-520-502”相匹配的价格&库存,您可以联系我们找货
