0.343 8.71
Mounting Option
.128 (3.25) Dia. Mounting Holes
Contact Detail
90 Degree Bend (Code 422 and 440 Contacts)
.156 [3.96] Contact Spacing x .200 [5.08] Row Spacing
ISSUE NUMBER
THIS IS A C.A.D. GENERATED DRAWING
DO NOT MAKE MANUAL REVISIONS TO MASTER.
ORIGINAL
1
0.156 3.96
1.412 35.86
1.558 39.57
1.844 46.84
SECTION A-A
A
0.473 12.01
A
.095 [2.41] Point of Contact
(FROM BTM OF SLOT)
Card Slot Accepts .054 [1.37]
to .070 [1.78] Thick P.C. Board
2.154 54.71
See Accompanying Pages for:
Contact Bend Details
Mounting Options
307 / 357 Card Edge Connector
Part Number: 307-016-458-202
EDAC INC
TORONTO, ONTARIO
CANADA
YOUR CONNECTION TO QUALITY & SERVICE
THESE DRAWINGS AND SPECIFICATIONS
ARE THE PROPERTY OF EDAC INC.,AND
SHALL NOT BE REPRODUCED,OR COPIED
OR USED AS THE BASIS FOR THE
MANUFACTURE OR SALE OF APPARATUS
WITHOUT WRITTEN PERMISSION.
ACAD REFERENCE NO.
J.LEE
DRAWN:
CHECKED:
SCALE:
NTS
DRAWING NUMBER
307 Assembly
307 ENG MASTER
DATE: AUG. 11/09
DATE:
SHEET 1 OF 3
ISSUE
1
Single Row Contacts - Read One Side of Daughter Board
ISSUE NUMBER
0.240 6.10
ORIGINAL
1
0.240 6.10
0.260 6.60
558 Contact Code
559 Contact Code
0.060 1.52
Single Row Contacts - Read Both Sides of Daughter Board
0.110 2.79
0.150 3.81
0.392 9.96
0.045 1.14
0.045 1.14
553 Contact Code
554 Contact Code
557 Contact Code
Dual Row Contacts - Read Both Sides of Daughter Board
0.240 [6.10] Up to 27/54 Pin
0.162 [4.11] 28/56 and Over
0.120 3.05
0.095 2.41
0.265 6.73
555 Contact Code
.125 [3.18] to .210 [5.33]
Outside Tails
.045 [1.14] to .060 [1.52]
Between Tails
0.290 [7.37] Up to 27/54 Pin
.212 [5.38] 28/56 and Over
0.165 4.19
0.195 4.95
556 Contact Code
.125 [3.18] to .185 [4.70]
Outside Tails
Between Tails
0.343 8.71
0.200 5.08
0.060 1.52
558 Contact Code
Outside Tails
Between Tails
0.150 3.81
0.060 1.52
559 Contact Code
560 Contact Code
307/ 357 Series Card Edge Connector
Contact Bend Detail
EDAC INC
TORONTO, ONTARIO
CANADA
ACAD REFERENCE NO.
J.LEE
DRAWN:
CHECKED:
SCALE:
NTS
DRAWING NUMBER
307 Assembly
307 ENG MASTER
DATE: AUG. 11/09
DATE:
SHEET 2 OF 3
ISSUE
1
0.125 3.18
Code x01
Code x12
ISSUE NUMBER
ORIGINAL
1
.128 [3.25] Dia
Through Holes
.128 [3.25] Dia
Through Holes
0.468 11.89
0.344 8.74
0.125 3.18
0.060 1.52
Code x02
0.116 2.95 I.D.
Floating Eyelets
0.090 2.29
0.250 6.35 Dia.
2.500 63.50
2.750 69.85
0.328 8.33
Code x03
0.005 0.13
.010 [0.25]
Radial Float
1.550 39.37
0.250 6.35
0.250 6.35
.156 [3.96] Dia
Through Holes
0.250 6.35
Code x04
M3-0.5 Metric
Threaded Insert
0.242 6.15
0.423 10.74
Code x58
Code x07
#4-40 UNC
Threaded Insert
Code x68
Mounting Options
EDAC INC
Code x08
TORONTO, ONTARIO
CANADA
Code x78
ACAD REFERENCE NO.
J.LEE
DRAWN:
CHECKED:
SCALE:
NTS
DRAWING NUMBER
307 Assembly
307 ENG MASTER
DATE: AUG. 11/09
DATE:
SHEET 3 OF 3
ISSUE
1
很抱歉,暂时无法提供与“307-016-458-202”相匹配的价格&库存,您可以联系我们找货
