325 SERIES
Card Edge Connectors 0.100” (2.54mm) Pitch
Features:
0.100” (2.54mm) contact spacing x 0.300” (7.62mm) row spacing
Accepts 0.125” (3.18mm) nominal thickness P.C. board
Contact termination options include P.C. tail, wire hole and 0.025” (0.64mm) square wire wrap
High profile insulator body 0.600” (15.24mm)
Single or dual row configurations
Variety of mounting options
Accepts in-contact polarizing keys
Automatic wire wrap positioning holes
RoHS Compliant
Specifications:
Insulator Material
UL 94V-0 Diallyl Phthalate, Green Color
Contact Material
Copper Alloy
Contact Plating
Gold Plating on mating area and Tin Plating on tails with Nickel underplating all over
Current Rating
3 amps
Contact Resistance
10 milliohms maximum
Dielectric Withstanding Voltage
1200 V AC rms at sea level between adjacent contacts
Insulation Resistance
5000 megaohms minimum
Operating Temperature
-65°C to +125°C
Insertion Force
16 oz (4.45 N) maximum per contact pair when tested with .135” (3.43mm) thick gauge
Withdrawal Force
1 oz (0.28 N) minimum per contact pair when tested with .115” (2.92mm) thick gauge
Example Part Number:
325-122-520-209
Series
Total Number of Contacts
Contact Code
IN-CONTACT
POLARIZING KEY
P/N 325-240-328
Contact Rows
Mounting Options
Series:
325
Total Number of Contacts:
Contact Rows:
005, 006, . . . . 061
Single Row
010, 012, . . . . 122
Dual Row
Contact Code:
Description:
Contact Point:
Tail Length “G”:
500
Wire Hole
.050 x .025 (1.27 x 0.64)
.260 (6.60)
520
P.C. Tail
.025 Square (0.64 Square)
.175 (4.45
540
Wire Wrap
.560 (14.22)
Contact Rows:
Description:
1
Single Row
2
Dual Row
Mounting Options:
Description:
01
No Mounting Lug
07
M3-0.5 Metric Threaded Inserts
08
#4-40 Unified Threaded Inserts
09
Ø.160” (Ø4.06mm) Mounting Holes
www.edac.net
Ordering Code Notes:
1) All connector sizes up to 61 contacts single row / 122 contacts dual row
are available upon request.
2) For details of the mounting options, refer to next pages.
customerservice@edac.net
325 SERIES
WIRE WRAP
POSITIONING
SLOT AND HOLE
.490
(12.46)
CARD SLOT ACCEPTS .115 (2.92) TO
.135 (3.43) THICK P.C. BOARDS
.600
(15.24)
SECTION THROUGH
CONTACT POSITION
.297 (7.54)
CARD SLOT
.312
(7.92)
.127 (3.23)
POINT OF
CONTACT
.030 X .080 (0.76 X 2.03)
WIRE HOLE
9 11 13 15 17 19 21 23 25 27 29 31 33 35 37 39 41
1
3
5
7
2
4
6
8 10 12 14 16 18 20 22 24 26 28 30 32 34 36 38 40 42
.300(7.62)
CONTACTS FOR SINGLE
ROW CONNECTORS ON
EVEN NUMBERED SIDE
.300
(7.62)
.320
(8.13)
.080 (2.03) CUT OUT FOR
IN-CONTACT POLARIZING KEY
+.000
MINUS .012 (0.30) -.015 (0.38)
Ø.160 (4.06)
REF.
.100(2.54)
.520 (13.21)
PANEL MOUNT
CUT OUT
.150 (3.81) PANEL MOUNT CUT OUT
.042 (1.07) +.004 (0.10)/-.000
FOR P.C. TAILS
.008 (0.20) DIA
"A" DIA.
THROUGH
HOLES
THREADED
INSERTS
CODE X09 - THROUGH MTG. HOLES
CODE X09
"A" DIA.
0.160(4.06)
CODE X07 AND X08- THREADED INSERTS
CODE X07
INSERT
NUMBER OF CONTACTS
CODE X08
M3-0.5(METRIC)
"A"
#4-40 UNC
B
C
MTG. OPTION
CODE x01
(NO MTG. LUGS)
"B"
B
MTG. OPTION
CODE xO9
"C"
MTG. OPTION
CODES x07 & xO8
(THREADED INSERTS)
"D"
"E"
Single
Double
Inch
mm
Inch
mm
Inch
mm
Inch
mm
Inch
mm
5
10
1.355
34.42
1.056
26.82
0.722
18.34
0.600
15.24
0.400
10.16
15
30
2.355
59.82
2.056
52.22
1.722
43.74
1.600
40.64
1.400
35.56
18
36
2.655
67.44
2.356
59.84
2.022
51.36
1.900
48.26
1.700
43.18
22
44
3.055
77.60
2.756
70.00
2.422
61.52
2.300
58.42
2.100
53.34
15
30
3.355
85.22
3.056
77.62
2.722
69.14
2.600
66.04
2.400
60.96
30
60
3.855
97.92
3.556
90.32
3.222
81.84
3.100
78.74
2.900
73.66
36
72
4.455
113.16
4.156
105.56
3.822
97.08
3.700
93.98
3.500
88.90
40
80
4.855
123.32
4.556
115.72
4.222
107.24
4.100
104.14
3.900
99.06
43
86
5.155
130.94
4.856
123.34
4.522
114.86
4.400
111.76
4.200
106.68
50
100
5.855
148.72
5.556
141.12
5.222
132.64
5.100
129.54
4.900
124.46
61
122
6.955
176.66
6.656
169.06
6.322
160.58
6.200
157.48
6.000
152.40
www.edac.net
很抱歉,暂时无法提供与“325-025-500-107”相匹配的价格&库存,您可以联系我们找货
