628-W15-222-012
628-W15-222-012
    628W (WATERPROOF) SERIES VERTICA
628-W15-222-012 数据手册
627W/628W SERIES Waterproof D-Sub Connectors: Vertical Features: • • • • • • • • 0.109”(2.77mm) contact spacing x 0.112”(2.82mm) row spacing Plug and receptacle in 9, 15, 25 or 37 contact sizes Pin and socket contact mating design with P.C. tail termination or solder cup termination Plug shell indents provide grounding and additional mating retention Grounding features include two prong boardlock for exceptional retention to P.C. board Mounting options for panel mount or connector mating include threaded inserts or threaded standoffs D-shaped connector mating outline provides polarization Degree of protection: IP67 as per IEC60529 Specifications: Insulator Material PBT Thermoplastic with 30% Glass Filled, UL 94V-0 Rated, Black color Contact Material Pins and Sockets: Copper Alloy Contact Plating Gold Plating over Nickel underplating Shell Material Nickel Plated Steel Epoxy Sealant Epoxy O-Ring Silicone Current Rating 5 amps Contact Resistance 10 Milliohms maximum Dielectric Withstanding Voltage 5000 megaohms minimum Insulation Resistance 1000 V AC rms at Sea Level Operating Temperature -25°C To +85°C Ordering Code: 627-W09-220-012 SERIES: 627 - PLUG (PIN) 628 - RECEPTACLE (SOCKET) MOUNTING OPTION: 2 - #4-40 UNC THREADED HOLE 3 - RIVETED #4-40 UNC BOARDLOCKS EDAC CODE: W - WATERPROOF NOTE: ALL CONNECTORS ARE SHIPPED WITH #4-40 UNC HEXAGON SCREWS (PACKED SEPARATELY) NO. OF CONTACTS: 09 - 9 CONTACTS 15 - 15 CONTACTS 25 - 25 CONTACTS 37 - 37 CONTACTS CONTACT PLATING: 2 - GOLD FLASH PLATING 3 - 15µ" OF GOLD PLATING 6 - 30µ" OF GOLD PLATING www.edac.net (ONLY AVAILABLE WITH CONTACT CODE 20) SHELL OPTIONS: 1 - NICKEL PLATED INSULATOR COLOR: 0 - BLACK CONTACT CODE: 20 - PC TAIL (LENGTH = 3.50mm) 21 - PC TAIL (LENGTH = 14.95mm) 22 - SOLDER CUP TERMINATION customerservice@edac.net
628-W15-222-012
物料型号:627W/628W系列
器件简介:这些连接器是垂直安装的防水D-Sub连接器,具有0.109英寸(2.77mm)的接触间距和0.112英寸(2.82mm)的行间距,提供9、15、25或37接触点大小的插头和插座。
引脚分配:文档未明确提供引脚分配图,但提到了不同接触点大小的选项。
参数特性: - 绝缘体材料:30%玻璃填充的PBT热塑性材料,UL 94V-0等级,黑色 - 接触材料:铜合金 - 接触镀层:镍底层上的金镀层 - 壳体材料:镀镍钢 - 环氧密封剂:环氧树脂 - O型圈:硅胶 - 电流额定值:5安培 - 接触电阻:最大10毫欧姆 - 介质耐压:至少5000兆欧 - 绝缘电阻:在海平面1000V交流有效值 - 工作温度范围:-25°C至+85°C
功能详解:文档未提供详细的功能解释,但强调了其防水特性,符合IEC60529标准的IP67防护等级。
应用信息:文档未明确提供应用信息,但根据其特性,这些连接器适用于需要防水和极好保持力的应用场景。
封装信息:提供了订购代码和详细的订购选项,包括系列、安装选项、EDAC代码、壳体选项、接触点数量、绝缘体颜色和接触代码。
628-W15-222-012 价格&库存
很抱歉,暂时无法提供与“628-W15-222-012”相匹配的价格&库存,您可以联系我们找货
628-W15-222-012
  • 1+148.547831+19.31074
  • 10+126.2464610+16.41163
  • 25+118.3394825+15.38375
  • 54+112.0828954+14.57042
  • 108+106.73470108+13.87517
  • 270+100.05844270+13.00728
  • 540+95.28805540+12.38714
