629C/630C SERIES
Power Combo D-Sub Connectors: Right Angle
Features:
Signal, along with power or coaxial contacts within one connector
Space saving on the PCB and I/O designs
Available in various pin out configurations
Pin and socket contact mating design with P.C. tail termination
Metal shell provides EMI/RFI shielding, plug shell indents provide grounding and additional mating
retention
Mounting options for panel mount or connector mating include through hole, threaded hole and
threaded standoffs
D-shaped connector mating outline provides polarization
Specifications:
Power/Coaxial Only
Combination
Insulator Material
Thermoplastic Polyester, UL 94V-0, Color: Black
Contact Material
Copper Alloy
Contact Plating
Selective Gold (See Ordering Code) over Nickel for the Mating Area, Tin Plating for Tail Area
Shell Material and Plating
Steel, Sn or Ni Plated
Shell Material
Nickel Plated Steel
Current Rating (Power Contacts)
10 amps, 20 amps, 30 amps, 40 amps
Current Rating (Signal Contacts)
5 amps
Voltage Rating
125 V
Contact Resistance
(Power Contacts)
1 Milliohms maximum
Contact Resistance
(Signal Contacts)
10 Milliohms maximum
Insulation Resistance
5000 megaohms minimum
Dielectric Withstanding Voltage
1000 V AC rms at Sea Level
Operating Temperature
-55°C To +125°C
Mating Cycle
500 For 30 Microinches Gold Plating, 50 For Gold Flash Plating
Ordering Code:
SERIES:
629: PLUG (PIN)
630: RECEPTACLE (SOCKET)
LAYOUT:
POWER/CO-AX
ONLY
SIZE 9 CONTACT SHELL
2WK2
5W1
3WK3
7W2
11W1
9W4
13W3 17W2 21W1
SIZE 15 CONTACT SHELL
3W3
SIZE 25 CONTACT SHELL
5W5
SIZE 37 CONTACT SHELL
8W8
13W6 17W5 25W3 27W2 21W4
24W7 36W4 43W2 47W1
SIZE 50 CONTACT SHELL
8W8
COMBINATION
2W2
2WK2
TOTAL NO.OF POWER OR CO-AXCONTACT
TOTAL NO.OF CONTACT
MALE FEMALE COMBINATION
CONTACT PLATING THICKNESS:
2 - GOLD FLASH PLATING
6 - 30 MICROINCHES OF GOLD PLATING
TAIL TYPE:
40 - PC TAIL
50 - PC TAIL 20.33mm FOOTPRINT (POWER CONTACT ONLY)
www.edac.net
MOUNTING OPTIONS:
1 - THROUGH HOLE
2 - #4-40 UNC THREADED HOLE ONLY
3 - #4-40 UNC THREADED HOLE, MOUNTING BRACKET, BOARDLOCK
4 - #4-40 UNC THREADED HOLE, MOUNTING BRACKET
5 - #4-40 UNC THREADED STANDOFF, MOUNTING BRACKET, BOARDLOCK
6 - #4-40 UNC THREADED STANDOFF, MOUNTING BRACKET
A - M3 THREADED HOLE ONLY
B - M3 THREADED HOLE, MOUNTING BRACKET, BOARDLOCK
C - M3 THREADED HOLE, MOUNTING BRACKET
D - M3 THREADED STANDOFF, MOUNTING BRACKET, BOARDLOCK
E - M3 THREADED STANDOFF, MOUNTING BRACKET
SHELL PLATING:
N - NICKEL
T - TIN
RATING:
POWER CONTACT
CURRENT RATING:
1 - 10A
2 - 20A
3 - 30A
4 - 40A
COAXIAL CONTACT
IMPEDANCE RATING:
5 - 50 OHMS
7 - 75 OHMS
customerservice@edac.net
629C/630C SERIES
Layout:
Layout:
POWER/COAXIAL D-SUB ONLY
COMBINATION
SIZE 9
2W2
2WK2
3W3
3WK3
5W1
SIZE 15
SIZE 25
7W2
11W1
9W4
13W3
17W2
21W1
5W5
13W6
17W5
25W3
27W2
SIZE 37
8W8
21W4
24W7
36W4
43W2
47W1
SIZE 50
www.edac.net
629C/630C SERIES
Power/Coaxial
Power/Coaxial D-SUB:
D-SUB:
R/A PCB SOLDER TYPE
MALE
FEMALE
POWER-DUB
POWER D-SUB
COAXIAL D-SUB
COAXIAL D-SUB
POWER D-SUB
POWER D-SUB
CONTACT SHELL SIZE
DIMA
DIMB
DIMC
DIMD DIME(POWER/COAXIAL) RATING
ØF
SIZE 9
30.80
25.00
16.90
12.50
7.90/8.30
10A
1.7
SIZE 15
39.20
33.30
25.25
12.50
7.90/8.30
20A
2.8
SIZE 25
53.05
47.05
38.95
12.50
7.90/8.30
30A
3.2
SIZE 37
69.40
63.50
55.40
12.50
7.90/8.30
40A
3.75
CONTACT SHELL SIZE
DIMA
DIMB DIMC(POWER/COAXIAL) DIMD
SIZE 9
30.80
25.00
SIZE 15
39.20
SIZE 25
53.05
SIZE 37
69.40
DIME
RATING
ØF
16.90/16.30
12.50
7.90
10A
1.7
33.30
25.25/24.60
12.50
7.90
20A
2.8
47.05
38.95/38.40
12.50
7.90
30A
3.2
63.50
55.40/54.80
12.50
7.90
40A
3.75
COAXIAL D-SUB
COAXIAL D-SUB
MOUNTING OPTION
MALE
CODE:1
CODE:3/B
CODE:5/D
www.edac.net
FEMALE
CODE:2/A
CODE:4/C
CODE:6/E
629C/630C SERIES
Power D-SUB:
PCB LAYOUT FOR POWER D-SUB MALE AND FEMALE CONNECTOR
CODE:3W3/3WK3
CODE:2W2/2WK2
CODE:8W8 MALE
CODE:5W5 MALE
CODE:8W8 FEMALE
CODE:5W5 FEMALE
CURRENT RATING
ØA(mm)
www.edac.net
10A
2.2
20A 30A 40A
3.3 3.7 4.2
629C/630C SERIES
Coaxial D-SUB:
PCB LAYOUT FOR COAXIAL D-SUB MALE AND FEMALE CONNECTOR
CODE:2W2/2WK2
MALE/FEMALE
CODE:3W3/3WK3
MALE/FEMALE
CODE:5W5
MALE
CODE:8W8
MALE
CODE:5W5
FEMALE
CODE:8W8
FEMALE
www.edac.net
629C/630C SERIES
Power Combo& Coaxial Combo D-SUB:
RA PCB SOLDER TYPE
MALE
FEMALE
POWER COMBO D-SUB
POWER COMBO D-SUB
COAXIAL COMBO D-SUB
COAXIAL COMBO D-SUB
POWER D-SUB
POWER D-SUB
CONTACT SHELL SIZE
DIMA
DIMB
DIMC
DIMD
DIME
RATING
ØF
SIZE 9
30.80
25.00
16.90
12.50
8.30
10A
1.7
CONTACT SHELL SIZE
SIZE 9
SIZE 15
39.20
33.30
25.25
12.50
8.30
20A
2.8
SIZE 25
SIZE 37
SIZE 50
53.05
69.40
67.00
47.05
63.50
61.00
38.95
55.40
52.80
12.50
12.50
15.30
8.30
8.30
11.15
30A
40A
3.2
3.75
COAXIAL D-SUB
DIMA
30.80
DIMB
25.00
SIZE 15
39.20
SIZE 25
53.05
SIZE 37
SIZE 37
DIMD
12.50
DIME
7.90
RATING
10A
ØF
1.7
33.30
24.60
12.50
7.90
20A
2.8
47.05
38.40
12.50
7.90
30A
3.2
69.40
63.50
55.40
12.50
7.90
40A
3.75
67.00
61.00
52.20
15.30
10.90
COAXIAL D-SUB
R/A PCB SOLDER TYPE MOUNTING OPTION
www.edac.net
DIMC
16.30
CODE:1
CODE:2/A
CODE:3/B
CODE:4/C
CODE:5/D
CODE:6/E
629C/630C SERIES
Power Combo D-SUB:
PCB LAYOUT FOR MALE AND FEMALE CONNECTOR
CODE:24W7
MALE/FEMALE
CODE:5W1
MALE/FEMALE
www.edac.net
CODE:7W2
MALE/FEMALE
CODE:21W4
MALE/FEMALE
CODE:11W1
MALE/FEMALE
CODE:27W2
MALE/FEMALE
CODE:17W2
MALE/FEMALE
CODE:21W1
MALE/FEMALE
CUREENT RATING
10A
20A 30A 40A
ØA(mm)
2.2
3.3
3.7
4.2
629C/630C SERIES
Power Combo D-SUB:
PCB LAYOUT FOR MALE CONNECTOR
CODE:25W3
MALE
CODE:9W4
MALE
CODE:36W4
MALE
CODE:13W3
MALE
CODE:43W2
MALE
CODE:13W6
MALE
CODE:47W1
MALE
CODE:17W5
MALE
www.edac.net
CUREENT RATING
10A
20A 30A 40A
ØA(mm)
2.2
3.3
3.7
4.2
629C/630C SERIES
Power Combo D-SUB:
PCB LAYOUT FOR FEMALE CONNECTOR
CODE:25W3
FEMALE
CODE:9W4
FEMALE
CODE:36W4
FEMALE
CODE:13W3
FEMALE
CODE:43W2
FEMALE
CODE:13W6
FEMALE
CODE:47W1
FEMALE
CODE:17W5
FEMALE
www.edac.net
CUREENT RATING
10A
20A 30A 40A
ØA(mm)
2.2
3.3
3.7
4.2
629C/630C SERIES
CODE:5W1
MALE/FEMALE
www.edac.net
CODE:24W7
MALE/FEMALE
CODE:7W2
MALE/FEMALE
CODE:21W4
MALE/FEMALE
CODE:11W1
MALE/FEMALE
CODE:27W2
MALE/FEMALE
CODE:17W2
MALE/FEMALE
CODE:21W1
MALE/FEMALE
629C/630C SERIES
CODE:25W3
MALE
CODE:9W4
MALE
CODE:36W4
MALE
CODE:13W3
MALE
CODE:43W2
MALE
CODE:13W6
MALE
SERIES:
629: PLUG (PIN)
LAYOUT:
POWER/CO-AX
ONLY
2WK2
5W1
3WK3
7W2
11W1
9W4
CODE:17W5
13W3 17W2
21W1
3W3
5W5
8W8
MALE
24W7 36W4 43W2 47W1
8W8
COMBINATION
2W2
2WK2
TOTAL NO.OF CONTACT
TAIL TYPE:
40 - PC TAIL
www.edac.net
MOUNTING OPTIONS:
1 - THROUGH HOLE
CODE:47W1
MALE
BOARDLOCK
SHELL PLATING:
N - NICKEL
T - TIN
RATING:
POWER CONTACT
CURRENT RATING:
1 - 10A
2 - 20A
3 - 30A
4 - 40A
COAXIAL CONTACT
IMPEDANCE RATING:
5 - 50 OHMS
7 - 75 OHMS
629C/630C SERIES
CODE:9W4
FEMALE
CODE:13W3
FEMALE
CODE:13W6
FEMALE
CODE:17W5
FEMALE
www.edac.net
CODE:25W3
FEMALE
CODE:36W4
FEMALE
CODE:43W2
FEMALE
CODE:47W1
FEMALE
很抱歉,暂时无法提供与“630-8W8-650-4NE”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 250+262.12921250+33.95490
- 国内价格 香港价格
- 250+297.52832250+38.54033
