725-048-560-201
    725 SERIES (.100" (2.54MM) CONTA
725-048-560-201 数据手册
725 SERIES Press-Fit Card Edge Connectors 0.100” (2.54mm) Pitch Features: • • • • • 0.100” (2.54mm) contact spacing x 0.200” (5.08mm) row spacing Accepts 0.062” (1.57mm) nominal thickness P.C. board Low profile insulator body, 0.550”(13.97mm) Contact termination options include P.C. tail, and 0.025” (0.64mm) square wire wrap Press-Fit compliant section for gas tight reliable connection in plated through holes eliminates soldering operations Single or dual row configurations Accepts between contact and in-contact polarizing keys (special features if requested) Tools available for insulator and contact removal. Simple “flat rock” tooling is used for connector installation RoHS Compliant & UL Certified • • • • Specifications: Insulator Material Thermoplastic Polyphenylene Sulfide (PPS), UL 94V-0, Black Color Contact Material Copper Alloy Contact Plating 30µ” Gold Plating on mating area and Tin Plating on tails with Nickel underplating all over Current Rating 2 amps Contact Resistance 10 milliohms maximum Dielectric Withstanding Voltage 1200 V AC rms at sea level between adjacent contacts Insulation Resistance 5000 megaohms minimum Operating Temperature -40°C to +105°C Insertion Force 16 oz (4.45 N) maximum per contact pair when tested with .070” (1.78mm) thick gauge Withdrawal Force 1 oz (0.28 N) minimum per contact pair when tested with .054” (1.37mm) thick gauge Contact insertion into Hole 20 lbs (89 N) Maximum Contact Retention in Hole 10 lbs (44 N) Minimum Re-Insertability in same Hole 1 Time Maximum Example Part Number: 725-100-520-201 Series Total Number of Contacts Contact Code Contact Rows Insulator Options Series: BETWEEN CONTACT POLARIZING KEY P/N 341-240-318 725 Total Number of Contacts: Contact Rows: 005, 006, . . . . 075 Single Row 010, 012, . . . . 150 Dual Row Contact Code: Description: Contact Point: Tail Length "G": 520 P.C. Tail Regular Point .190 (4.83) 522 P.C. Tail Regular Point .375 (9.53) 525 P.C. Tail High Point .190 (4.83) 540 Wire Wrap Regular Point .560 (14.22) 541 Wire Wrap Regular Point .750 (19.05) 545 Wire Wrap High Point .560 (14.22) 560 Make Before Break (MBB) Contacts Contact Rows: Description: 1 Single Row 2 Dual Row Insulator Options: Description: 01 .550” (13.97mm) www.edac.net .190(4.83) PROPOSED IN-CONTACT POLARIZING KEY P/N 725-240-328 Ordering Code Notes: 1) All connector sizes up to 75 contacts single row / 150 contacts dual row are available upon request. 2) Make-Before-Break switching contacts, assembled in specific contact positions, are available upon request. customerservice@edac.net 725 SERIES Press-Fit Card Edge Connectors 0.100” (2.54mm) Pitch "C" .420 (10.67) CARD SLOT "D" .350 (8.89) .230 (5.84) CONTACT POINT CARD SLOT ACCEPTS .054(1.37) TO .070 (1.78) THICK P.C. BOARD CODE 101 CODE 201 Single Row Versions May Require Backup Springs Depending upon the Application. "Y" .550 (13.97) .100 (2.54) "Y" MAKE BEFORE BREAK (M.B.B) POINT CONTACTS "G" ±0.020" .025 (0.64) SQUARE P.C. & WIRE WRAP TAILS .100 (2.54) RECOMMENDED DAUGHTER BOARD "E" .535 (13.59) KEY CUT OUTS BOARD TAB .440 (11.18) .300 (7.62) .200 (5.08) .050 (1.27) CUT OUT FOR BETWEEN CONTACT POLARIZING KEY +.000 ( "D" MINUS .012 (0.30) -.015 (0.38) .080 (2.03) CUT OUT FOR IN-CONTACT POLARIZING KEY .200 (5.08) ROW SPACING .040 (1.02) DIA ± .003 (0.08) SEE NOTE BELOW .008 (0.20) DIA .100 (2.54) "E" TO OBTAIN OPTIMUM COMPLIANT SECTION PERFORMANCE, DRILL HOLES .0453 ± .001 (1.15 ± 0.03) DIAMETER COPPER PLATE, .001 (25.4 MICRONS) MINIMUM THICKNESS, FOLLOWED BY TIN PLATE TO PROVIDE FINISHED HOLES .040 ± .003 (1.02 ± 0.08) DIAMETER RECOMMENDED MOTHER BOARD HOLE PATTERN NUMBER OF CONTACTS "C" "D" "E" Single Double Inch mm Inch mm Inch mm 5 10 0.760 19.30 0.600 15.24 0.400 10.16 10 20 1.260 32.00 1.100 27.94 0.900 22.86 15 30 1.760 44.70 1.600 40.64 1.400 35.56 18 36 2.060 52.32 1.900 48.26 1.700 43.18 22 44 2.460 62.48 2.300 58.42 2.100 53.34 25 50 2.760 70.10 2.600 66.04 2.400 60.96 28 56 3.060 77.72 2.900 73.66 2.700 68.58 30 60 3.260 82.80 3.100 78.74 2.900 73.66 31 62 3.360 85.34 3.200 81.28 3.000 76.20 35 70 3.760 95.50 3.600 91.44 3.400 86.36 36 72 3.860 98.04 3.700 93.98 3.500 88.90 43 86 4.560 115.82 4.400 111.76 4.200 106.68 50 100 5.260 133.60 5.100 129.54 4.900 124.46 75 150 7.760 197.10 7.600 193.04 7.400 187.96 www.edac.net customerservice@edac.net
725-048-560-201
物料型号:725系列 器件简介:0.100英寸(2.54mm)间距的Press-Fit卡边连接器,接受0.062英寸(1.57mm)厚度的PCB板。 引脚分配:0.100英寸(2.54mm)接触间距 x 0.200英寸(5.08mm)行间距。 参数特性:包括绝缘体材料、接触材料、接触镀层、电流额定值、接触电阻、介电强度、绝缘电阻、操作温度范围、插入力、拔出力、接触插入力和保持力、可重插次数等。 功能详解:提供了连接器的安装工具信息、RoHS合规性和UL认证。 应用信息:可用于单排或双排配置,接受接触和接触间极化键(如果需要特殊功能)。 封装信息:提供了订购代码说明和推荐的女儿板设计。
725-048-560-201 价格&库存
很抱歉,暂时无法提供与“725-048-560-201”相匹配的价格&库存,您可以联系我们找货
  • 25+63.0007125+7.88264
  • 1+73.988281+9.25740
  • 10+66.6249410+8.33610
  • 25+61.3907525+7.68120
  • 50+60.5036050+7.57020
  • 100+56.33400100+7.04850
  • 250+52.96283250+6.62670
  • 500+50.92239500+6.37140
  • 1000+48.083511000+6.01620
