408-035-522-222
408-035-522-222
    P=2.54mm
    408 SERIES METAL TO METAL 2 PIEC
408-035-522-222 数据手册
408/424 SERIES METAL TO METAL CARD EDGE CONNECTORS Features: • • • • • • • • 0.200” (5.08mm) contact spacing x 0.125” (3.18mm) or 0.150” (3.81mm) row spacing with staggered grid Accepts 0.062” (1.57mm) or 0.093” (2.36mm) nominal thickness P.C. board Edacon hermaphroditic contact mating design Contact termination options include P.C. tail, fork tail, wire hole and wire wrap Open or closed card slot ends, card guides optional Accepts polarizing keys without loss of contact position 408 series without card guides designed to mate with 421 Series, 408 Series with card guides designed to mate with 422 Series, 424 Series designed to mate with 423 Series RoHS Compliant Specifications: Insulator Material UL 94V-0 Diallyl Phthalate, Green Color Contact Material Copper Alloy Contact Plating Gold Plating over Nickel over entire contact Current Rating 10 amps Contact Resistance 10 milliohms maximum Dielectric Withstanding Voltage 2000 V AC rms at sea level Insulation Resistance 5000 megaohms minimum Operating Temperature -65°C to +125°C Insertion Force 2 to 16 oz (0.56 to 4.45 N) per contact position Withdrawal Force 2 to 16 oz (0.56 to 4.45 N) per contact position 424-041-500-112 Contact Code: Description: Tail Size: Tail Length "G": 500 Wire Hole .115 x .025 (2.92 x 0.64) .326 (8.28) Total Number of Contacts 502 Fork Tail .115 x .025 (2.92 x 0.64) .168 (4.27) Contact Code 520 P.C. Tail .044 x .025 (1.12 x 0.64) .123 (3.12) Card Slot Width and Mounting Options 521 P.C. Tail .044 x .025 (1.12 x 0.64) .154 (3.91) 522 P.C. Tail .044 x .025 (1.12 x 0.64) .186 (4.72) 523 P.C. Tail .044 x .025 (1.12 x 0.64) .123 (3.12) .154 (3.91) Example Part Number: Series Series: Insulator Color: 524 P.C. Tail .044 x .025 (1.12 x 0.64) 408 Closed Card Slot Ends 525 P.C. Tail .044 x .025 (1.12 x 0.64) .186 (4.72) 424 Open Card Slot Ends per Mil-C-21097 540 Wire Wrap .060 x .025 (1.52 x 0.64) .744 (18.90) Total Number of Contacts: 541 Wire Wrap .060 x .025 (1.52 x 0.64) .744 (18.90) 017, 023, 029, 035, 041 or 047 542 Wire Wrap .060 x .025 (1.52 x 0.64) .965 (24.51) Ordering Code Notes: 1) Contact Codes 523, 524 and 525 are designed for 0.150” (3.81mm) row spacing connectors. 2) Contact code 540 has a wire hole at the tip of the tail. 3) Mounting options 212 and 222 are available on the 408 series connectors only. www.edac.net Card Slot Width: Mounting Options: Description: 112 Accepts .062(1.57) Board .128(3.25)Dia.Mounting Holes 122 Accepts .093(2.36) Board .128(3.25)Dia.Mounting Holes 212 Accepts .062(1.57) Board .128(3.25)Dia.Mounting Holes With Card Guides 222 Accepts .093(2.36) Board .128(3.25)Dia.Mounting Holes With Card Guides customerservice@edac.net 408/424 SERIES METAL TO METAL CARD EDGE CONNECTORS NUMBER OF CONTACTS "A" "B" 408 424 "D" 408 424 "E" 408 "F" 408, 424 424 inch mm inch mm inch mm inch mm inch mm inch mm inch mm 17 2.406 61.11 2.570 65.28 2.134 54.20 2.300 58.42 1.920 48.77 1.600 40.64 1.900 48.26 23 3.006 76.35 3.170 80.52 2.734 69.44 2.900 73.66 2.520 64.01 2.200 55.88 2.500 63.50 29 3.606 91.59 3.770 95.76 3.334 84.68 3.500 88.90 3.120 79.25 2.800 71.12 3.100 78.74 35 4.206 106.83 4.370 111.00 3.934 99.92 4.100 104.14 3.720 94.49 3.400 86.36 3.700 93.98 41 4.806 122.07 4.970 126.24 4.534 115.16 4.700 119.38 4.320 109.73 4.000 101.60 4.300 109.22 www.edac.net customerservice@edac.net
408-035-522-222
物料型号:EDAC cardEDGE
器件简介:该系列连接器具有0.200英寸(5.08mm)的接触间距和0.125英寸(3.18mm)或0.150英寸(3.81mm)的行间距,采用错位网格设计。
引脚分配:接受0.062英寸(1.57mm)或0.093英寸(2.36mm)标称厚度的PCB板。
参数特性: - 绝缘体材料:UL 94V-0二丙酸二丁酯,绿色 - 接触材料:铜合金 - 接触镀层:整个接触上的金镀层覆盖镍 - 电流额定值:10安培 - 接触电阻:最大10毫欧姆 - 介质耐压:海平面上2000V交流有效值 - 绝缘电阻:最小5000兆欧姆 - 工作温度:-65°C至+125°C - 插入力:每个接触位置2至16盎司(0.56至4.45N) - 拔出力:每个接触位置2至16盎司(0.56至4.45N)
功能详解:连接器设计为雌雄同体接触,提供多种接触终止选项,包括PCB尾、叉尾、线孔和绕线。可选的开闭卡槽端和卡导轨。
应用信息:408系列无卡导轨设计用于与421系列配合,408系列带卡导轨设计用于与422系列配合,424系列设计用于与423系列配合。
封装信息:提供了详细的连接器安装模式和尺寸信息。
408-035-522-222 价格&库存
很抱歉,暂时无法提供与“408-035-522-222”相匹配的价格&库存,您可以联系我们找货
