421/422/423 SERIES
METAL TO METAL CARD EDGE CONNECTORS
Features:
0.200” (5.08mm) contact spacing x 0.300” (7.62mm) row spacing with staggered grid
Mount into 0.062” (1.57mm) or 0.093” (2.36mm) nominal thickness P.C. board by soldering and/or
staking of P.C. tails
Edacon hermaphroditic contact mating design
Mounting hole and guide pin options
421 Series designed to mate with non-card guide versions of 408 or 415 Series, 422 Series designed
to mate with card guide versions of 408 or 415 Series, 423 Series designed to mate with 424 or 438
Series
RoHS Compliant
Specifications:
Insulator Material
UL 94V-0 Diallyl Phthalate, Green Color
Contact Material
Copper Alloy
Contact Plating
Gold Plating over Nickel over entire contact
Current Rating
10 amps
Contact Resistance
10 milliohms maximum
Dielectric Withstanding Voltage
2000 V AC rms at sea level
Insulation Resistance
5000 megaohms minimum
Operating Temperature
-65°C to +125°C
Insertion Force
2 to 16 oz (0.56 to 4.45 N) per contact position
Withdrawal Force
423-041-520-102
Contact Code:
Tail Description:
Tail Size:
Tail Length "G":
520
P.C. Tail
.044 x .025 (1.12 x 0.64)
.122 (3.10)
Total Number of Contacts
521
P.C. Tail
.153 (3.89)
Contact Code
Code:
Insulator Mounting Option:
Card Slot Width and Mounting Options
100
No Mounting Holes (422 Series)
102
.128 (3.25) Dia. Mounting Holes (421 Series)
.128 (3.25) Dia. Mounting Holes and Guide Pins as per MIL-C-21097 (423 Series)
Example Part Number:
Series
Series:
421
422
423
Total Number of Contacts:
017, 023, 029, 035, 041 or 047
www.edac.net
customerservice@edac.net
421/422/423 SERIES
NUMBER
OF
CONTACTS
"A"
"B"
408
424
"D"
408
424
"E"
408
"F"
408, 424
424
inch
mm
inch
mm
inch
mm
inch
mm
inch
mm
inch
mm
inch
mm
17
2.406
61.11
2.570
65.28
2.134
54.20
2.300
58.42
1.920
48.77
1.600
40.64
1.900
48.26
23
3.006
76.35
3.170
80.52
2.734
69.44
2.900
73.66
2.520
64.01
2.200
55.88
2.500
63.50
29
3.606
91.59
3.770
95.76
3.334
84.68
3.500
88.90
3.120
79.25
2.800
71.12
3.100
78.74
35
4.206
106.83
4.370
111.00
3.934
99.92
4.100
104.14
3.720
94.49
3.400
86.36
3.700
93.98
41
4.806
122.07
4.970
126.24
4.534
115.16
4.700
119.38
4.320
109.73
4.000
101.60
4.300
109.22
www.edac.net
很抱歉,暂时无法提供与“422-023-521-100”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 25+238.6946825+30.93938
