438-029-500-112
438-029-500-112
    P=5.08mm
    CONN EDGE DUAL FMALE 29POS 0.200
438-029-500-112 数据手册
415/438 SERIES METAL TO METAL CARD EDGE CONNECTORS Features: • • • • • • • • 0.200” (5.08mm) contact spacing x 0.125” (3.18mm) row spacing with staggered grid Accepts 0.062” (1.57mm) or 0.093” (2.36mm) nominal thickness P.C. board Edacon hermaphroditic contact mating design Contact termination options include crimp, P.C. tail, wire hole and wire wrap Open or closed card slot ends, card guides optional Accepts polarizing keys without loss of contact position 415 Series without card guides designed to mate with 421 Series, 415 Series with card guides designed to mate with 422 Series, 438 Series designed to mate with 423 Series RoHS Compliant Specifications: Insulator Material UL 94V-0 Diallyl Phthalate, Green Color Contact Material Copper Alloy Contact Plating Gold Plating over Nickel over entire contact Current Rating 10 amps Contact Resistance 10 milliohms maximum Dielectric Withstanding Voltage 2000 V AC rms at sea level Insulation Resistance 5000 megaohms minimum Operating Temperature -65°C to +125°C Insertion Force 2 to 16 oz (0.56 to 4.45 N) per contact position Withdrawal Force 2 to 16 oz (0.56 to 4.45 N) per contact position 415-035-500-212 Code: Card Slot Width: Mounting Options: 112 Accepts .062(1.57) Board .128(3.25)Dia.Mounting Holes Total Number of Contacts 122 Accepts .093(2.36) Board .128(3.25)Dia.Mounting Holes Contact Code 212 Accepts .062(1.57) Board .128(3.25)Dia.Mounting Holes With Card Guides 222 Accepts .093(2.36) Board .128(3.25)Dia.Mounting Holes With Card Guides Example Part Number: Series Card Slot Width and Mounting Options Series: Insulator Color: 415 Closed Card Slot Ends 438 Open Card Slot Ends Total Number of Contacts: 017, 023, 029, 035, 041 or 047 Contact Code: Tail Description: 000 No Contacts Assembled 500 Wire Hole .110 x .024 (2.79 x 0.61) .245 (6.22) 520 P.C. Tail .025 x .024 (0.64 x 0.61) .215 (5.46) 540 Wire Wrap .050 x .024 (1.27 x 0.61) .600 (15.24) 541 Wire Wrap .026 x .024 (0.66 x 0.61) .620 (15.70) 542 Wire Wrap .050 x .024 (1.27 x 0.61) .790 (20.07) www.edac.net Tail Size: Tail Length "G": Ordering Code Notes: Crimp contacts are also available for the 415 and 438 series connectors. Contacts may be ordered separately for pre-wired or select position assembly. Part Number Description Silhouette 516-290-500 Wire Hole 516-290-520 P.C. Tail 516-290-540 Wire Wrap 516-290-541 Wire Wrap 516-290-542 Wire Wrap 516-290-590 Crimp (Loose) 516-294-571 Crimp - 1800 Contact Per Reel For contact installation, removal and crimping tools, Please contact EDAC. Mounting Options 212 and 222 are available on the 415 series connectors only. customerservice@edac.net 415/438 SERIES METAL TO METAL CARD EDGE CONNECTORS NUMBER OF CONTACTS "A" "B" 415 438 415 438 "D" "E" "F" 415 415, 438 438 inch mm inch mm inch mm inch mm inch mm inch mm inch mm 17 2.406 61.11 2.570 65.28 2.134 54.20 2.300 58.42 1.920 48.77 1.600 40.64 1.900 48.26 23 3.006 76.35 3.170 80.52 2.734 69.44 2.900 73.66 2.520 64.01 2.200 55.88 2.500 63.50 29 3.606 91.59 3.770 95.76 3.334 84.68 3.500 88.90 3.120 79.25 2.800 71.12 3.100 78.74 35 4.206 106.83 4.370 111.00 3.934 99.92 4.100 104.14 3.720 94.49 3.400 86.36 3.700 93.98 41 4.806 122.07 4.970 126.24 4.534 115.16 4.700 119.38 4.320 109.73 4.000 101.60 4.300 109.22 47 5.620 142.75 5.570 141.48 5.352 135.94 5.300 134.62 5.030 127.76 4.600 116.84 4.900 124.46 www.edac.net customerservice@edac.net
438-029-500-112
物料型号:415/438系列
器件简介: - 0.200英寸(5.08mm)接触间距 x 0.125英寸(3.18mm)行间距,交错网格布局 - 接受0.062英寸(1.57mm)或0.093英寸(2.36mm)名义厚度的PCB板 - Edacon双性接触配对设计 - 接触终止选项包括压接、PCB尾、线孔和绕线
引脚分配: - 引脚分配示例:415-035-500-212,其中035表示总接触数为35
参数特性: - 绝缘体材料:UL 94V-0二丙烯酸二丁酯,绿色 - 接触材料:铜合金 - 接触镀层:整个接触上的金镀层覆盖镍 - 电流额定值:10安培 - 接触电阻:最大10毫欧姆 - 介质耐压:海平面2000V交流有效值 - 绝缘电阻:最小5000兆欧姆 - 工作温度:-65°C至+125°C - 插入力:每个接触位置2至16盎司(0.56至4.45N) - 拔出力:每个接触位置2至16盎司(0.56至4.45N)
功能详解: - 415系列无卡槽导向设计用于与421系列配合 - 415系列带卡槽导向设计用于与422系列配合 - 438系列设计用于与423系列配合 - 符合RoHS标准
应用信息: - 可用于需要极化键的应用,且不会损失接触位置
封装信息: - 绝缘体颜色:415系列为封闭卡槽端,438系列为开放卡槽端 - 订购代码注释:压接接触也适用于415和438系列连接器。接触可以单独订购,用于预接线或选择位置组装。
438-029-500-112 价格&库存
很抱歉,暂时无法提供与“438-029-500-112”相匹配的价格&库存,您可以联系我们找货
