627M/628M SERIES
Machined D-Sub Connectors: Vertical
Features:
Standard density, straight D-Sub with machined contacts
0.109”(2.77mm) contact spacing x 0.112”(2.84mm) row spacing
Plug and receptacle in 9, 15, 25, 37 or 50 contact sizes
Pin and socket contact mating design with P.C. tail, and solder cup termination
Metal shell provides EMI/RFI shielding, plug shell indents provide grounding and additional mating
retention
Grounding features include boardlock for exceptional retention to P.C. board
Mounting options for panel mount or connector mating include through hole, threaded inserts and
threaded standoffs
Insulation housings are offered in different colors: black, white, green and blue
D-shaped connector mating outline provides polarization
Specifications:
Insulator Material
PA6T, UL 94V-0, Color: Black, White, Blue or Green
Contact Material
Precision Machined Copper Alloy
Contact Plating
Gold Plating over Nickel All Over
Shell Material
Nickel Plated Steel (Optional Tin Plating)
Current Rating
5 amps
Contact Resistance
10 Milliohms maximum
Dielectric Withstanding Voltage
5000 megaohms minimum
Insulation Resistance
1000 V AC rms at Sea Level
Operating Temperature
-55°C To +125°C
Ordering Code:
627-M25-220-BN3
SERIES:
627: PLUG (PIN)
628: RECEPTACLE (SOCKET)
MOUNTING & GROUNDING OPTIONS:
1 - Ø.120"(Ø3.05MM) THROUGH HOLE
2 - 4-40 UNC, 2.7MM THREADED INSERT
M: MACHINED CONTACTS
(NOTE: CODES 3, 4, 5, & 6 ARE FOR PC TAIL ONLY)
3 - 4-40 UNC THREADED BOARDSPACER
4 - 4-40 UNC THREADED STANDOFF WITH
5 - 4-40 UNC THREADED BOARDSPACER
WITH BOARDLOCKS
6 - 4-40 UNC THREADED STANDOFF WITH
BOARDSPACER & BOARDLOCKS
NO. OF CONTACTS:
09 - 9 CONTACTS 25 - 25 CONTACTS
15 - 15 CONTACTS 37 - 37 CONTACTS
50 - 50 CONTACTS
CONTACT FINISH CODE:
2 - GOLD FLASH PLATING
3 - 15 MICROINCHES OF GOLD PLATING
6 - 30 MICROINCHES OF GOLD PLATING
CONTACT CODE:
20 - .224"(5.70mm) PC TAIL (ONLY FOR PLUG)
21 - .232"(5.90mm) PC TAIL (ONLY FOR RECEPTACLE)
22 - SOLDER CUP TAIL
23 - .495".(12.57mm) PC TAIL
www.edac.net
SHELL PLATING CODE:
N - NICKEL
T - TIN
HOUSING MATERIAL CODE:
B - BLACK
W - WHITE
G - GREEN
L - BLUE
customerservice@edac.net
627M/628M SERIES
CODE - 1
Ø3.05 Through Hole
www.edac.net
CODE - 2
#4-40 UNC, 2.7mm Threaded Insert
627M/628M SERIES
CODE - 3
#4-40 UNC Threaded Boardspacer
CODE - 4
#4-40 UNC Threaded Standoff with
CODE - 5
#4-40 UNC Threaded Boardspacer with
Boardlocks
CODE - 6
Boardspacer & Boardlocks
9 POS
37 POS
15 POS
50 POS
25 POS
www.edac.net
很抱歉,暂时无法提供与“627-M09-623-GT1”相匹配的价格&库存,您可以联系我们找货
