627-M25-223-GT6
627-M25-223-GT6
    627M SERIES VERTICAL D-SUB PLUG
627-M25-223-GT6 数据手册
627M/628M SERIES Machined D-Sub Connectors: Vertical Features: • • • • • • • • • Standard density, straight D-Sub with machined contacts 0.109”(2.77mm) contact spacing x 0.112”(2.84mm) row spacing Plug and receptacle in 9, 15, 25, 37 or 50 contact sizes Pin and socket contact mating design with P.C. tail, and solder cup termination Metal shell provides EMI/RFI shielding, plug shell indents provide grounding and additional mating retention Grounding features include boardlock for exceptional retention to P.C. board Mounting options for panel mount or connector mating include through hole, threaded inserts and threaded standoffs Insulation housings are offered in different colors: black, white, green and blue D-shaped connector mating outline provides polarization Specifications: Insulator Material PA6T, UL 94V-0, Color: Black, White, Blue or Green Contact Material Precision Machined Copper Alloy Contact Plating Gold Plating over Nickel All Over Shell Material Nickel Plated Steel (Optional Tin Plating) Current Rating 5 amps Contact Resistance 10 Milliohms maximum Dielectric Withstanding Voltage 5000 megaohms minimum Insulation Resistance 1000 V AC rms at Sea Level Operating Temperature -55°C To +125°C Ordering Code: 627-M25-220-BN3 SERIES: 627: PLUG (PIN) 628: RECEPTACLE (SOCKET) MOUNTING & GROUNDING OPTIONS: 1 - Ø.120"(Ø3.05MM) THROUGH HOLE 2 - 4-40 UNC, 2.7MM THREADED INSERT M: MACHINED CONTACTS (NOTE: CODES 3, 4, 5, & 6 ARE FOR PC TAIL ONLY) 3 - 4-40 UNC THREADED BOARDSPACER 4 - 4-40 UNC THREADED STANDOFF WITH THREADED BOARDSPACER 5 - 4-40 UNC THREADED BOARDSPACER WITH BOARDLOCKS 6 - 4-40 UNC THREADED STANDOFF WITH BOARDSPACER & BOARDLOCKS NO. OF CONTACTS: 09 - 9 CONTACTS 25 - 25 CONTACTS 15 - 15 CONTACTS 37 - 37 CONTACTS 50 - 50 CONTACTS CONTACT FINISH CODE: 2 - GOLD FLASH PLATING 3 - 15 MICROINCHES OF GOLD PLATING 6 - 30 MICROINCHES OF GOLD PLATING CONTACT CODE: 20 - .224"(5.70mm) PC TAIL (ONLY FOR PLUG) 21 - .232"(5.90mm) PC TAIL (ONLY FOR RECEPTACLE) 22 - SOLDER CUP TAIL 23 - .495".(12.57mm) PC TAIL www.edac.net SHELL PLATING CODE: N - NICKEL T - TIN HOUSING MATERIAL CODE: B - BLACK W - WHITE G - GREEN L - BLUE customerservice@edac.net 627M/628M SERIES Machined D-Sub Connectors: Vertical MOUNTING & GROUNDING OPTIONS: CODE - 1 Ø3.05 Through Hole www.edac.net CODE - 2 #4-40 UNC, 2.7mm Threaded Insert customerservice@edac.net 627M/628M SERIES Machined D-Sub Connectors: Vertical CODE - 3 #4-40 UNC Threaded Boardspacer CODE - 4 #4-40 UNC Threaded Standoff with Threaded Boardspacer CODE - 5 #4-40 UNC Threaded Boardspacer with Boardlocks CODE - 6 #4-40 UNC Threaded Standoff with Boardspacer & Boardlocks 9 POS 37 POS 15 POS 50 POS 25 POS www.edac.net customerservice@edac.net
627-M25-223-GT6
物料型号为627M/628M系列,是垂直安装的机加工D-Sub连接器。
以下是该PDF文档中提到的一些关键信息:
- 器件简介:标准密度,直式D-Sub连接器,具有机加工接触件,接触件间距为0.109英寸(2.77mm),行间距为0.112英寸(2.84mm)。
插头和插座有9、15、25、37或50个接触点大小。
引脚和插座接触设计带有PC尾和焊杯端接。
- 引脚分配:文档中提供了不同接触点数量的尺寸表,例如9、15、25、37和50个接触点。
- 参数特性: - 绝缘体材料:PA6T, UL 94V-0,颜色:黑色、白色、蓝色或绿色 - 接触材料:精密机加工铜合金 - 接触镀层:整体镀金,底层为镍 - 壳体材料:镀镍钢(可选锡镀层) - 电流额定值:5安培 - 接触电阻:最大10毫欧姆 - 介质耐电压:最小5000兆欧姆 - 绝缘电阻:在海平面1000V AC rms - 工作温度:-55°C至+125°C - 功能详解:金属壳体提供EMI/RFI屏蔽,插头壳体凹槽提供接地和额外的配对保持力。
接地特性包括板锁,为PCB板提供卓越的保持力。
- 应用信息:适用于需要EMI/RFI屏蔽和极化功能的垂直安装D-Sub连接器应用。
- 封装信息:绝缘体颜色有多种选择,D形连接器配合轮廓提供极化。
提供了不同的安装选项,包括通孔、螺纹嵌件和螺纹支架。
订购代码示例:627-M25-220-BN3,其中包含安装和接地选项的代码。
更多详细信息和定制选项,建议访问[EDAC网站](www.edac.net)或联系他们的客户服务。
627-M25-223-GT6 价格&库存
很抱歉,暂时无法提供与“627-M25-223-GT6”相匹配的价格&库存,您可以联系我们找货
627-M25-223-GT6
  • 2400+126.342522400+16.42145
