628-2WK2624-1T6
628-2WK2624-1T6
    CONN D-SUB RCPT 2POS VERT SLDR
628-2WK2624-1T6 数据手册
627C/628C SERIES Power Combo D-Sub Connectors: Vertical Features: • • • • • • • Signal, along with power or coaxial contacts within one connector Space saving on the PCB and I/O designs Available in various pin out configurations Pin and socket contact mating design with P.C. tail and solder cup termination Metal shell provides EMI/RFI shielding, plug shell indents provide grounding and additional mating retention Mounting options for panel mount or connector mating include through hole, threaded hole and threaded standoffs D-shaped connector mating outline provides polarization Specifications: Power/Coaxial Only Combination Insulator Material Thermoplastic Polyester, UL 94V-0, Color: Black Contact Material Copper Alloy Contact Plating Selective Gold (See Ordering Code) over Nickel for the Mating Area, Tin Plating for Tail Area Shell Material and Plating Steel, Sn or Ni Plated Shell Material Nickel Plated Steel Current Rating (Power Contacts) 10 amps, 20 amps, 30 amps, 40 amps Current Rating (Signal Contacts) 5 amps Voltage Rating 125 V Contact Resistance (Power Contacts) 1 Milliohms maximum Contact Resistance (Signal Contacts) 10 Milliohms maximum Insulation Resistance 5000 megaohms minimum Dielectric Withstanding Voltage 1000 V AC rms at Sea Level Operating Temperature -55°C To +125°C Mating Cycle 500 For 30 Microinches Gold Plating, 50 For Gold Flash Plating Ordering Code: 627-2W2-220-1N2 SERIES: 627: PLUG (PIN) 628: RECEPTACLE (SOCKET) LAYOUT: POWER/CO-AX ONLY COMBINATION 2W2 2WK2 5W1 SIZE 15 CONTACT SHELL 3W3 3WK3 7W2 11W1 SIZE 25 CONTACT SHELL 5W5 9W4 13W3 17W2 21W1 SIZE 37 CONTACT SHELL 8W8 13W6 17W5 25W3 27W2 21W4 SIZE 9 CONTACT SHELL SIZE 50 CONTACT SHELL 8W8 24W7 36W4 43W2 47W1 2WK2 TOTAL NO.OF POWER OR CO-AXCONTACT TOTAL NO.OF CONTACT MALE FEMALE COMBINATION CONTACT PLATING THICKNESS: 2 - GOLD FLASH PLATING 6 - 30 MICROINCHES OF GOLD PLATING TAIL TYPE: 22 - SOLDER CUP 24 - PC TAIL www.edac.net MOUNTING OPTIONS: 1 - THROUGH HOLE 2 - #4-40 UNC THREADED HOLE 2.70 3 - #4-40 UNC THREADED HOLE 7.40 (PC TAIL ONLY) 4 - #4-40 UNC THREADED STANDOFF (PC TAIL ONLY) 5 - #4-40 UNC THREADED HOLE WITH BOARDLOCKS (PC TAIL ONLY) 6 - #4-40 UNC THREADED STANDOFF WITH BOARDLOCKS (PC TAIL ONLY) A - M3 THREADED HOLE 2.70 B - M3 THREADED HOLE 7.40 (PC TAIL ONLY) C - M3 THREADED STANDOFF (PC TAIL ONLY) D - M3 THREADED HOLE WITH BOARDLOCKS (PC TAIL ONLY) E - M3 THREADED STANDOFF WITH BOARDLOCKS (PC TAIL ONLY) SHELL PLATING: N - NICKEL T - TIN RATING: POWER CONTACT CURRENT RATING: 1 - 10A 2 - 20A 3 - 30A 4 - 40A COAXIAL CONTACT IMPEDANCE RATING: 5 - 50 OHMS 7 - 75 OHMS customerservice@edac.net 627C/628C SERIES Power Combo D-Sub Connectors: Vertical Layout: POWER/COAXIAL D-SUB ONLY COMBINATION SIZE 9 2W2 2WK2 3W3 3WK3 5W1 SIZE 15 SIZE 25 7W2 11W1 9W4 13W3 17W2 21W1 5W5 13W6 17W5 25W3 27W2 SIZE 37 8W8 21W4 24W7 36W4 43W2 47W1 SIZE 50 www.edac.net customerservice@edac.net 627C/628C SERIES Power Combo D-Sub Connectors: Vertical STRAIGHT PCB TYPE MOUNTING OPTION CODE:2/A CODE:1 CODE:4/C CODE:3/B CODE:6/E CODE:5/D PCB LAYOUT FOR POWER D-SUB MALE AND FEMALE CONNECTOR www.edac.net CODE:2W2/2WK2 CODE:3W3/3WK3 CODE:5W5 MALE CODE:8W8 MALE CODE:5W5 FEMALE CODE:8W8 FEMALE CURRENT RATING 10A 20A 30A 40A ØA(mm) 2.2 3.3 3.7 4.2 customerservice@edac.net 627C/628C SERIES Power Combo D-Sub Connectors: Vertical Power/Coaxial D-SUB STRAIGHT PCB TYPE MOUNTING OPTION CODE:2/A CODE:1 CODE:4/C CODE:3/B CODE:6/E CODE:5/D PCB LAYOUT FOR POWER D-SUB MALE AND FEMALE CONNECTOR www.edac.net CODE:2W2/2WK2 CODE:3W3/3WK3 CODE:5W5 MALE CODE:8W8 MALE CODE:5W5 FEMALE CODE:8W8 FEMALE CURRENT RATING 10A 20A 30A 40A ØA(mm) 2.2 3.3 3.7 4.2 customerservice@edac.net 627C/628C SERIES Power Combo D-Sub Connectors: Vertical PCB LAYOUT FOR COAXIAL D-SUB MALE AND FEMALE CONNECTOR CODE:2W2/2WK2 CODE:5W5 MALE CODE:5W5 FEMALE www.edac.net CODE:3W3/3WK3 CODE:8W8 MALE CODE:8W8 FEMALE customerservice@edac.net 627C/628C SERIES Power & Coaxial Combo D-SUB Power Combo D-Sub Connectors: Vertical SOLDER CUP TYPE POWER COMBO D-SUB POWER COMBO D-SUB COAXIAL COMBO D-SUB COAXIAL COMBO D-SUB POWER D-SUB POWER D-SUB CONTACT SHELL SIZE DIMA DIMB DIMC DIMD DIME RATING ØF CONTACT SHELL SIZE DIMA DIMB DIMC DIMD DIME RATING ØF SIZE 9 30.80 25.00 16.90 12.50 8.30 10A 1.7 SIZE 9 30.80 25.00 16.30 12.50 7.90 10A 1.7 SIZE 15 39.20 33.30 25.25 12.50 8.30 20A 2.7 SIZE 15 39.20 33.30 24.60 12.50 7.90 20A 2.7 SIZE 25 53.05 47.05 38.95 12.50 8.30 30A 3.5 SIZE 25 53.05 47.05 38.40 12.50 7.90 30A 3.5 SIZE 37 69.40 63.50 55.40 12.50 11.15 40A 4.6 SIZE 37 69.40 63.50 54.80 12.50 7.90 40A 4.6 SIZE 50 67.00 61.00 52.80 15.30 11.15 SIZE 50 67.00 61.00 52.20 15.30 10.90 COAXIAL D-SUB COAXIAL D-SUB STRAIGHT PCB TYPE POWER COMBO D-SUB POWER COMBO D-SUB COAXIAL COMBO D-SUB COAXIAL COMBO D-SUB POWER D-SUB POWER D-SUB CONTACT SHELL SIZE DIMA DIMB DIMC DIMD DIME RATING ØF CONTACT SHELL SIZE DIMA DIMB DIMC DIMD DIME RATING ØF SIZE 9 30.80 25.00 16.90 12.50 8.30 10A 1.7 SIZE 9 30.80 25.00 16.30 12.50 7.90 10A 1.7 SIZE 15 39.20 33.30 25.25 12.50 8.30 20A 2.8 SIZE 15 39.20 33.30 24.60 12.50 7.90 20A 2.8 SIZE 25 53.05 47.05 38.95 12.50 8.30 30A 3.2 SIZE 25 53.05 47.05 38.40 12.50 7.90 30A 3.2 SIZE 37 69.40 63.50 55.40 12.50 11.15 40A 3.75 SIZE 37 69.40 63.50 54.80 12.50 7.90 40A 3.75 SIZE 50 67.00 61.00 52.80 15.30 11.15 SIZE 50 67.00 61.00 52.20 15.30 10.90 COAXIAL D-SUB COAXIAL D-SUB SOLDER CUP TYPE MOUNTING OPTION CODE:1 www.edac.net CODE:A customerservice@edac.net 627C/628C SERIES Power Combo D-Sub Connectors: Vertical Power & Coaxial Combo D-SUB STRAIGHT PCB TYPE MOUNTING OPTION CODE:1 CODE:2/A CODE:3/B CODE:4/C CODE:5/D CODE:6/E www.edac.net customerservice@edac.net 627C/628C SERIES Power Combo D-Sub Connectors: Vertical Power Combo D-SUB Power Combo D-SUB PCB LAYOUT FOR MALE AND FEMALE CONNECTOR CODE:5W1 MALE/FEMALE CODE:24W7 MALE/FEMALE CODE:7W2 MALE/FEMALE CODE:21W4 MALE/FEMALE CODE:27W2 MALE/FEMALE CODE:11W1 MALE/FEMALE CODE:21W1 MALE/FEMALE CODE:17W2 MALE/FEMALE www.edac.net CUREENT RATING 10A 20A 30A 40A ØA(mm) 2.2 3.3 3.7 4.2 customerservice@edac.net 627C/628C SERIES Power Combo D-Sub Connectors: Vertical Power Combo D-SUB Power Combo D-SUB PCB LAYOUT FOR MALE CONNECTOR CODE:25W3 MALE CODE:9W4 MALE CODE:36W4 MALE CODE:13W3 MALE CODE:43W2 MALE CODE:13W6 MALE CODE:47W1 MALE CODE:17W5 MALE www.edac.net CUREENT RATING 10A 20A 30A 40A ØA(mm) 2.2 3.3 3.7 4.2 customerservice@edac.net 627C/628C SERIES Power Combo D-Sub Connectors: Vertical Power Combo D-SUB PCB LAYOUT FOR FEMALE CONNECTOR CODE:25W3 FEMALE CODE:9W4 FEMALE CODE:36W4 FEMALE CODE:13W3 FEMALE CODE:43W2 FEMALE CODE:13W6 FEMALE CODE:47W1 FEMALE CODE:17W5 FEMALE www.edac.net CUREENT RATING 10A 20A 30A 40A ØA(mm) 2.2 3.3 3.7 4.2 customerservice@edac.net 627C/628C SERIES Power Combo D-Sub Connectors: Vertical STRAIGHT PCB TYPE MOUNTING OPTION CODE:2/A CODE:1 CODE:4/C CODE:3/B CODE:6/E CODE:5/D PCB LAYOUT FOR POWER D-SUB MALE AND FEMALE CONNECTOR www.edac.net CODE:2W2/2WK2 CODE:3W3/3WK3 CODE:5W5 MALE CODE:8W8 MALE CODE:5W5 FEMALE CODE:8W8 FEMALE CURRENT RATING 10A 20A 30A 40A ØA(mm) 2.2 3.3 3.7 4.2 customerservice@edac.net 627C/628C SERIES Power Combo D-Sub Connectors: Vertical Coaxial Combo D-SUB www.edac.net customerservice@edac.net 627C/628C SERIES Power Combo D-Sub Connectors: Vertical Coaxial Combo D-SUB www.edac.net customerservice@edac.net 627C/628C SERIES Power Combo D-Sub Connectors: Vertical Coaxial Combo D-SUB www.edac.net customerservice@edac.net
628-2WK2624-1T6
1. 物料型号:627C/628C系列,其中627代表插头(PIN),628代表插座(SOCKET)。
2. 器件简介:这些连接器可以在一个连接器内同时传输信号、电源或同轴接触。它们节省了PCB和I/O设计的空间,并且提供了多种引脚配置。金属壳体提供EMI/RFI屏蔽,插头壳体的凹槽提供接地和额外的配对保持力。
3. 引脚分配:提供了不同尺寸的接触壳,例如SIZE 9、15、25、37和50,以及不同的布局配置,例如2W2、2WK2、5W1等。
4. 参数特性:包括绝缘材料、接触材料、接触镀层、壳体材料和镀层、电流等级、电压等级、接触电阻、绝缘电阻、耐电压、工作温度范围和配对周期等。
5. 功能详解:提供了详细的安装选项,包括通孔、螺纹孔和螺纹支架,以及D形连接器配对轮廓以提供极化。
6. 应用信息:适用于需要垂直安装电源和同轴组合D-SUB的应用场景。
7. 封装信息:提供了详细的PCB布局信息,包括男性和女性连接器的布局代码和尺寸。
628-2WK2624-1T6 价格&库存
很抱歉,暂时无法提供与“628-2WK2624-1T6”相匹配的价格&库存,您可以联系我们找货
628-2WK2624-1T6
  • 200+81.96628200+10.65315
