243-003-542-101
243-003-542-101
    插件,P=5.08mm
    CONN EDGE SINGLE FMALE 3POS .200
243-003-542-101 数据手册
ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. ORIGINAL 1 0.592 15.04 Features x.200 (5.08) Contact Spacing x .200 (5.08) Row Spacing xAccepts .062 (1.57) Nominal Thickness P.C. Board xHigh Profile Insulator Body .656 (16.66) xInsulating Bushings Press into Metal Backplane xModular Design Permits any Connector Length Assembly xContact Termination .045 (1.14) Square Wire Wrap xAccepts Between Contact and In-Contact Polarizing Keys 0.392 9.96 0.370 9.40 Card Slot 0.240 6.10 Point of Contact 0.656 16.66 0.650 16.51 0.188 4.78 Specifications xInsulator Material: Thermoplastic Polyester, UL94V-0, Colour: White xContact Material: Phosphor Bronze Alloy CA-510 xContact Plating: Gold over Nickel for Entire Contact xCurrent Rating: 5 Amperes Continuous xContact Resistance: 10 Milliohms Maximum xDielectric Withstanding Voltage: 1800 V AC rms at Sea Level Between Contacts xInsulation Resistance: 5000 Megohms Minimum xOperating Temperature: -65 to +105 Degrees C xInsertion Force: 16 oz (4.45 N) Maximum per Contact Pair when Tested with a .070 (1.78) Thick Gauge xWithdrawal Force: 1 oz (0.28 N) Minimum per Contact Pair when Tested with a .054 (1.37) Thick Gauge 0.200 5.08 243 Series Card Edge Connector Part Number: 243-003-542-101 EDAC INC TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. ACAD REFERENCE NO. DRAWN: J.LEE 243-ENG MASTER DATE: AUG 25/09 CHECKED: DATE: SCALE: SHEET 1 DRAWING NUMBER 243-ENG MASTER OF 1 ISSUE 1
243-003-542-101 价格&库存
很抱歉,暂时无法提供与“243-003-542-101”相匹配的价格&库存,您可以联系我们找货
