305-018-520-558
305-018-520-558
    插件,P=3.96mm
    305 SERIES (.156" (3.96MM) CONTA
305-018-520-558 数据手册
Mounting Option 58-.468 (11.89) Offset Card Guides Contact Detail 520-P.C. Tail .046x.013(1.17x0.33) - Tail LG.=.213(5.41) .156 [3.96] Contact Spacing x .140 [3.56] Row Spacing ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. ORIGINAL 1 0.343 8.71 Card Slot Accepts .054 (1.37) to .070 (1.78) Thick P.C. Board 0.156 3.96 1.568 39.83 1.714 43.54 0.330 8.38 Card Slot 2.000 50.80 2.846 72.29 0.460 11.68 A A 305 / 315 / 355 Card Edge Connector Part Number: 305-018-520-558 See Accompanying Page for: • Mounting Options SECTION A-A 0.125 3.18 Point of Contact 2.310 58.67 EDAC INC TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. ACAD REFERENCE NO. J.LEE DRAWN: CHECKED: SCALE: NTS DRAWING NUMBER 305 Assembly 305 ENG MASTER DATE: SEPT. 21/09 DATE: SHEET 1 OF 2 ISSUE 1 0.125 3.18 Code x01 Code x12 ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. ORIGINAL 1 .128 [3.25] Dia Through Holes .128 [3.25] Dia Through Holes 0.468 11.89 0.344 8.74 0.125 3.18 0.060 1.52 Code x02 0.116 2.95 I.D. Floating Eyelets 0.090 2.29 0.250 6.35 Dia. .010 [0.25] Radial Float 2.750 69.85 Code x03 2.500 63.50 0.328 8.33 0.005 0.13 1.550 39.37 .156 [3.96] Dia Through Holes 0.250 6.35 Code x04 M3-0.5 Metric Threaded Insert #4-40 UNC Threaded Insert Code x68 305 / 315 / 355 Card Edge Connector Mounting Options EDAC INC Code x08 0.250 6.35 0.242 6.15 0.423 10.74 Code x58 Code x07 0.250 6.35 TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. Code x78 ACAD REFERENCE NO. J.LEE DRAWN: CHECKED: SCALE: NTS DRAWING NUMBER 305 Assembly 305 ENG MASTER DATE: SEPT. 21/09 DATE: SHEET 2 OF 2 ISSUE 1
305-018-520-558
1. 物料型号:文档中提到了“305 / 315 / 355 Card Edge Connector”,并且给出了具体的部件型号“305-018-520-558”。
2. 器件简介:文档中没有直接提供器件的简介,但根据上下文推测,该文档描述的是一种卡边缘连接器,具有不同的安装选项和详细的接触点规格。
3. 引脚分配:文档中提到了接触点的详细规格,例如“520-P.C. Tail”,以及接触点间距“.156 [3.96] Contact Spacing x .140 [3.56] Row Spacing”。
4. 参数特性:文档列出了多种参数,包括接触点的尺寸、PCB板的厚度(“Card Slot Accepts .054 (1.37) to .070 (1.78) Thick P.C. Board”)、以及不同代码的通孔直径和尺寸。
5. 功能详解:文档中没有直接提供功能详解,但通过提供的规格和安装选项可以推断该连接器的功能特性。
6. 应用信息:文档中没有明确提供应用信息,但根据连接器的规格和设计,可以推测它可能用于需要高密度连接的电子设备中。
7. 封装信息:文档中提供了多种安装选项和尺寸信息,但没有直接提到封装信息。然而,可以根据提供的图纸和规格推断封装的物理特性。
305-018-520-558 价格&库存
很抱歉,暂时无法提供与“305-018-520-558”相匹配的价格&库存,您可以联系我们找货
