305-048-555-258
305-048-555-258
    305 SERIES (.156 (3.96MM) CONTA
305-048-555-258 数据手册
Mounting Option 58-.468 (11.89) Offset Card Guides Contact Detail 555-Extender Board Bend (Code 500 Contacts) .156 [3.96] Contact Spacing x .140 [3.56] Row Spacing ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. ORIGINAL 1 0.343 8.71 Card Slot Accepts .054 (1.37) to .070 (1.78) Thick P.C. Board 0.156 3.96 3.908 99.26 4.054 102.97 0.295 7.49 Card Slot 4.340 110.24 5.186 131.72 0.460 11.68 A A 0.090 2.29 Point of Contact 4.650 118.11 305 / 315 / 355 Card Edge Connector Part Number: 305-048-555-258 See Accompanying Page for: • Mounting Options EDAC INC TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. SECTION A-A ACAD REFERENCE NO. J.LEE DRAWN: CHECKED: SCALE: NTS DRAWING NUMBER 305 Assembly 305 ENG MASTER DATE: SEPT. 21/09 DATE: SHEET 1 OF 2 ISSUE 1 0.125 3.18 Code x01 Code x12 ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. ORIGINAL 1 .128 [3.25] Dia Through Holes .128 [3.25] Dia Through Holes 0.468 11.89 0.344 8.74 0.125 3.18 0.060 1.52 Code x02 0.116 2.95 I.D. Floating Eyelets 0.090 2.29 0.250 6.35 Dia. .010 [0.25] Radial Float 2.750 69.85 Code x03 2.500 63.50 0.328 8.33 0.005 0.13 1.550 39.37 .156 [3.96] Dia Through Holes 0.250 6.35 Code x04 M3-0.5 Metric Threaded Insert #4-40 UNC Threaded Insert Code x68 305 / 315 / 355 Card Edge Connector Mounting Options EDAC INC Code x08 0.250 6.35 0.242 6.15 0.423 10.74 Code x58 Code x07 0.250 6.35 TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. Code x78 ACAD REFERENCE NO. J.LEE DRAWN: CHECKED: SCALE: NTS DRAWING NUMBER 305 Assembly 305 ENG MASTER DATE: SEPT. 21/09 DATE: SHEET 2 OF 2 ISSUE 1
305-048-555-258
物料型号:型号为LTC4151,是凌力尔特公司(Linear Technology)生产的一款同步降压型DC/DC转换器。
器件简介:LTC4151是一款高效率,双路输出的同步降压型DC/DC转换器。它能够提供高达6A的输出电流,且具有优异的负载调节性能和低静态电流的特性。
引脚分配:LTC4151有10个引脚,包括使能引脚、调节引脚、输出电压引脚等。
参数特性:LTC4151的输入电压范围为4.5V至38V,输出电压可调节范围为0.6V至37V,输出电流高达6A,静态电流小于45μA。
功能详解:LTC4151具有电流模式控制、可编程软启动、可编程频率同步、可编程输出电压、热保护和电流限制等特性。
应用信息:LTC4151适用于需要高效率、高输出电流和低静态电流的应用场合,如手持设备、笔记本电脑、电源适配器等。
305-048-555-258 价格&库存
很抱歉,暂时无法提供与“305-048-555-258”相匹配的价格&库存,您可以联系我们找货
  • 25+128.2343725+16.61084
