305-078-520-203
305-078-520-203
    305 SERIES (.156" (3.96MM) CONTA
305-078-520-203 数据手册
Mounting 0.500 Option 12.70 03-.116 (2.95) I.D. Floating Eyelets Contact Detail 520-P.C. Tail .046x.013(1.17x0.33) - Tail LG.=.213(5.41) .156 [3.96] Contact Spacing x .140 [3.56] Row Spacing ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. ORIGINAL 1 Card Slot Accepts .054 (1.37) to .070 (1.78) Thick P.C. Board 0.156 3.96 6.248 158.70 0.295 7.49 Card Slot 6.394 162.41 6.680 169.67 0.460 11.68 A A 0.090 2.29 Point of Contact 6.990 177.55 305 / 315 / 355 Card Edge Connector Part Number: 305-078-520-203 See Accompanying Page for: • Mounting Options EDAC INC TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. SECTION A-A ACAD REFERENCE NO. J.LEE DRAWN: CHECKED: SCALE: NTS DRAWING NUMBER 305 Assembly 305 ENG MASTER DATE: SEPT. 21/09 DATE: SHEET 1 OF 2 ISSUE 1 0.125 3.18 Code x01 Code x12 ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. ORIGINAL 1 .128 [3.25] Dia Through Holes .128 [3.25] Dia Through Holes 0.468 11.89 0.344 8.74 0.125 3.18 0.060 1.52 Code x02 0.116 2.95 I.D. Floating Eyelets 0.090 2.29 0.250 6.35 Dia. .010 [0.25] Radial Float 2.750 69.85 Code x03 2.500 63.50 0.328 8.33 0.005 0.13 1.550 39.37 .156 [3.96] Dia Through Holes 0.250 6.35 Code x04 M3-0.5 Metric Threaded Insert #4-40 UNC Threaded Insert Code x68 305 / 315 / 355 Card Edge Connector Mounting Options EDAC INC Code x08 0.250 6.35 0.242 6.15 0.423 10.74 Code x58 Code x07 0.250 6.35 TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. Code x78 ACAD REFERENCE NO. J.LEE DRAWN: CHECKED: SCALE: NTS DRAWING NUMBER 305 Assembly 305 ENG MASTER DATE: SEPT. 21/09 DATE: SHEET 2 OF 2 ISSUE 1
305-078-520-203
物料型号:305-078-520-203 器件简介:305/315/355卡边连接器 引脚分配:0.156英寸(3.96mm)接触间距,0.140英寸(3.56mm)行间距 参数特性:0.500英寸(12.70mm)安装选项,0.116英寸(2.95mm)内径浮动眼圈,0.046x0.013英寸(1.17x0.33mm)尾部尺寸,尾部长度0.213英寸(5.41mm),0.295英寸(7.49mm)卡槽 功能详解:卡槽可接受0.054英寸(1.37mm)至0.070英寸(1.78mm)厚的PCB板 应用信息:EDAC公司产品,用于连接电子设备 封装信息:0.128英寸(3.25mm)直径通孔,0.125英寸(3.18mm)直径,0.060英寸(1.52mm)深度,0.010英寸(0.25mm)径向浮动,2.750英寸(69.85mm)长度,2.500英寸(63.50mm)宽度,0.328英寸(8.33mm)高度,0.005英寸(0.13mm)公差,M3-0.5公制螺纹嵌件,#4-40 UNC螺纹嵌件
请注意,以上信息是根据PDF文档内容的直接翻译和解读,可能需要结合实际应用和设计需求进一步分析。
305-078-520-203 价格&库存
很抱歉,暂时无法提供与“305-078-520-203”相匹配的价格&库存,您可以联系我们找货
  • 25+139.8533825+18.12766
