422-035-520-100
422-035-520-100
    CONN FEMALE 35POS 0.200 GOLD
422-035-520-100 数据手册
421/422/423 SERIES METAL TO METAL (TWO PIECE) CONNECTOR • FEATURES: • .200" (5.08mm) Contact Spacing x .300" (7.62mm) Row Spacing with staggered Grid • Mount into .062" (1.57mm) or .093" (2.36mm) Nominal Thickness P.C. Board by Soldering and/or Staking of P.C. Tails • Edacon Hermaphroditic Contact Mating Design • Mounting Hole and Guide Pin Options • 421 Series Designed to mate with Non-Card Guide Versions of 408 or 415 Series, 422 Series, 438 Series Designed to mate with Card Guide Versions of 408 or 415 Series, 423 Series Designed to mate with 424 or 438 Series • RoHS Compliant Specifications: Insulator Material Contact Material Contact Plating Current Rating Contact Resistance Dielectric Withstanding Voltage Insulation Resistance Operating Temperature Insertion Force Withdrawal Force Example Part Number: UL 94V-0 Diallyl Phthalate, Green Color Copper Alloy Gold Plating over Nickel over entire contact 10A Continuous 10 milliohms maximum 2000 VAC rms at sea level 5000 Megaohms minimum -65°C to +125°C 2 to 16 Oz (0.56 to 4.45N) per contact position 2 to 16 Oz (0.56 to 4.45N) per contact position 423-041-520-102 Series Total Number of Contacts Series 421 422 423 Contact Code Card Slot Width and Mounting Options Total Number of Contacts 017, 023, 029, 035, 041 or 047 Contact Code 520 521 www.edac.net Page 1 Insulator Mounting Option .128 (3.25) Dia. Mounting Holes No Mounting Holes .128 (3.25) Dia. Mounting Holes and Guide Pins as per MIL-C-21097 Description & Tail Size P.C. Tail .044 x .025 (1.12 x 0.64) P.C. Tail .044 x .025 (1.12 x 0.64) Tail Length "G" .122 (3.10) .153 (3.89) 421/422/423 SERIES METAL TO METAL (TWO PIECE) CONNECTOR NUMBER OF CONTACTS 17 23 29 35 41 47 "A" 421 inch 2.370 2.970 3.570 4.170 4.770 5.370 mm 60.20 75.44 90.68 105.92 121.16 136.40 "B" 423 inch 1.470 3.070 3.670 4.270 4.870 5.470 mm 37.34 77.98 93.22 108.46 123.70 138.94 421 inch 2.100 2.700 3.300 3.900 4.500 5.100 423 mm 53.34 68.58 83.82 99.06 114.30 129.54 inch 1.200 2.800 3.400 4.000 4.600 5.200 www.edac.net Page 2 mm 30.48 71.12 86.36 101.60 116.84 132.08 "C" 421, 422 inch 1.714 2.314 2.914 3.514 4.114 4.714 mm 43.54 58.78 74.02 89.26 104.50 119.74 "E" 421, 422, 423 inch 1.600 2.200 2.800 3.400 4.000 4.600 mm 40.64 55.88 71.12 86.36 101.60 116.84 "F" 423 inch 1.900 2.500 3.100 3.700 4.300 4.900 mm 48.26 63.50 78.74 93.98 109.22 124.46
422-035-520-100 价格&库存
很抱歉,暂时无法提供与“422-035-520-100”相匹配的价格&库存,您可以联系我们找货
