628-015-624-212
628-015-624-212
    插件
    CONN D-SUB RCPT 15POS VERT SLDR
628-015-624-212 数据手册
627/628 SERIES D-Sub Connectors: Vertical, Plastic Body Features: • • • • • • • • 0.109”(2.77mm) contact spacing x 0.112”(2.84mm) row spacing Standard profile plug and receptacle in 9, 15, 25 and 37 contact sizes Pin and socket contact mating design with P.C. tail termination Metal shell provides EMI/RFI shielding, plug shell indents provide grounding and additional mating retention Grounding features include boardlocks for exceptional retention to P.C. board Flange mounting options for panel mount or connector mating include threaded hole and threaded standoff D-shaped connector mating outline provides polarization Design based on requirements of MIL-C-24038, EIA RS-232 and RS-449 Specifications: Insulator Material Thermoplastic Polyester, UL 94V-0, Chemical Resistant, Color: Black Contact Material Plug (Pins): Brass Receptacle (Socket): Brass Contact Plating Selective Gold (See Ordering Code) over Nickel for the Mating Area, Tin Plating for Tail Area Shell Material Nickel Plated Steel (Optional Tin Plating) Current Rating 3 amps Contact Resistance 25 Milliohms maximum Insulation Resistance 5000 megaohms minimum Dielectric Withstanding Voltage 1000 V AC rms at Sea Level Operating Temperature -55°C To +85°C Insertion Force 16 oz (4.45 N) Maximum Per Contact Position Withdrawal Force 1 oz (0.28 N) Minimum Per Contact Position Ordering Code: 627-025-220-013 SERIES: 627: PLUG (PIN) 628: RECEPTACLE (SOCKET) NO. OF CONTACTS: 009 - 9 CONTACTS 025 - 25 CONTACTS 015 - 15 CONTACTS 037 - 37 CONTACTS CONTACT FINISH CODE: 2 - GOLD FLASH PLATING 3 - 15 MICROINCHES OF GOLD PLATING 6 - 30 MICROINCHES OF GOLD PLATING CONTACT CODE: 20 - .105"(2.67mm) TO .160"(4.06mm) PC TAIL 24 - .169"(4.30mm) TO .189"(4.80mm) PC TAIL 26 - PRESS FIT CONTACT www.edac.net FLANGE MOUNTING OPTIONS: 2 - #4-40 THREADED HOLE 3 - #4-40 THREADED STANDOFF 6 - #4-40 THREADED HOLE WITH BOARDLOCKS 7 - #4-40 THREADED STANDOFF WITH BOARDLOCKS PROFILE: 1 - STANDARD PROFILE SHELL PLATING: 0 - NICKEL PLATED SHELL 2 - TIN PLATED SHELL customerservice@edac.net 627/628 SERIES D-Sub Connectors: Vertical, Plastic Body PLUG 627 SERIES A B C #4-40 B 2.77 2.77±0.13 2.84 1.42 9-Ø1.10 2.84 8.36±0.25 Recommended PCB Layout (Plug and Receptacle) 6.00±0.25 TAIL LENGTH 2.10 6.00±0.25 3.65±0.25 1.385 B 6.00±0.25 12.55±0.38 1.385 2.84±0.25 Ø3.10±0.1 RECEPTACLE 628 SERIES A B D 2.84 7.90±0.13 2.77±0.13 B NUMBER OF CONTACTS A±0.38 Inch (mm) 6.00±0.25 TAIL LENGTH 2.10 6.00±0.25 5.80±0.25 1.385 3.65±0.25 12.55±0.38 #4-40 2.84±0.25 Ø3.10±0.1 B±0.25 C±0.25 PLUG D±0.13 RECEPTACLE Inch (mm) Inch (mm) Inch (mm) 9 1.213 (30.81) .984 (24.99) .666 (16.92) .643 (16.33) 15 1.543 (39.19) 1.312 (33.32) .994 (25.25) .971 (24.66) 25 2.088 (53.04) 1.852 (47.04) 1.534 (38.96) 1.534 (38.96) 37 2.729 (69.32) 2.500 (63.50) 2.182 (55.42) 2.159 (54.84) 2-Ø3.20
628-015-624-212
物料型号:627/628系列
器件简介: - 垂直塑料体D-Sub连接器 - 9、15、25和37接触点尺寸 - 符合MIL-C-24038、EIA RS-232和RS-449标准
引脚分配: - 插头(Pin)系列627和插座(Socket)系列628 - 接触点数量:9、15、25、37
参数特性: - 绝缘材料:热塑性聚酯,UL 94V-0,耐化学性,黑色 - 接触材料:黄铜 - 接触镀层:选择性金层(见订购代码),尾部区域锡镀层 - 外壳材料:镀镍钢(可选锡镀层) - 电流额定值:3安培 - 接触电阻:最大25毫欧姆 - 绝缘电阻:最小5000兆欧姆 - 耐电压:1000 V AC rms 海平面 - 工作温度:-55°C至+85°C - 插入力:每个接触位置最大16盎司(4.45牛顿) - 拔出力:每个接触位置最小1盎司(0.28牛顿)
功能详解: - 金属外壳提供EMI/RFI屏蔽 - 插头外壳凹槽提供接地和额外的配对保持力 - 板锁提供对PCB板的异常保持力 - 法兰安装选项包括螺纹孔和螺纹支架 - D形连接器配对轮廓提供极化
应用信息: - 适用于需要EMI/RFI屏蔽和极化的应用
封装信息: - 订购代码示例:627-025-220-013 - 法兰安装选项:2-#4-40螺纹孔,3-#4-40螺纹支架,6-#4-40螺纹孔带板锁,7-#4-40螺纹支架带板锁 - 接触完成代码:2-金闪镀层,3-15微英寸金镀层,6-30微英寸金镀层 - 外壳镀层:0-镀镍外壳,2-锡镀外壳 - 接触代码:20-0.105"(2.67mm)至0.160"(4.06mm)PC尾,24-0.169"(4.30mm)至0.189"(4.80mm)PC尾,26-压接接触
628-015-624-212 价格&库存
很抱歉,暂时无法提供与“628-015-624-212”相匹配的价格&库存,您可以联系我们找货
  • 50+47.4561050+6.15739
