SERIES 690 / 693
USB AND IEEE 1394
Edac series 690 USB (Universal Serial Bus) and series 693
(IEEE1394) connectors are industry-standard data transfer
devices used to interconnect computers to peripheral devices such as scanners and printers. A wide variety of
styles are available including right angle, vertical, and a
unique right angle vertical that minimizes board space.
USB products are compatible with asynchronous and
isochronous data transfer methods up to 1.2 Mbps and utilize plug and play technology. Edac manufactures both USB
and IEE1394 connectors in through-hole or SMT board
styles as well as molded cable assemblies for USB A, B,
mini-USB and IEEE variations (see cable series 628 and
table below). Edac can also manufacture USB units
stacked with RJ45s (with or without LEDs) on special order.
SPECIFICATIONS
USB 1.1 or USB 2.0 available
Minimum mating cycles: 1500 per EIA 364-09
Insulator Housing: UL 94V-0 thermoplastic
Contact Material: P Bronze (USB), Copper Alloy (1394)
Contact Plating: Gold Flash or Gold Plate over nickel
Contact Resistance: 30 milliohms maximum
Insulation Resistance: 100 megaohms minimum
Current Rating: 1 amp maximum under 30 degrees C
ORDERING CODE
Voltage Rating: 30 volts AC rms maximum
DW Voltage: 750 vac@0asl (USB), DC500 (1394)
Shield Housing: copper alloy
Mate/Un-mate: 35/10 Newtons per EIA 364-13
Temperature Range -55 to +85 degrees C
Popular styles are stocked by our authorized
distributors worldwide. Factory minimum order
quantity (MOQ) is 1,000 pieces per item.
SAMPLE PART NUMBER:
693-006-620-003
693 = Series Number: 690 = USB (1.1 or 2.0), 693 = IEEE 1394a Standard
006 = Number of contacts: 004 = single jack USB; 006 = single jack IEEE 1394a; 008 = dual stacked USB
type A; 012 = triple stacked USB type A
6 = Gold thickness: 2 = gold flash (standard for original USB). 3 = 15u gold plate (USB 1.1 only), 6 = 30u
gold plate (mandatory for series 693 to meet IEEE 1394a specification; also mandatory for USB 2.0).
20 = Contact Orientation: FOR SERIES 690: 21 = Right angle contacts (jack face 90 degrees from PCB
and parallel to board). 60 = vertical contacts (jack face 180 degrees from PCB), 61 = Right angle vertical
(jack face 90 degrees from PCB and vertical to board), 99 = surface mount right angle contacts.
FOR SERIES 693: 20 = Right angle contacts (jack face 90 degrees from PCB and parallel to board). 21 =
Right angle vertical (jack face 90 degrees from PCB and vertical to board), 22 = vertical contacts (jack face
180 degrees from PCB), 99 = surface mount right angle contacts.
003 = Connector Type: 003 = IEEE 1394a, 013 = USB Type A, 023 = USB Type B, 033 = Miniature USB
Type A, 043 = Miniature USB Type B
Popular cable assembles (all connectors are male):
628-000-940 = USB A to Mini USB A x 1 meter
628-000-906-1 = IEEE1394a both ends x 0.7meter
628-000-942 = USB A to USB A x 1.8 meters
628-000-906-2 = IEEE1394a both ends x 2.0 meters
628-000-943 = USB A to USB B x 1.8 meters
628-000-906-3 = IEEE1394a both ends x 4.5 meters
628-000-944 = USB B to USB B x 1.8 meters
628-000-906-4 = IEEE1394a both ends x 10.0 meters
Copyright © 2004 Edac Inc. All rights reserved
www.edac.net
Sheet D-6903
很抱歉,暂时无法提供与“693-006-620-003”相匹配的价格&库存,您可以联系我们找货
