140 SERIES
Wire to Board Connectors
Features:
0.079” (2.00mm) contact spacing
For use with PC board thickness: 0.047” (1.2mm) ~ 0.062” (1.6mm)
Low profile insulator body, 0.185” (4.7mm) width 0.240” (6.10mm) Height
Contact termination options include: P.C. tail, surface mount
Top entry or side entry configurations
Board retention contacts available
Designed for high-density connection of internal wires to PCB
Specifications:
Insulator Material
PA66, UL94V-0, Natural Color
Contact Material
Brass (For Male Header)
Phosphor Bronze (For Female Contact)
Contact Plating
Tin Plating (For Male Header)
Tin Plating, Copper Underplating (For Female Contact)
Current Rating
2 amps
Voltage Rating
100 V
Contact Resistance
Initial: 10 milliohms maximum
Dielectric Withstanding Voltage
800 V AC rms
Insulation Resistance
1000 megaohms minimum
Operating Temperature
-40°C to +105°C
Applicable Wire
AWG #30~#24
Through-Hole Type Header:
TOP ENTRY
2.00±0.10
A±0.25
4.70±0.30
B±0.30
3.4±0.2
6.10±0.30
CAVITIY NO.
0.80±0.10
PIN SQ 0.50
3P~16P
www.edac.net
2P
customerservice@edac.net
140 SERIES
SIDE ENTRY
PIN 0.5X0.5
2.00±0.10 .TYP
A±0.20
CAVITIY NO.
CAVITIY NO.
5.00±0.30
CAVITIY NO.
6.10±0.30
0.80±0.10
6.25±0.25
B±0.30
3.4±0.20
No.of Circuits
www.edac.net
Top Entry
Side Entry
EDAC P/N
EDAC P/N
Dim A
Dim B
2
140-502-415-001 140-502-415-000
2.00
6.00
3
140-503-415-001 140-503-415-000
4.00
8.00
4
140-504-415-001 140-504-415-000
6.00
10.00
5
140-505-415-001 140-505-415-000
8.00
12.00
6
140-506-415-001 140-506-415-000
10.00
14.00
7
140-507-415-001 140-507-415-000
12.00
16.00
8
140-508-415-001 140-508-415-000
14.00
18.00
9
140-509-415-001 140-509-415-000
16.00
20.00
10
140-510-415-001 140-510-415-000
18.00
22.00
11
140-511-415-001 140-511-415-000
20.00
24.00
12
140-512-415-001 140-512-415-000
22.00
26.00
140 SERIES
Through-Hole Header:
TOP ENTRY
2.00±0.10
A±0.25
CAVITIY NO.
4.70±0.30
3.4±0.2
6.10±0.30
B±0.30
PIN SQ 0.50
3P~12P
2P
SIDE ENTRY
PIN 0.5X0.5
2.00±0.10 .TYP
A±0.20
5.00±0.30
CAVITIY NO.
CAVITIY NO.
6.10±0.30
6.25±0.25
B±0.30
3.4±0.20
www.edac.net
140 SERIES
No.of Circuits
Top Entry
Side Entry
EDAC P/N
EDAC P/N
Dim A
Dim B
2
140-502-415-101 140-502-415-100
2.00
6.00
3
140-503-415-101 140-503-415-100
4.00
8.00
4
140-504-415-101 140-504-415-100
6.00
10.00
5
140-505-415-101 140-505-415-100
8.00
12.00
6
140-506-415-101 140-506-415-100
10.00
14.00
7
140-507-415-101 140-507-415-100
12.00
16.00
8
140-508-415-101 140-508-415-100
14.00
18.00
9
140-509-415-101 140-509-415-100
16.00
20.00
10
140-510-415-101 140-510-415-100
18.00
22.00
11
140-511-415-101 140-511-415-100
20.00
24.00
12
140-512-415-101 140-512-415-100
22.00
26.00
SMT Header:
TOP ENTRY
B±0.20
Circuit 1
SQ 0.50±0.03
A±0.15
3P-16P
www.edac.net
2P
140 SERIES
SMT Header:
SIDE ENTRY
2.00±0.10
Circuit 1
A±0.20
B±0.25
No.of Circuits
www.edac.net
Top Entry
Side Entry
EDAC P/N
EDAC P/N
Dim A (mm)
Dim B (mm)
2
140-502-417-011 140-502-417-060
2.0
3
140-503-417-011 140-503-417-060
4.0
8.0
10.0
4
140-504-417-011 140-504-417-060
6.0
12.0
5
140-505-417-011 140-505-417-060
8.0
14.0
6
140-506-417-011 140-506-417-060
10.0
16.0
7
140-507-417-011 140-507-417-060
12.0
18.0
8
140-508-417-011 140-508-417-060
14.0
20.0
9
140-509-417-011 140-509-417-060
16.0
22.0
10
140-510-417-011 140-510-417-060
18.0
24.0
11
140-511-417-011 140-511-417-060
20.0
26.0
12
140-512-417-011 140-512-417-060
22.0
28.0
13
140-513-417-011 140-513-417-060
24.0
30.0
14
140-514-417-011 140-514-417-060
26.0
32.0
15
140-515-417-011 140-515-417-060
28.0
34.0
16
140-516-417-011
30.0
36.0
N/A
140 SERIES
Socket Housing:
No.of Circuits
2
EDAC P/N
Dim A (mm)
Dim B (mm)
140-502-210-011
2.00
3
140-503-210-011
4.00
5.80
7.80
2.00±0.10
4
140-504-210-011
6.00
9.80
A±0.20
5
140-505-210-011
8.00
11.80
6
140-506-210-011
10.00
13.80
7
140-507-210-011
12.00
15.80
8
140-508-210-011
14.00
17.80
9
140-509-210-011
16.00
19.80
10
140-510-210-011
18.00
21.80
4.40±0.25
6.85±0.25
B±0.25
3.40±0.20
Circuit 1
11
140-511-210-011
20.00
23.80
12
140-512-210-011
22.00
25.80
13
140-513-210-011
24.00
27.80
14
140-514-210-011
26.00
29.80
15
140-515-210-011
28.00
31.80
16
140-516-210-011
30.00
33.80
Contact:
0.950
0.500
0.20
2.05
5.3
EDAC P/N
140-941-290
www.edac.net
0.350
1.35
1.45
Wire Range Insulation O.D
24-30AWG
1.50 MAX.
Material
Phosphor Bronze
140 SERIES
PCB Layout:
Through hole side entry
Through hole top entry
0.70±
0.20
0.20
2.00±0.20
2.00±0.20
Recommended PCB Layout
PCB Thickness: 1.20~1.60mm
Tolerance: ±0.05
Tolerance: ±0.05
SMT side entry
1.60±0.10
1.50±0.10
3.40±0.10
1.60±0.1
2.00±0.05
A±0.10
3.00±0.1
1.50
2.00MAX
7.50MIN
1.00MIN
1.60±0.1
9.20±0.10
SMT top entry
5.70±0.10
0.70±
1.00±0.05
2.00±0.05
Tolerance: ±0.05
www.edac.net
Tolerance: ±0.05
很抱歉,暂时无法提供与“140-508-210-011.”相匹配的价格&库存,您可以联系我们找货
