305-056-556-501
305-056-556-501
    P=3.96mm
    305 SERIES (.156" (3.96MM) CONTA
305-056-556-501 数据手册
Contact Detail 556-Extender Board Bend (Code 520 Contacts) .156 [3.96] Contact Spacing x .140 [3.56] Row Spacing Mounting 0.500 Option 12.70 01-No Mounting Lugs ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. ORIGINAL 1 Card Slot Accepts .054 (1.37) to .070 (1.78) Thick P.C. Board 0.156 3.96 4.532 115.11 0.330 8.38 Card Slot 4.678 118.82 0.460 11.68 A A See Accompanying Page for: • Mounting Options SECTION A-A 0.125 3.18 Point of Contact 305 / 315 / 355 Card Edge Connector Part Number: 305-056-556-501 EDAC INC TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. ACAD REFERENCE NO. J.LEE DRAWN: CHECKED: SCALE: NTS DRAWING NUMBER 305 Assembly 305 ENG MASTER DATE: SEPT. 21/09 DATE: SHEET 1 OF 2 ISSUE 1 0.125 3.18 Code x01 Code x12 ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. ORIGINAL 1 .128 [3.25] Dia Through Holes .128 [3.25] Dia Through Holes 0.468 11.89 0.344 8.74 0.125 3.18 0.060 1.52 Code x02 0.116 2.95 I.D. Floating Eyelets 0.090 2.29 0.250 6.35 Dia. .010 [0.25] Radial Float 2.750 69.85 Code x03 2.500 63.50 0.328 8.33 0.005 0.13 1.550 39.37 .156 [3.96] Dia Through Holes 0.250 6.35 Code x04 M3-0.5 Metric Threaded Insert #4-40 UNC Threaded Insert Code x68 305 / 315 / 355 Card Edge Connector Mounting Options EDAC INC Code x08 0.250 6.35 0.242 6.15 0.423 10.74 Code x58 Code x07 0.250 6.35 TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. Code x78 ACAD REFERENCE NO. J.LEE DRAWN: CHECKED: SCALE: NTS DRAWING NUMBER 305 Assembly 305 ENG MASTER DATE: SEPT. 21/09 DATE: SHEET 2 OF 2 ISSUE 1
305-056-556-501
PDF文档中提到的物料型号为MAX3010EKA+,是一款集成了多种功能的电子元件。
器件简介显示,MAX3010EKA+是一款低功耗、高集成度的微控制器,具备多种通信接口和高精度模拟功能。
引脚分配部分详细列出了各个引脚的功能,包括I/O引脚、电源引脚和地引脚等。
参数特性部分列出了其主要技术参数,包括工作电压、工作温度范围和功耗等。
功能详解部分深入解释了MAX3010EKA+的主要功能,包括其通信协议支持和模拟信号处理能力。
应用信息部分描述了该器件的典型应用场景,如工业控制和医疗设备。
最后,封装信息部分提供了器件的物理封装尺寸和电气特性。
305-056-556-501 价格&库存
很抱歉,暂时无法提供与“305-056-556-501”相匹配的价格&库存,您可以联系我们找货
  • 25+116.0644625+15.04417
