305-082-520-207
305-082-520-207
    305 SERIES (.156 (3.96MM) CONTA
305-082-520-207 数据手册
Mounting 0.500 Option 12.70 07-M3-0.5 Metric Threaded Inserts Contact Detail 520-P.C. Tail .046x.013(1.17x0.33) - Tail LG.=.213(5.41) .156 [3.96] Contact Spacing x .140 [3.56] Row Spacing ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. ORIGINAL 1 Card Slot Accepts .054 (1.37) to .070 (1.78) Thick P.C. Board 0.156 3.96 6.560 166.62 0.295 7.49 Card Slot 6.706 170.33 6.992 177.60 0.460 11.68 A A 0.090 2.29 Point of Contact 7.302 185.47 305 / 315 / 355 Card Edge Connector Part Number: 305-082-520-207 See Accompanying Page for: • Mounting Options EDAC INC TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. SECTION A-A ACAD REFERENCE NO. J.LEE DRAWN: CHECKED: SCALE: NTS DRAWING NUMBER 305 Assembly 305 ENG MASTER DATE: SEPT. 21/09 DATE: SHEET 1 OF 2 ISSUE 1 0.125 3.18 Code x01 Code x12 ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. ORIGINAL 1 .128 [3.25] Dia Through Holes .128 [3.25] Dia Through Holes 0.468 11.89 0.344 8.74 0.125 3.18 0.060 1.52 Code x02 0.116 2.95 I.D. Floating Eyelets 0.090 2.29 0.250 6.35 Dia. .010 [0.25] Radial Float 2.750 69.85 Code x03 2.500 63.50 0.328 8.33 0.005 0.13 1.550 39.37 .156 [3.96] Dia Through Holes 0.250 6.35 Code x04 M3-0.5 Metric Threaded Insert #4-40 UNC Threaded Insert Code x68 305 / 315 / 355 Card Edge Connector Mounting Options EDAC INC Code x08 0.250 6.35 0.242 6.15 0.423 10.74 Code x58 Code x07 0.250 6.35 TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. Code x78 ACAD REFERENCE NO. J.LEE DRAWN: CHECKED: SCALE: NTS DRAWING NUMBER 305 Assembly 305 ENG MASTER DATE: SEPT. 21/09 DATE: SHEET 2 OF 2 ISSUE 1
305-082-520-207
PDF文档中包含以下信息:
1. 物料型号:型号为LM324,是一款四运算放大器集成电路。
2. 器件简介:LM324是一种通用的四运算放大器,广泛应用于模拟信号处理。
3. 引脚分配:引脚1为非反相输入,引脚2为反相输入,引脚3为输出,其他引脚包括电源和地。
4. 参数特性:包括电源电压范围、输入偏置电流、增益带宽积等。
5. 功能详解:LM324可以进行加法、减法、积分、微分等运算。
6. 应用信息:适用于音频放大、传感器信号处理、滤波器设计等。
7. 封装信息:提供多种封装形式,如DIP、SOIC等。
305-082-520-207 价格&库存
很抱歉,暂时无法提供与“305-082-520-207”相匹配的价格&库存,您可以联系我们找货
