337-086-520-201
337-086-520-201
    86 位置 母头 连接器 非指定 - 双边 镀金 0.156"(3.96mm) 绿色
337-086-520-201 数据手册
337/387 SERIES Card Edge Connector 0.156" (3.96mm) Pitch FEATURES • 0.156" (3.96mm) Contact Spacing by 0.200" 5.08mm) Row Spacing • Accepts .062" (1.57mm) Nominal Thickness P.C. Board • High Profile Insulator Body, .600" (15.24mm) • Card Slot Depth of .330" (8.38mm) • Contact Termination Options include P.C. Tail, Wire Hole, Wire Wrap, 90° and Extender Board Bends • Single or Dual Row Configurations • Large Variety of Mounting Options, Flush or Offset Lugs • Accepts between Contact and In-Contact Polarizing Keys • Pre-assembled Card Guides are available • RoHS Compliant, UL certified Specifications: Insulator Material Contact Material Contact Plating Current Rating Contact Resistance Dielectric Withstand Voltage Insulation Resistance Operating Temperature Insertion Force Withdrawal Force Example Part Number UL 94V-0 Thermoplastic Polyester Copper Alloy Gold Plating on mating area and Tin Plating on tails with Nickel underplating all over 3 Ampere 10milliohms maximum 1800 VAC rms at sea level between adjacent contacts 5000 Megaohms minimum Operating Temperature: -40°C to +105°C 16oz (4.45N) maximum per contact pair when tested with .070" (1.78mm) thick gauge 1oz (0.28N) minimum per contact pair when tested with .054" (1.37mm) thick gauge 337-086-524-204 Series Total Number of Contacts Mounting Options Total Number of Contacts: Contact Rows 006, 007, . . . . 043 012, 014, . . . . 086 Single Row Dual Row Description & Tail Size Wire Hole .050 x .025 (1.27 x 0.64) P.C. Tail .030 x .018 (0.76 x 0.46) P.C. Tail .025 Square (0.64 Square) P.C. Tail .025 Square (0.64 Square) P.C. Tail .018 Square (0.46 Square) Wire Wrap .025 Square (0.64 Square) Wire Wrap .025 Square (0.64 Square) Wire Wrap .025 Square (0.64 Square) Wire Wrap .050 x .025 (1.27 x 0.64) EXTENDER BOARD BEND (Code 500 Contacts) EXTENDER BOARD BEND (Code 520 Contacts) 90 DEGREE BEND (Code 541 Contacts) 90 DEGREE BEND (Code 541 Contacts) EXTENDER BOARD BEND (Code 523 Contacts) www.edac.net Green Black 1 2 6 8 Contact Rows and Insulator Style 500 520 521 523 524 540 541 542 544 555 556 558 559 560 Insulator Color 337 387 Contact Rows and Insulator Style Contact Code Contact Code Series Tail Length "G" .260 (6.60) .175 (4.45) .150 (3.81) .390 (9.91) .175 (4.45) .560 (14.22) .750 (19.05) .645 (16.38) .750 (19.05) Single Row, Flush Mounting Lugs Dual Row, Flush Mounting Lugs Single Row, .170 (4.32) Offset Lugs Dual Row, .170 (4.32) Offset Lugs Mounting Options 01 No Mounting Lug 02 Ø.128" (Ø3.25mm) Mounting Holes 03 Ø.116" (Ø2.95mm) I.D. Floating Eyelets 04 Ø.156" (Ø3.96mm) Mounting Holes 07 M3-0.5 Metric Threaded Inserts 08 #4-40 Unified Threaded Inserts 12 Ø.128" (Ø3.25mm) Side Mounting Holes 58 .468" (11.89mm) Offset Card Guides 68 .344" (8.74mm) Offset Card Guides 78 In-Line Card Guides Ordering Code Notes: 1) All connector sizes up to 43 contacts single row / 086 contacts dual row are available upon request. 2) The 500 contact code is only available in the 337 series. Green polyphenylene sulphide insulator material will be supplied. 3) For details of the extender board and 90 degree bends refer to our website. 4 For lugless connectors, code 01 mounting, specify contact row code 1 or 2. 5) In-line card guides are only with offset mounting lugs. 6) For details of the mounting options refer to next pages. Page 1
337-086-520-201 价格&库存
很抱歉,暂时无法提供与“337-086-520-201”相匹配的价格&库存,您可以联系我们找货
  • 1+71.310391+9.14633
  • 10+60.5796410+7.76999
  • 25+56.7794825+7.28258
  • 50+54.0670450+6.93468
  • 100+51.48698100+6.60376
  • 250+48.26433250+6.19042
  • 500+45.96204500+5.89513
  • 1000+43.770731000+5.61407
库存:62
