566 SERIES
WATERPROOF WIRE TO WIRE & WIRE TO BOARD CONNECTORS
Features:
2.0mm pitch, rated current: 2A max
Fully waterproof solution available in 2, 3, 4, or 6 positions (2 and 3 positions only for wire to board)
Available in wire to wire and wire to board options
Seals preassembled into housing; no external sealing required
True crimp and poke solution
Waterproofing cap available to cover unused positions
Available with wire already installed
Waterproof Grade: IP67 Certified
Specifications:
No. of Positions
2, 3, 4, or 6
Pitch
2.0 mm
Rated Voltage
250 V
Rated Current
2 amps maximum
Dielectric Withstanding Voltage
1000 V AC (rms)
Contact Resistance
10 milliohms maximum
Insulation Resistance
1000 megaohms minimum/DC 500 V
Operating Temperature
-40°C to +105°C
PCB Thickness
1.6 mm
Ordering Code:
Crimp Contact:
566-002-000-710
Male Contact (Pin)
SERIES:
566, WIRE TO WIRE
WIRE TO BOARD
NO. OF CONTACTS:
002 - 2 CONTACTS
003 - 3 CONTACTS
004 - 4 CONTACTS
006 - 6 CONTACTS
Female Contact (Socket)
Part No
AWG#
Ins. Dia.
Pcs/Reel
Part No
AWG#
Ins. Dia.
Pcs/Reel
566-290-711
22-28
Ø1.0~Ø1.5
12,000
566-290-721
22-28
Ø1.0~Ø1.5
12,000
**Crimp Contacts are also available in strips of 60pcs. Contact
EDAC for more information.
**Wire seals and housing seals are already
pre-assembled in the connector.
CONTACT CODE:
000 - NO CONTACTS (ONLY FOR CRIMP CONTACTS)
421 - BOARD MOUNT CONTACTS (PCB) ONLY FOR
2 & 3 PIN SIZE
STYLE:
701 - BLACK MALE HOUSING (ONLY FOR BOARD MOUNT CONTACTS)
710 - BLACK MALE HOUSING FOR WIRE INSULATION Ø1.00 TO Ø1.25
711 - BLACK MALE HOUSING FOR WIRE INSULATION Ø1.25 TO Ø1.50
810 - BLACK FEMALE HOUSING FOR WIRE INSULATION Ø1.00 TO Ø1.25
811 - BLACK FEMALE HOUSING FOR WIRE INSULATION Ø1.25 TO Ø1.50
Rear Gasket (Wire Seal):
Materials:
Crimp & Poke
PCB Header
Housing
PBT, UL 94V-0
Contact
Phosphor Bronze
Housing
PBT with Glass, UL
94V-0
Contact
Brass
Contact Plating
Tin Plating
Wire & Housing Seals
Silicone Rubber
Waterproofing Cap
PBT, UL 94V-0
Waterproofing Cap:
Part No.
Applicable
Contact
Wire O.D.
Color
566-290-711
566-290-721
Ø1.00 to Ø1.25
Light Blue
Ø1.25 to Ø1.50
Orange
Assembly Layout:
PIN SIZE:
A (mm) LENGTH:
2P, 3P, 4P
28.85
6P
29.05
Waterproofing Cap
566-200-100
A
www.edac.net
customerservice@edac.net
566 SERIES
Female Housing:
Male Housing:
Female Housing:
Male Housing:
566-002-000-XXX
566-002-000-XXX
566-003-000-XXX
566-003-000-XXX
566-004-000-XXX
566-004-000-XXX
PCB Header
PCB Header
566-002-421-701
566-003-000-XXX
2.8±0.1
566-006-000-XXX
0.0
.8 ±
RECOMMENDED
PCB LAYOUT
Ø1.0±
0.05
1.6±0.1
566-006-000-XXX
Male Housing:
Female Housing:
Ø Wire Insulation
Housing Color
XXX
Ø Wire Insulation
Housing Color
XXX
"Ø1.00 to Ø1.25"
Black
710
"Ø1.00 to Ø1.25"
Black
810
"Ø1.25 to Ø1.50"
Black
711
"Ø1.25 to Ø1.50"
Black
811
www.edac.net
Ø0
2.0±0.05
5
±0.1
2x(N-1)
很抱歉,暂时无法提供与“566-002-421-701”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+47.59560
- 250+18.99720
- 500+18.36000
- 1000+18.04680
