305-028-500-258
305-028-500-258
    305 SERIES (.156" (3.96MM) CONTA
305-028-500-258 数据手册
Mounting Option 58-.468 (11.89) Offset Card Guides Contact Detail 500-Wire Hole .087x.013(2.21x0.33) - Tail LG.=.282(7.16) .156 [3.96] Contact Spacing x .140 [3.56] Row Spacing ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. ORIGINAL 1 0.343 8.71 Card Slot Accepts .054 (1.37) to .070 (1.78) Thick P.C. Board 0.156 3.96 2.348 59.64 2.494 63.35 0.295 7.49 Card Slot 2.780 70.61 3.626 92.10 0.460 11.68 A A 0.090 2.29 Point of Contact 3.090 78.49 305 / 315 / 355 Card Edge Connector Part Number: 305-028-500-258 See Accompanying Page for: • Mounting Options EDAC INC TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. SECTION A-A ACAD REFERENCE NO. J.LEE DRAWN: CHECKED: SCALE: NTS DRAWING NUMBER 305 Assembly 305 ENG MASTER DATE: SEPT. 21/09 DATE: SHEET 1 OF 2 ISSUE 1 0.125 3.18 Code x01 Code x12 ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. ORIGINAL 1 .128 [3.25] Dia Through Holes .128 [3.25] Dia Through Holes 0.468 11.89 0.344 8.74 0.125 3.18 0.060 1.52 Code x02 0.116 2.95 I.D. Floating Eyelets 0.090 2.29 0.250 6.35 Dia. .010 [0.25] Radial Float 2.750 69.85 Code x03 2.500 63.50 0.328 8.33 0.005 0.13 1.550 39.37 .156 [3.96] Dia Through Holes 0.250 6.35 Code x04 M3-0.5 Metric Threaded Insert #4-40 UNC Threaded Insert Code x68 305 / 315 / 355 Card Edge Connector Mounting Options EDAC INC Code x08 0.250 6.35 0.242 6.15 0.423 10.74 Code x58 Code x07 0.250 6.35 TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. Code x78 ACAD REFERENCE NO. J.LEE DRAWN: CHECKED: SCALE: NTS DRAWING NUMBER 305 Assembly 305 ENG MASTER DATE: SEPT. 21/09 DATE: SHEET 2 OF 2 ISSUE 1
305-028-500-258
1. 物料型号:文档中提到的物料型号为“305-028-500-258”。
2. 器件简介:文档中没有直接提供器件的简介信息,但根据文档内容可以推断,该文档描述的是一种卡边连接器(Card Edge Connector),具有不同的安装选项和细节规格。
3. 引脚分配:文档中提供了详细的引脚分配信息,包括接触点间距(.156 [3.96] Contact Spacing)和行间距(.140 [3.56] Row Spacing),以及不同代码(Code x01, Code x02, Code x03, Code x04, Code x58, Code x68, Code x78, Code x07, Code x08)对应的具体尺寸和特征。
4. 参数特性:文档中列出了多种参数特性,例如接触点的直径(.128 [3.25] Dia)、通过孔的尺寸(0.125 3.18)、浮动眼孔(Floating Eyelets)的内径(0.116 I.D.)等。
5. 功能详解:文档中没有直接提供功能详解,但通过分析可以了解到,该连接器支持不同厚度的PCB板(.054 (1.37) to .070 (1.78) Thick P.C. Board),并具有多种安装选项。
6. 应用信息:文档中没有明确提供应用信息,但根据连接器的特性和规格,可以推断它可能用于需要高密度连接和多种安装选项的电子设备中。
7. 封装信息:文档中提供了封装相关的详细信息,包括不同代码的安装选项和尺寸规格。
305-028-500-258 价格&库存
很抱歉,暂时无法提供与“305-028-500-258”相匹配的价格&库存,您可以联系我们找货
