305-044-520-512
305-044-520-512
    305 SERIES (.156 (3.96MM) CONTA
305-044-520-512 数据手册
Mounting Option 12-.128 (3.25) Dia. Side Mounting Holes Contact Detail 520-P.C. Tail .046x.013(1.17x0.33) - Tail LG.=.213(5.41) .156 [3.96] Contact Spacing x .140 [3.56] Row Spacing ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. ORIGINAL 1 0.343 8.71 Card Slot Accepts .054 (1.37) to .070 (1.78) Thick P.C. Board 0.156 3.96 3.596 91.34 3.742 95.05 0.330 8.38 Card Slot 4.028 102.31 0.460 11.68 SECTION A-A A A 0.125 3.18 Point of Contact 4.028 102.31 4.338 110.19 305 / 315 / 355 Card Edge Connector Part Number: 305-044-520-512 See Accompanying Page for: • Mounting Options EDAC INC TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. ACAD REFERENCE NO. DRAWN: J.LEE DATE: CHECKED: SCALE: 305 ENG MASTER DATE: SEPT. 21/09 NTS DRAWING NUMBER 305 Assembly SHEET 1 OF 2 ISSUE 1 0.125 3.18 Code x01 Code x12 ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. ORIGINAL 1 .128 [3.25] Dia Through Holes .128 [3.25] Dia Through Holes 0.468 11.89 0.344 8.74 0.125 3.18 0.060 1.52 Code x02 0.116 2.95 I.D. Floating Eyelets 0.090 2.29 0.250 6.35 Dia. .010 [0.25] Radial Float 2.750 69.85 Code x03 2.500 63.50 0.328 8.33 0.005 0.13 1.550 39.37 .156 [3.96] Dia Through Holes 0.250 6.35 Code x04 M3-0.5 Metric Threaded Insert #4-40 UNC Threaded Insert Code x68 305 / 315 / 355 Card Edge Connector Mounting Options EDAC INC Code x08 0.250 6.35 0.242 6.15 0.423 10.74 Code x58 Code x07 0.250 6.35 TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. Code x78 ACAD REFERENCE NO. DRAWN: J.LEE DATE: CHECKED: SCALE: 305 ENG MASTER DATE: SEPT. 21/09 NTS DRAWING NUMBER 305 Assembly SHEET 2 OF 2 ISSUE 1
305-044-520-512
1. 物料型号:文档中提到的物料型号是“305-044-520-512”。
2. 器件简介:文档描述了一种卡边连接器,具体为“305 / 315 / 355 Card Edge Connector”。
3. 引脚分配:文档中提到了不同的引脚分配代码,例如“Code x01”、“Code x12”、“Code x02”、“Code x03”、“Code x04”、“Code x58”、“Code x68”、“Code x78”和“Code x07”,以及“#4-40 UNC Threaded Insert”和“M3-0.5 Metric Threaded Insert”。
4. 参数特性:文档中包含了一些参数特性,如接触间距“.156 [3.96] Contact Spacing”和行间距“.140 [3.56] Row Spacing”,以及卡槽可以接受的PCB板厚度“.054 (1.37) to .070 (1.78)”。
5. 功能详解:文档中没有提供具体的功能详解,但提到了连接器的装配和安装选项。
6. 应用信息:文档中没有明确提供应用信息,但提到了“YOUR CONNECTION TO QUALITY & SERVICE”,暗示该连接器可能用于需要高质量连接的应用。
7. 封装信息:文档中包含了一些封装相关的细节,如侧装孔直径“12-.128 (3.25) Dia. Side Mounting Holes”,尾部尺寸“520-P.C. Tail .046x.013(1.17x0.33)”,以及尾部长度“Tail LG.=.213(5.41)”。
305-044-520-512 价格&库存
很抱歉,暂时无法提供与“305-044-520-512”相匹配的价格&库存,您可以联系我们找货
