307-006-453-102
307-006-453-102
    307 SERIES (.156 (3.96MM) CONTA
307-006-453-102 数据手册
0.343 8.71 Mounting Option .128 (3.25) Dia. Mounting Holes Contact Detail 90 Degree Bend (Code 421 Contacts) .156 [3.96] Contact Spacing x .200 [5.08] Row Spacing ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. ORIGINAL 1 0.156 3.96 1.100 27.94 1.246 31.65 1.532 38.91 SECTION A-A A 0.473 12.01 A .175 [4.45] Point of Contact (FROM BTM OF SLOT) Card Slot Accepts .054 [1.37] to .070 [1.78] Thick P.C. Board 1.842 46.79 See Accompanying Pages for: • Contact Bend Details • Mounting Options 307 / 357 Card Edge Connector Part Number: 307-006-453-102 EDAC INC TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. ACAD REFERENCE NO. DRAWN: J.LEE DATE: CHECKED: SCALE: 307 ENG MASTER DATE: AUG. 11/09 NTS DRAWING NUMBER 307 Assembly SHEET 1 OF 3 ISSUE 1 Single Row Contacts - Read One Side of Daughter Board ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. 0.240 6.10 ORIGINAL 1 0.240 6.10 0.260 6.60 558 Contact Code 559 Contact Code 0.060 1.52 Single Row Contacts - Read Both Sides of Daughter Board 0.110 2.79 0.150 3.81 0.392 9.96 0.045 1.14 0.045 1.14 553 Contact Code 554 Contact Code 557 Contact Code Dual Row Contacts - Read Both Sides of Daughter Board 0.240 [6.10] Up to 27/54 Pin 0.162 [4.11] 28/56 and Over 0.240 [6.10] Up to 27/54 Pin 0.162 [4.11] 28/56 and Over 0.120 3.05 0.095 2.41 0.265 6.73 555 Contact Code .125 [3.18] to .210 [5.33] Outside Tails .045 [1.14] to .060 [1.52] Between Tails 0.290 [7.37] Up to 27/54 Pin .212 [5.38] 28/56 and Over 0.165 4.19 0.195 4.95 556 Contact Code .125 [3.18] to .185 [4.70] Outside Tails .045 [1.14] to .060 [1.52] Between Tails 0.343 8.71 0.200 5.08 0.060 1.52 558 Contact Code 0.060 1.52 559 Contact Code 307/ 357 Series Card Edge Connector Contact Bend Detail EDAC INC TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE .125 [3.18] to .210 [5.33] Outside Tails .045 [1.14] to .060 [1.52] Between Tails 0.150 3.81 THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. 560 Contact Code ACAD REFERENCE NO. DRAWN: J.LEE DATE: CHECKED: SCALE: 307 ENG MASTER DATE: AUG. 11/09 NTS DRAWING NUMBER 307 Assembly SHEET 2 OF 3 ISSUE 1 0.125 3.18 Code x01 Code x12 ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. ORIGINAL 1 .128 [3.25] Dia Through Holes .128 [3.25] Dia Through Holes 0.468 11.89 0.344 8.74 0.125 3.18 0.060 1.52 Code x02 0.116 2.95 I.D. Floating Eyelets 0.090 2.29 0.250 6.35 Dia. 2.500 63.50 2.750 69.85 0.328 8.33 Code x03 0.005 0.13 .010 [0.25] Radial Float 1.550 39.37 0.250 6.35 0.250 6.35 .156 [3.96] Dia Through Holes 0.250 6.35 Code x04 M3-0.5 Metric Threaded Insert 0.242 6.15 0.423 10.74 Code x58 Code x07 #4-40 UNC Threaded Insert Code x68 307 / 357 Card Edge Connector Mounting Options EDAC INC Code x08 TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. Code x78 ACAD REFERENCE NO. DRAWN: J.LEE DATE: CHECKED: SCALE: 307 ENG MASTER DATE: AUG. 11/09 NTS DRAWING NUMBER 307 Assembly SHEET 3 OF 3 ISSUE 1
307-006-453-102 价格&库存
很抱歉,暂时无法提供与“307-006-453-102”相匹配的价格&库存,您可以联系我们找货
