621/622 SERIES
D-Sub Connectors: Right Angle, 0.318” (8.08mm) Footprint
Features:
Two contact rows with 0.318”(8.08mm) footprint, right angle bend
0.109”(2.77mm) contact spacing X 0.112”(2.84mm) row spacing
Plug and receptacle in 9, 15, 25, or 37 contact sizes
Pin and socket contact mating design with P.C. tail termination
Metal shell provides EMI/RFI shielding, plug shell indents provide grounding and additional mating
retention
Board mounting features include threaded hole, two and four prong boardlock for superior retention
to P.C. board
Flange mounting options for panel mount or connector mating include through hole, threaded hole
and threaded standoffs
D-shaped connector mating outline provides polarization
Design based on requirements of MIL-C-24038, EIA RS-232 and RS-449
Specifications:
Insulator Material
Thermoplastic Polyester, UL 94V-0, Chemical Resistant, Color: Black
Contact Material
Plug (Pins): Copper Alloy
Receptacle (Socket): Copper Alloy
Contact Plating
Selective Gold (See Ordering Code) over Nickel for the Mating Area, Tin Plating for Tail Area
Ferrite Specs
20dB MIN @30 MHz, 30dB MIN @50 MHz, and 50dB MIN @100 MHz
Shell Material
Nickel Plated Steel
Current Rating
3 amps
Contact Resistance
25 Milliohms maximum
Dielectric Withstanding Voltage
5000 megaohms minimum
Insulation Resistance
1000 V AC rms at Sea Level
Operating Temperature
-55°C To +85°C (upto +125°C for high temp)
Insertion Force
16 oz (4.45 N) Maximum Per Contact Position
Withdrawal Force
1 oz (0.28 N) Minimum Per Contact Position
Ordering Code:
621-025-260-013
SERIES:
621: PLUG (PIN)
622: RECEPTACLE (SOCKET)
NO. OF CONTACTS:
009 - 9 CONTACTS
025 - 25 CONTACTS
015 - 15 CONTACTS 037 - 37 CONTACTS
CONTACT FINISH CODE:
2 - GOLD FLASH PLATING
3 - 15 MICROINCHES OF GOLD PLATING
6 - 30 MICROINCHES OF GOLD PLATING
CONTACT CODE:
60 - .318" FOOTPRINT CONTACT
68 - .318" FOOTPRINT WITH FERRITE FILTER
www.edac.net
FLANGE MOUNTING OPTIONS
FLANGE MOUNTING OPTIONS:
0 - #4-40 THREADED FIXED STANDOFF
1 - Ø.120"(Ø3.05MM) THROUGH HOLE
2 - #4-40 THREADED HOLE
3 - #4-40 THREADED STANDOFF
5 - M3 THREADED HOLE
6 - M3 THREADED STANDOFF
BOARD MOUNTING FEATURE:
3 - TWO PRONG BOARDLOCKS
4 - FOUR PRONG BOARDLOCKS
5 - #4-40 THREADED HOLE
INSULATOR MATERIAL CODE:
0 - STANDARD
5 - HIGH TEMP INSULATOR
customerservice@edac.net
621/622 SERIES
B
8.08
Ø1.10
2-Ø3.20
9.50
2.77±0.13
2.84
#4-40UNC/M3
12.55±0.38
8.36±0.13
2.84
PLUG
A
B
C
2.77±0.13
1.385
P.C.B EDGE
RECEPTACLE
6.00±0.25
8.08±0.25
2.84±0.25
9.50±0.25
12.40±0.25
RECOMMENDED P.C.B LAYOUT
(FOR PLUG AND RECEPTACLE)
3.18±0.38
A
B
C
2.77±0.13
NUMBER OF
CONTACTS
www.edac.net
A±0.38mm
B±0.25mm
5.80±0.25
8.08±0.25
2.84±0.25
9.50±0.25
12.40±0.25
12.55±0.38
7.90±0.13
2.84
#4-40UNC/M3
3.18±0.38
C±0.13mm
C±0.13mm
PLUG
RECEPTACLE
Inch
(mm)
Inch
(mm)
Inch
(mm)
9
1.213 (30.81)
.984
(24.99)
.667
(16.92)
.643
(16.33)
15
1.543 (39.19)
1.312
(33.32)
.994
(25.25)
.971
(24.66)
25
2.088 (53.04)
1.852
(47.04) 1.534
(38.96)
1.511
(38.38)
37
2.729 (69.32)
2.500
(63.50) 2.182
(55.42)
2.159
(54.84)
Inch
(mm)
很抱歉,暂时无法提供与“621-009-268-536”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+38.79360
- 200+15.01200
- 500+14.49360
- 1000+14.22360
- 国内价格 香港价格
- 200+25.22946200+3.26329
