661/662/663/664 SERIES
D-Sub Connectors: Dual Port, Right Angle
Features:
Two contact rows per connector with right angle bend
0.109”(2.77mm) contact spacing x 0.112”(2.84mm) row spacing
Plug and receptacle in 9, 15, 25 or 37 contact sizes
Pin and socket contact mating design with P.C. tail termination
Metal shell provides EMI/RFI shielding, plug shell indents provide grounding and additional mating retention
Board mounting features include grounding bracket with threaded hole or boardlocks for exceptional retention to
P.C. board
Flange mounting options for panel mount or connector mating include through hole, threaded inserts and
threaded standoffs
D-shaped connector mating outline provides polarization
Design based on requirements of MIL-C-24038, EIA RS-232 and RS-449
Additional grounding features or mounting options - contact customer service at customerservice@edac.net
Specifications:
Insulator Material
Thermoplastic Polyester, UL 94V-0, Chemical Resistant, Color: Black
Contact Material
Plug (Pins): Brass
Receptacle (Socket): Brass or Phosphor Bronze
Contact Plating
Selective Gold (See Ordering Code) over Nickel for the Mating Area, Tin Plating for Tail Area
Ferrite Specs:
20dB MIN @30 MHz, 30dB MIN @50 MHz, and 50dB MIN @100 MHz (Optional)
Shell Material
Nickel Plated Steel
Current Rating
3 amps
Contact Resistance
25 Milliohms maximum
Insulation Resistance
5000 megaohms minimum
Dielectric Withstanding Voltage
1000 V AC rms at Sea Level
Operating Temperature
-55°C To +85°C
Insertion Force
16 oz (4.45 N) Maximum Per Contact Position
Ordering Code:
661-025-264-053
SERIES:
661: PLUG OVER PLUG
662: RECEPTACLE OVER RECEPTACLE
663: PLUG OVER RECEPTACLE
664: RECEPTACLE OVER PLUG
NO. OF CONTACTS (PER CONNECTOR):
009 - 9 CONTACTS 025 - 25 CONTACTS
015 - 15 CONTACTS 037 - 37 CONTACTS
CONTACT FINISH CODE:
2 - GOLD FLASH PLATING
3 - 15 MICROINCHES OF GOLD PLATING
6 - 30 MICROINCHES OF GOLD PLATING
CONTACT CODE:
64 - DUAL PORT RIGHT ANGLE BEND CONTACT
EDAC INTERNAL:
www.edac.net
661 SERIES
PLUG OVER PLUG
FLANGE MOUNTING OPTIONS:
1- .625"(15.88MM) M3 THREADED INSERT
2 - .625"(15.88MM) #4-40 UNC THREADED INSERT
3 - .625"(15.88MM) #4-40 UNC THREADED HEX STANDOFF
4 - .625"(15.88MM) .125" CLEAR HOLE INSERT
A - .750"(19.05MM) M3 THREADED INSERT
5 - .750"(19.05MM) #4-40 UNC THREADED INSERT
6 - .750"(19.05MM) #4-40 UNC THREADED HEX STANDOFF
7 - .750"(19.05MM) .125" CLEAR HOLE INSERT
C - .900"(22.86MM) M3 THREADED INSERT
8 - .900"(22.86MM) #4-40 UNC THREADED INSERT
9 - .900"(22.86MM) #4-40 UNC THREADED HEX STANDOF
0 - .900"(22.86MM) .125" CLEAR HOLE INSERT
663 SERIES
VERTICAL SPACING
662 SERIES
664 SERIES
VERTICAL SPACING
BOARD GROUNDING FEATURE:
0 - Ø3.80mm THRU' HOLES
3 - 4x 2 PRONG BOARDLOCKS
4 - 2x 2 PRONG BOARDLOCKS (REAR ONLY)
5 - #4-40 THREADED HOLE
12.55±0.38
8.36±0.13
2.84
PLUG/PLUG 661 SERIES
A
B
C
6.00±0.25
2.770
2
3
10
4
5
11
6
12
13
7
14
8
15
E
F
9
3.18±0.38
1
1
2
4
3
5
11
10
6
12
12.55±0.38
8.36±0.13
2.84
9
13
7
14
8
15
2.770
Ø1.10
4-Ø3.20
2.77
8.08 8.00
2.77
3.92
8.08
8.00 8.08
19.60±0.25
8.08
14.84±0.25
3.92
2.84
2.84
2.84
B
P.C.B EDGE
2.84
RECOMMENDED P.C.B LAYOUT
FOR ALL SERIES
12.55±0.38
7.90±0.13
2.84
RECEPTACLE/RECEPTACLE 662 SERIES
A
B
5.80±0.25
2.770
8
7
6
14
5
13
4
12
3
11
2
10
1
9
8
7
6
14
5
13
4
12
3
11
2
10
1
9
2.770
D
FOR ALL SERIES
8.00 8.08
19.60±0.25
E±0.25
CTR TO CTR
VERTICAL
SPACING
2.84
8.08
14.84±0.25
3.92
12.55±0.38
7.90±0.13
2.84
15
3.18±0.38
E
F
15
(mm)
Inch
F±0.38
Inch
(mm)
.625
(15.88) 1.119 (28.43)
.750
(19.05) 1.244 (31.60)
.900
(22.86) 1.394 (35.41)
FOR ALL SERIES
NUMBER OF
CONTACTS
www.edac.net
A±0.38
Inch
(mm)
B±0.25
C±0.13
PLUG
Inch
(mm)
Inch
(mm)
D±0.13
RECEPTACLE
Inch
(mm)
(16.33)
9
1.213 (30.81)
.984
(24.99)
.666
(16.92)
.643
15
1.543 (39.19)
1.312
(33.32)
.994
(25.25)
.971
(24.66)
25
2.088 (53.04)
1.852
(47.04) 1.534
(38.96)
1.511
(38.38)
37
2.729 (69.32)
2.500
(63.50) 2.182
(55.42)
2.159
(54.84)
PLUG/RECEPTACLE 663 SERIES
12.55±0.38
8.36±0.13
2.84
A
B
C
6.00±0.25
2.770
1
2
4
3
5
7
6
8
10
11
12
13
14
15
7
6
5
4
3
2
14
13
12.55±0.38
7.90±0.13
2.84
15
12
11
1
10
9
2.770
5.80±0.25
B
2.84
D
Ø1.10
4-Ø3.20
2.77
8.08 8.00
3.92
8.08
8.00 8.08
19.60±0.25
8.08
2.77
P.C.B EDGE
2.84
14.84±0.25
3.92
2.84
2.84
8
3.18±0.38
E
F
9
FOR ALL SERIES
RECEPTACLE/PLUG 664 SERIES
12.55±0.38
7.90±0.13
2.84
A
B
D
5.80±0.25
2.770
8
5
6
7
14
13
3
4
12
11
2
10
1
9
1
2
3
10
4
11
5
12
6
13
7
14
8
15
2.770
C
6.00±0.25
FOR ALL SERIES
E±0.25
8.00 8.08
19.60±0.25
14.84±0.25
3.92
12.55±0.38
8.36±0.13
2.84
2.84
8.08
9
3.18±0.38
E
F
15
2.84
CTR TO CTR
VERTICAL
SPACING
Inch
(mm)
F±0.38
Inch
(mm)
.625
.750
.900
FOR ALL SERIES
NUMBER OF
CONTACTS
www.edac.net
A±0.38
Inch
(mm)
B±0.25
C±0.13
PLUG
Inch
(mm)
Inch
(mm)
D±0.13
RECEPTACLE
Inch
(mm)
(16.33)
9
1.213 (30.81)
.984
(24.99)
.666
(16.92)
.643
15
1.543 (39.19)
1.312
(33.32)
.994
(25.25)
.971
(24.66)
25
2.088 (53.04)
1.852
(47.04) 1.534
(38.96)
1.511
(38.38)
37
2.729 (69.32)
2.500
(63.50) 2.182
(55.42)
2.159
(54.84)
很抱歉,暂时无法提供与“664-009-664-003”相匹配的价格&库存,您可以联系我们找货
