305-038-521-258
305-038-521-258
    305 SERIES (.156" (3.96MM) CONTA
305-038-521-258 数据手册
Contact Detail 521-P.C. Tail .037x.013(0.94x0.33) - Tail LG.=.125(3.18) .156 [3.96] Contact Spacing x .140 [3.56] Row Spacing Mounting Option 58-.468 (11.89) Offset Card Guides ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. ORIGINAL 1 0.343 8.71 Card Slot Accepts .054 (1.37) to .070 (1.78) Thick P.C. Board 0.156 3.96 3.128 79.45 3.274 83.16 0.295 7.49 Card Slot 3.560 90.42 4.406 111.91 0.460 11.68 A A 0.090 2.29 Point of Contact 3.870 98.30 305 / 315 / 355 Card Edge Connector Part Number: 305-038-521-258 See Accompanying Page for: • Mounting Options EDAC INC TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. SECTION A-A ACAD REFERENCE NO. J.LEE DRAWN: CHECKED: SCALE: NTS DRAWING NUMBER 305 Assembly 305 ENG MASTER DATE: SEPT. 21/09 DATE: SHEET 1 OF 2 ISSUE 1 0.125 3.18 Code x01 Code x12 ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. ORIGINAL 1 .128 [3.25] Dia Through Holes .128 [3.25] Dia Through Holes 0.468 11.89 0.344 8.74 0.125 3.18 0.060 1.52 Code x02 0.116 2.95 I.D. Floating Eyelets 0.090 2.29 0.250 6.35 Dia. .010 [0.25] Radial Float 2.750 69.85 Code x03 2.500 63.50 0.328 8.33 0.005 0.13 1.550 39.37 .156 [3.96] Dia Through Holes 0.250 6.35 Code x04 M3-0.5 Metric Threaded Insert #4-40 UNC Threaded Insert Code x68 305 / 315 / 355 Card Edge Connector Mounting Options EDAC INC Code x08 0.250 6.35 0.242 6.15 0.423 10.74 Code x58 Code x07 0.250 6.35 TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. Code x78 ACAD REFERENCE NO. J.LEE DRAWN: CHECKED: SCALE: NTS DRAWING NUMBER 305 Assembly 305 ENG MASTER DATE: SEPT. 21/09 DATE: SHEET 2 OF 2 ISSUE 1
305-038-521-258
1. 物料型号:文档中提到了型号为“305-038-521-258”的卡边连接器。
2. 器件简介:文档中没有直接提供器件的简介,但根据上下文推测,该文档描述的是一种卡边连接器,具有不同的安装选项和细节规格。
3. 引脚分配:文档中提到了接触点间距为“.156 [3.96]”和行间距为“.140 [3.56]”,以及不同代码(如Code x01, Code x12等)对应的不同直径的通孔。
4. 参数特性:文档中列出了多种参数,例如接触点的直径、通孔的直径、浮动眼圈的内径等,但没有提供详细的参数特性描述。
5. 功能详解:文档中没有提供功能详解部分,主要是图纸和规格说明。
6. 应用信息:文档中没有直接提供应用信息,但根据器件的描述,可以推测它可能用于电子设备的卡槽连接。
7. 封装信息:文档中提供了一些封装相关的尺寸信息,例如卡槽接受的PCB板厚度范围、接触点的尺寸等。
305-038-521-258 价格&库存
很抱歉,暂时无法提供与“305-038-521-258”相匹配的价格&库存,您可以联系我们找货
