305-080-520-502
305-080-520-502
    插件,P=3.96mm
    305 SERIES (.156" (3.96MM) CONTA
305-080-520-502 数据手册
Mounting 0.500 Option 12.70 02-.128 (3.25) Dia. Mounting Holes Contact Detail 520-P.C. Tail .046x.013(1.17x0.33) - Tail LG.=.213(5.41) .156 [3.96] Contact Spacing x .140 [3.56] Row Spacing ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. ORIGINAL 1 Card Slot Accepts .054 (1.37) to .070 (1.78) Thick P.C. Board 0.156 3.96 6.404 162.66 0.330 8.38 Card Slot 6.550 166.37 6.836 173.63 0.460 11.68 A A 305 / 315 / 355 Card Edge Connector Part Number: 305-080-520-502 See Accompanying Page for: • Mounting Options SECTION A-A 0.125 3.18 Point of Contact 7.146 181.51 EDAC INC TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. ACAD REFERENCE NO. J.LEE DRAWN: CHECKED: SCALE: NTS DRAWING NUMBER 305 Assembly 305 ENG MASTER DATE: SEPT. 21/09 DATE: SHEET 1 OF 2 ISSUE 1 0.125 3.18 Code x01 Code x12 ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. ORIGINAL 1 .128 [3.25] Dia Through Holes .128 [3.25] Dia Through Holes 0.468 11.89 0.344 8.74 0.125 3.18 0.060 1.52 Code x02 0.116 2.95 I.D. Floating Eyelets 0.090 2.29 0.250 6.35 Dia. .010 [0.25] Radial Float 2.750 69.85 Code x03 2.500 63.50 0.328 8.33 0.005 0.13 1.550 39.37 .156 [3.96] Dia Through Holes 0.250 6.35 Code x04 M3-0.5 Metric Threaded Insert #4-40 UNC Threaded Insert Code x68 305 / 315 / 355 Card Edge Connector Mounting Options EDAC INC Code x08 0.250 6.35 0.242 6.15 0.423 10.74 Code x58 Code x07 0.250 6.35 TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. Code x78 ACAD REFERENCE NO. J.LEE DRAWN: CHECKED: SCALE: NTS DRAWING NUMBER 305 Assembly 305 ENG MASTER DATE: SEPT. 21/09 DATE: SHEET 2 OF 2 ISSUE 1
305-080-520-502
PDF文档中包含的物料型号为305-080-520-502,属于305/315/355系列的卡边连接器。
器件简介指出,该连接器适用于接受0.054至0.070英寸厚的PCB板,并且有多种安装选项。
引脚分配详细说明了接触间距和行间距,分别为0.156英寸和0.140英寸。
参数特性包括接触细节、尾部长度、安装孔直径等。
功能详解部分描述了卡槽接受的PCB板厚度范围,以及连接器的接触点。
应用信息强调了该连接器是连接高质量和服务的桥梁。
封装信息提供了详细的尺寸和安装细节,如安装孔直径为0.128英寸,浮动眼环的内径为0.116英寸等。
这些信息对于理解连接器的物理特性和应用场景至关重要。
305-080-520-502 价格&库存
很抱歉,暂时无法提供与“305-080-520-502”相匹配的价格&库存,您可以联系我们找货
