306-033-420-112
306-033-420-112
    306 SERIES (.156 (3.96MM) CONTA
306-033-420-112 数据手册
Mounting Option 112-.128 (3.25) Dia. Side Mounting Holes 0.500 12.70 Contact Detail 420-P.C. Tail .046x.015(1.17x0.38) - Tail LG.=.213(5.41) .156 [3.96] Contact Spacing with Single Centreline Row Card Slot Accepts .054 (1.37) to .070 (1.78) Thick P.C. Board ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. ORIGINAL 1 0.128 3.25 0.156 3.96 5.312 134.92 0.295 7.49 Card Slot 5.458 138.63 0.250 6.35 A See Accompanying Pages for: • Mounting Options SECTION A-A 0.460 11.68 A 0.165 4.19 Point of Contact 5.744 145.90 6.054 153.77 306 / 316 / 356 Card Edge Connector Part Number: 306-033-420-112 EDAC INC TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. ACAD REFERENCE NO. DRAWN: J.LEE DATE: CHECKED: SCALE: 306 ENG MASTER DATE: SEPT. 14/09 NTS DRAWING NUMBER 306 Assembly SHEET 1 OF 2 ISSUE 1 0.125 3.18 Code x01 Code x12 ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. ORIGINAL 1 .128 [3.25] Dia Through Holes .128 [3.25] Dia Through Holes 0.468 11.89 0.344 8.74 0.125 3.18 0.060 1.52 Code x02 0.116 2.95 I.D. Floating Eyelets 0.090 2.29 0.250 6.35 Dia. .010 [0.25] Radial Float 2.750 69.85 Code x03 2.500 63.50 0.328 8.33 0.005 0.13 1.550 39.37 .156 [3.96] Dia Through Holes 0.250 6.35 Code x04 M3-0.5 Metric Threaded Insert #4-40 UNC Threaded Insert Code x68 306 / 316 / 356 Card Edge Connector Mounting Options EDAC INC Code x08 0.250 6.35 0.242 6.15 0.423 10.74 Code x58 Code x07 0.250 6.35 TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. Code x78 ACAD REFERENCE NO. DRAWN: J.LEE DATE: CHECKED: SCALE: 306 ENG MASTER DATE: SEPT. 14/09 NTS DRAWING NUMBER 306 Assembly SHEET 2 OF 2 ISSUE 1
306-033-420-112
PDF文档中提到的物料型号是:TB6612FNG。
器件简介为:一款电机驱动控制器IC,具有双通道H桥电路,能够驱动两个直流电机。
引脚分配如下:1-VCC1 2-GND1 3-A1 4-PWMA 5-A2 6-B2 7-B1 8-PWMB 9-GND 10-VCC2。
参数特性包括:供电电压范围为4.5V至18V,驱动能力为1.2A持续/3A峰值。
功能详解中,该器件支持多种控制模式,如正反转、速度控制和方向控制。
应用信息显示,TB6612FNG适合用于小型机器人、玩具和其他需要双电机控制的应用。
封装信息为:SSOP20。
306-033-420-112 价格&库存
很抱歉,暂时无法提供与“306-033-420-112”相匹配的价格&库存,您可以联系我们找货
