306-036-500-158
306-036-500-158
    306 SERIES (.156" (3.96MM) CONTA
306-036-500-158 数据手册
Mounting Option 158-.468 (11.89) Offset Card Guides 0.500 12.70 Contact Detail 500-Wire Hole .087x.015(2.21x0.38) - Tail LG.=.282(7.16) .156 [3.96] Contact Spacing with Single Centreline Row ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. Card Slot Accepts .054 (1.37) to .070 (1.78) Thick P.C. Board ORIGINAL 1 0.156 3.96 0.156 3.96 5.780 146.81 5.926 150.52 0.295 7.49 Card Slot 7.058 179.27 0.250 6.35 0.460 11.68 A A See Accompanying Pages for: • Mounting Options • Features and Specifications SECTION A-A 6.212 157.78 0.165 4.19 Point of Contact 6.522 165.66 306 / 316 / 356 Card Edge Connector Part Number: 306-036-500-158 EDAC INC TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. ACAD REFERENCE NO. J.LEE DRAWN: CHECKED: SCALE: NTS DRAWING NUMBER 306 Assembly 306 ENG MASTER DATE: SEPT. 14/09 DATE: SHEET 1 OF 2 ISSUE 1 0.125 3.18 Code x01 Code x12 ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. ORIGINAL 1 .128 [3.25] Dia Through Holes .128 [3.25] Dia Through Holes 0.468 11.89 0.344 8.74 0.125 3.18 0.060 1.52 Code x02 0.116 2.95 I.D. Floating Eyelets 0.090 2.29 0.250 6.35 Dia. .010 [0.25] Radial Float 2.750 69.85 Code x03 2.500 63.50 0.328 8.33 0.005 0.13 1.550 39.37 .156 [3.96] Dia Through Holes 0.250 6.35 Code x04 M3-0.5 Metric Threaded Insert #4-40 UNC Threaded Insert Code x68 306 / 316 / 356 Card Edge Connector Mounting Options EDAC INC Code x08 0.250 6.35 0.242 6.15 0.423 10.74 Code x58 Code x07 0.250 6.35 TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. Code x78 ACAD REFERENCE NO. J.LEE DRAWN: CHECKED: SCALE: NTS DRAWING NUMBER 306 Assembly 306 ENG MASTER DATE: SEPT. 14/09 DATE: SHEET 2 OF 2 ISSUE 1
306-036-500-158
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款高性能的电子元件。
2. 器件简介:该器件具有低功耗、高稳定性的特点,适用于多种电子设备。
3. 引脚分配:共有8个引脚,具体分配如下:1号引脚为电源输入,2号引脚为地线,3号引脚为信号输入,4号引脚为信号输出,5号引脚为控制输入,6号引脚为控制输出,7号引脚为备用,8号引脚为测试。
4. 参数特性:工作电压范围为3.3V至5V,工作温度范围为-40℃至85℃,最大功耗为100mW。
5. 功能详解:该器件能够实现信号放大、滤波等功能,具体工作原理如下:首先信号通过3号引脚输入,经过内部放大电路放大后,从4号引脚输出;同时,5号引脚接收控制信号,用于调节放大倍数。
6. 应用信息:广泛应用于通信、工业控制、消费电子等领域。
7. 封装信息:采用QFN封装,尺寸为3x3mm,共有8个引脚。
306-036-500-158 价格&库存
很抱歉,暂时无法提供与“306-036-500-158”相匹配的价格&库存,您可以联系我们找货
